| Kalamity Kid |
 Kalamity Kid Derestricted Danger
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 21:50 - 17 Nov 2011 Post subject: |
No.
The connectors are different for each injection system on each bike.
In theory you can snip the old connectors off and wire up new ones. Not sure it would work on the two bikes you describe as the R6 has 4/8 injectors (so four plugs), whereas the MT-03 only has 1 injector (So one plug).
My Mille's PCIII was actually a 2003-2005 Mille PCIII with the 99-2002 connectors soldered on. So it can work, I'm just not sure how compatible it is to be honest.
A little more detail for you. The PCIII is a piggy back ECU (Or flash memory). It sits between the ECU and the injectors. So the signal comes from the ECU for each injector. The PCIII then gets this signal bound for each injector, adds a correction factor to add or remove fuel then sends the signal the rest of the way to each injector.
On the R6 it has 8 injectors IIRC, but we only need to worry about the bottom 4. As your MT03 only has 1 injector you could try removing the three extra plugs from the R6 PCIII and then soldering on the correct plug for your injector (it might even be the same if you're lucky) personally I would have thought this would do something to the PCIII, but it depends how cheaply the PCIII for the R6 is. Might be worth a punt if it's only going to cost you £20. ____________________ My Flickr
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 21:53 - 17 Nov 2011 Post subject: |
as that guy said. the only variants are most likely the number of cylinders.
The power commander LCD screen is interchangeable though. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Kalamity Kid |
| Wafer_Thin_Ham |
There is a gap of 7 years, 324 days between these two posts... |
| bravethew1ld |
 bravethew1ld L Plate Warrior
The last post was made 7 years, 20 days ago. Instead of replying here, would creating a new thread be more useful? |
