| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
 Posted: 15:51 - 15 Nov 2011 Post subject: Tune ECU - Triumph ECU's Programability |
In the Tune ECU software, you can change the injector timing by up to 250%, does anyone know if the ECU will actually accept this?
Ie in other words are they totally programmable and not restrictive like power commanders?
Cheers ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Bikes: 2007 Derbi GPR 50, 1998 Yamaha Fazer 600 (written off), 2002 Yamaha Fazer 600, 1994 CBR 600F, 2003 Triumph Daytona 600, Kawasaki ZX6R J1.....Current: 2006 Yamaha FZ6, 1998 Suzuki TL1000R and a Honda VFR 400 NC30. |
| stonesie |
 stonesie World Chat Champion
| chris-red |
| 0l0dom0l0 |
| 0l0dom0l0 |
| jjdugen |
 jjdugen World Chat Champion
| chris-red |
| chris-red |
| 0l0dom0l0 |
 Posted: 18:20 - 15 Nov 2011 Post subject: |
Ahh okay, fair enough.
It was just out of curiosity really, because people I showed it too couldn't believe you would be able to have so much control over the map. ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
 Posted: 19:24 - 15 Nov 2011 Post subject: |
If you could get/borrow a wideband datalogger you can make a fuelling map easily that suits what you want to do.
Want maximum power in the upper rev/throttle openings? No problem, adjust the map for 13-13.2:1 AFR
Want to save a lot fo fuel whan cruising about at 70mph? No sweat, figure out what revs you cruise at and pull out fuel until your AFR is in the 14's.
Want to get rid of that lean stumble at about 4krpm? Easy, find the range where they retarded the ignition to comply with noise & emission regs and adjust the timing to advance it back up.
This is what the software is designed for. On it's own, it's a handy fiddle-tool, which might get you some improvement but for it to be really effective you need to know exactly what's going on, and what your changes did. Even with all that - you can still melt valves and pistons if you do something daft like alter fuelling table cells by 250% ____________________ a.k.a 'Geri'
| 0l0dom0l0 |
| jjdugen |
The last post was made 14 years, 339 days ago. Instead of replying here, would creating a new thread be more useful? |
