Haynes Warning
WildGoose
White Van Man
PostPosted: 15:24 - 11 Sep 2004    Post subject: Haynes Warning Reply with quote
a word of advice, be very wary about following any advice from these books regarding torque settings
i'm well aware that torque settings are pretty in-accurate as it is, but it appears haynes has no clue about the bikes they write about, and so far i have encountered 3 torque settings that are so woefully wrong, that its caused the bolt to shear clean off
so use only manufacturer quoted torque settings, if you dont wish to ruin your weekend Thumbs Up
and avoid instant gasket, its toss, use only official honda parts, thank you
PostPosted: 15:34 - 11 Sep 2004    Post subject: Reply with quote
Go on, which bolts and what torques?
Also might be worth checking the torque wrench. Years ago I sheared a head bolt on on the MBX125 using a torque wrench. Turned out that when it was indicating 15 lb/ft it was actually almost 30.
WildGoose
White Van Man
PostPosted: 15:37 - 11 Sep 2004    Post subject: Reply with quote
disc bolts, quoted as 20 when it should be 15, snapped as a result
clutch cover bolts, read as 24, should have been 12, bit of confusion on my part, as they word it as "8mm engine cover bolts" which i thought meant the head, but apparently means the thread
would be much nicer if they quoted the bolts they mean
the exhaust bolt torques were too tight as well, i sheared one of those earlier today, but cant remember the exact number
PostPosted: 15:48 - 11 Sep 2004    Post subject: Reply with quote
That is a very low torque for a disk bolt. EG, early CBR600 it is 29lb/ft, slightly later ones 31 lb/ft. The VFR400 it is 14lb/ft though.
Metric bolts are always quoted on the thread size (it is the old WW ones that the spnner size referred to the thread).
Had fun with a Clymer manual that told you to refer to "table 1" for the cylinder head torques. Found table 1 and it gave a torque for the appropriate size fastener. Later found another table one in that chapter (rather than in the notes at the front) which gave a specific higher torque for those bolts.
WildGoose
White Van Man
PostPosted: 16:00 - 11 Sep 2004    Post subject: Reply with quote
the above torques were in Nm, didnt make that clear
it just frustrates me, cos making a manual like a haynes must cost loads, why cant they do it properly, making the list of torque settings 3-4 pages long rather than trying to abbreviate it by saying, 8mm bolt = such and such a torque
haynes are sposed to be an idiots guide anyway, surely
PostPosted: 16:07 - 11 Sep 2004    Post subject: Reply with quote
Personally I wish they would put the torque in the text as well as a list at the start of the section, as I get hacked off wandering off to find the torque figures and loosing the place in the manual.
However most bolts are just torqued to a generic value for that size bolt, and with metric bolts an M8 refers to an 8mm thread.
ZRX61
Victor Meldrew
PostPosted: 16:29 - 11 Sep 2004    Post subject: Reply with quote
You torqued the clutch cover bolts????? Rolling Eyes
WildGoose
White Van Man
PostPosted: 16:40 - 11 Sep 2004    Post subject: Reply with quote
yes, do you have a point, other than trying to sound condesending?
every bolt down to the oil filler cap has a specified torque setting, if you were to service a bike officially by the book, you would use a torque wrench for everything
and considering the clutch cover, is an area with gasket, where the idea is to stop oil leaking, you would think its a fairly important bolt to get the torque right
so kindly stfu Middle Finger
Robby
Dirty Old Man
PostPosted: 17:36 - 11 Sep 2004    Post subject: Reply with quote
Goose has a torque fascination. Others just do things up tight, goose torques everything.
We leave him to it, and he doesn't bother us.
PostPosted: 17:44 - 11 Sep 2004    Post subject: Reply with quote
Finger tight doesn't count for wheels. Razz Razz
Robby
Dirty Old Man
PostPosted: 19:01 - 11 Sep 2004    Post subject: Reply with quote
Its only Danny, its not an important bolt.
carvell
Scuttler
PostPosted: 19:15 - 11 Sep 2004    Post subject: Reply with quote
Bleh to torque settings.
I've never ever used one, I just do them up as tight as I think they should be done up, when I feel it beginning to shear or I think it's goign too far, I stop.
Not had a problem yet. Thumbs Up
Yamaha TDM 850
Rory
PostPosted: 19:19 - 11 Sep 2004    Post subject: Reply with quote
*cue sheared sump plug* Smile
My Old CBR400RR | Bike Oil FAQ | Petrol FAQ
carvell
Scuttler
PostPosted: 19:20 - 11 Sep 2004    Post subject: Reply with quote
That's the one I'm most weary of - bollocks am I letting some tool tell me if its tight enough - if I do it myself I can stop before it shears, the tool won't!
Yamaha TDM 850
Phoenix
Twisted Firestarter
PostPosted: 17:10 - 12 Sep 2004    Post subject: Reply with quote
I thought you guessed the tightness goose, as your torque wrench didn't go low enough Wink
WildGoose
White Van Man
PostPosted: 17:28 - 12 Sep 2004    Post subject: Reply with quote
shush, that was only one of them Wink
mrchips
PostPosted: 19:34 - 12 Sep 2004    Post subject: Reply with quote
What happened the gold old days of mechanicing when you knew how tight a bolt should be by the feel of the ratchet?
PostPosted: 21:54 - 12 Sep 2004    Post subject: Reply with quote
I would say there must have been a structural fault on the bolt if that happened, they usually use a minimum of grade 8.8 high-tensile bolts to hold on discs, it should have stripped the thread out of the hub before it sheared the bolt
They did. You ALWAYS refer to the diameter of the bolt not the size of spanner you use on it. An M6 bolt can have virtually any size head on it that you want to make, it would still be an M6, my bike some with 10, 11 and 12mm heads (and some with 5mm allen heads).
The two most common lies in Haynes manuals are:
"Warning, this is a right hand thread."
and
"Reassembly is the reverse of the above."
RealNinja
PostPosted: 19:32 - 13 Sep 2004    Post subject: Reply with quote
and
Oh how so painfully true Evil or Very Mad
You will become my force of retribution. Where you tread, doom will follow. Go now and claim your destiny
Clanger
Stirrer
PostPosted: 09:19 - 14 Sep 2004    Post subject: Reply with quote
We use the Clymer manuals - far more descriptive in their diagrams!
mr.z
PostPosted: 11:14 - 14 Sep 2004    Post subject: Reply with quote
Somehow managed to get hold of a factory manual (for a 20year old bike they are a little bit rare!) i go by that for torque settings...
I'd rather spend 3minutes torqueing a bolt properly than several hours fixing it. I very nearly had a knackerd radiator because somebody thought they knew better and guessed the torque, it was WAY too tight and could have knackered the rad, just because they couldn't be arsed to check. It didn't need torqueing but 2lbft gives you a clue.
Overtightening might not shear the bolt but it can cause fractures in say.. your engine caseing (on the sump plug, how about a never ending leak, great fun).
Haynes have a bit of a reputation for over-enthusiastic torque settings, if it says 10-20 i use 12 or 25-30 i'll use 27, or get it out the propper manual!
The last post was made 22 years, 48 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 111.63 Kb
