Tune ECU - Triumph ECU's Programability
0l0dom0l0
PostPosted: 15:51 - 15 Nov 2011    Post subject: Tune ECU - Triumph ECU's Programability Reply with quote
In the Tune ECU software, you can change the injector timing by up to 250%, does anyone know if the ECU will actually accept this?
Ie in other words are they totally programmable and not restrictive like power commanders?
stonesie
PostPosted: 16:59 - 15 Nov 2011    Post subject: Reply with quote
Taking the injectors to anything like that extreme will need a turbo to get enough air in there but the main advantage of TuneECU for tuning is that it gives control over ignition timing, a power commander (not too sure about the latest version) can only alter the fueling, not the sparks.
It also acts as a handy diagnostic tool and can do fancy stuff like re-calibrateing the speedo to account for gearing changes or just makeing it read spot-on...... Must get a laptop so I can plug the Daytona in.
PostPosted: 18:09 - 15 Nov 2011    Post subject: Reply with quote
You can plug any value in weather the bike will run is another story. I made I thread about it a while ago and got good results with a little bit of fiddling
0l0dom0l0
PostPosted: 18:10 - 15 Nov 2011    Post subject: Reply with quote
Yeah thanks I understand that.
More to the point will the ecu actually accept it if I changed the fueling by 250% or not accept the new map if I've changed it that much?
0l0dom0l0
PostPosted: 18:13 - 15 Nov 2011    Post subject: Reply with quote
Sounds good.
So its totally programmable without any restrictions then and won't spit the map back out again if someone alters the fuelling by to much?
jjdugen
PostPosted: 18:14 - 15 Nov 2011    Post subject: Reply with quote
Triumph should hire the guys that wrote it, or at least pay them something. Probably the best (and free) piece of motorcycle software you can lay hands on. Dont go crazy making alterations, the downloadable maps are as near perfect as I have ever been able to get.
PostPosted: 18:16 - 15 Nov 2011    Post subject: Reply with quote
I don't know for certain but I would think so, the ECU wasn't really designed to be fiddled with by joe public so there wouldn't be any form of safety on it, the tune ECU will just update the matrix on the ECU.
Whether the injectors could actually put 250% extra fuel is is another story.
Why does it matter?
PostPosted: 18:19 - 15 Nov 2011    Post subject: Reply with quote
The Guy who wrote it just stole it from Tuneboy, he made it look different and removed the need for licensing. I'm pretty sure Triumph have there own version of this software probably Write by the Guys at Sagem who make the ECU. The hardest part wouldn't be writing it but hacking the maps and working out what does what. Triumph/Sagem wouldn't need to do this are they already know.
0l0dom0l0
PostPosted: 18:20 - 15 Nov 2011    Post subject: Reply with quote
Ahh okay, fair enough.
It was just out of curiosity really, because people I showed it too couldn't believe you would be able to have so much control over the map.
PostPosted: 19:24 - 15 Nov 2011    Post subject: Reply with quote
If you could get/borrow a wideband datalogger you can make a fuelling map easily that suits what you want to do.
Want maximum power in the upper rev/throttle openings? No problem, adjust the map for 13-13.2:1 AFR
Want to save a lot fo fuel whan cruising about at 70mph? No sweat, figure out what revs you cruise at and pull out fuel until your AFR is in the 14's.
Want to get rid of that lean stumble at about 4krpm? Easy, find the range where they retarded the ignition to comply with noise & emission regs and adjust the timing to advance it back up.
This is what the software is designed for. On it's own, it's a handy fiddle-tool, which might get you some improvement but for it to be really effective you need to know exactly what's going on, and what your changes did. Even with all that - you can still melt valves and pistons if you do something daft like alter fuelling table cells by 250%
0l0dom0l0
PostPosted: 20:11 - 15 Nov 2011    Post subject: Reply with quote
Thanks pete that's a very informative post.
The maps that are available do pretty much exactly what you would need so I'll have a study of them!
jjdugen
PostPosted: 00:19 - 16 Nov 2011    Post subject: Reply with quote
If the guys at Triumph, or Sagam were so good, why does every Triumph I've had in have the worst fuelling map possible (after the obligatory trip to the Triumph dealership to be utterly ripped off).
Either the dealers use an outdated map or the 'technicians' dont know how to do a simple download. My thoughts are that the 'official' program has to comply with noise/emmisions regs so its full of flat spot holes. The maps on TuneECU have been tweaked to make fuelling much smoother. BTW, I thought that the Tuneboy et. al. add ons were an eight bit device?
The last post was made 14 years, 333 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 75.68 Kb
