Loooong project CD175
Bike Chat Forums Index -> Show & Tell Goto page 1, 2, 3 ... 9, 10, 11  Next
grahamd1
PostPosted: 13:27 - 19 Nov 2011    Post subject: Loooong project CD175 Reply with quote
I took my test (too many years ago) on my trusty cd175, so I have hankered to find another, but the cost of them is silly on fleabay, then I came across this wreck for not a lot, and well, just had to have it (even the wife nagged me to get it, as she remembers my old one well). and voila one 1972 CD175 that has spent the last 20+ years in the back os someones shed. I drove 140miles this morning to collect it, and its amazing what you can squeeze into the back of a Picasso Razz Laughing
https://i314.photobucket.com/albums/ll431/grahamdrry/CD175/ebayp2.jpg
https://i314.photobucket.com/albums/ll431/grahamdrry/CD175/IMAG0276.jpg
XV1100, XV750
CD175 (Rebuild)
CF70 (Chaly - Rebuild),
grahamd1
PostPosted: 15:05 - 20 Nov 2011    Post subject: Reply with quote
Wahay, got the engine out, however do have a problem with the carb, more on that later.
https://i314.photobucket.com/albums/ll431/grahamdrry/IMAG0285-1.jpg
Took the top off the carb so I could pull out the throttle slide so that I could take the engine out complete with carb BUT, the damn slide is stuck solid (crud fuel!!!) and wont budge, with the throttle cable stuck in situ. So I took the carb off to enable me to get the engine out, but I'm buggered if I can get the cable or slide out of the carb, I've soaked it in penetrating oil and paraffin, but so far no go, and I dont want to damage it, suggestions ?
XV1100, XV750
CD175 (Rebuild)
hadden
PostPosted: 20:07 - 20 Nov 2011    Post subject: Reply with quote
hi mate.looks like this could be a good project.im no expert by all means but if it was me i would either get dw-40 down there and spend a good hour wiggling it.or search the net just incase there is a knack to it.you never know.
red bull gives you wing sting!!!
current:aprilia rs 125
previous:honda c90,honda cm 125,yamaha xt 550,2004 suzuki drz 400.(all used for off road back in the day)and a piagio zip 50cc..oooossssshhhh
virus
PostPosted: 20:52 - 20 Nov 2011    Post subject: Reply with quote
your going to have to completely strip and clean the carb anyway so drop it in a vat of diesel overnight, that will unsieze it.
John
own: 81 xs1100g...
pepperami
PostPosted: 21:09 - 20 Nov 2011    Post subject: Reply with quote
This ^ +1
grahamd1
PostPosted: 17:38 - 21 Nov 2011    Post subject: Reply with quote
In the end I took some cutters to the throttle cable (having checked I could still get a replacement), and that allowed me to bring the carb into the house for examination. Took the top off and wiggled the inner throttle cable till it came clear of the slide, then again sprayed and soaked the carb in brake cleaner/wd40/penetrating oil. Went back a few hour later, and nope still not moving, so I tool the rear fly screen (a small mesh over the air intake), and could just see the bottom of the slide, so using a small bit of wood wedge shaped, I kept pushing and working it in, till it moved a little bit, then more spray, more wedging, untill it came out. What was holding it was cruddy sediments of old fuel, almost like tar. Tonight I'm going to strip it right down, and give it a soak in the ultrasonic bath.
I've also removed the handlebars (not sure if they are saveable), and the front headlamp cowl with the speedo. Just tried a drill in the speedo and that works fine, BUT its discoloured over the years of neglect so I'd like to strip the speedo down and give that a clean. But its made of metal and although I can get the screws out of the back (talk about rusty), its clear that disasembly requires the guts to come through the glass front aperture, and from what I can see the glass is held in by the front chrome (ISH) bezel, formed over a lip around the speedo. So removing the glass so I can get at the guts is gonna be a bugger.
Whilst playing yesterday, I discovered it had a cheapo tin horn fitted, rather than the original oem part (I loved the sound of the original), but luckilly I found someone selling an original, so its on order. Also no iginition switch (hard wired), so again found someone with an original one with braket and original Honda keys. the helmet lock and steering lock keys are also missing, but they look servicable. I did a search on the net and if I send my helmet lock to a specialist they will cut a key to match (steering and helmet lock are the same key), for about £12.
XV1100, XV750
CD175 (Rebuild)
grahamd1
PostPosted: 17:49 - 21 Nov 2011    Post subject: Reply with quote
All in all the condition is not as bad as it looks, at some point someone has cared for her, as touch wood nothing has broken when being dismantled (inc bolts/screws).
The bottom head steady bracket is before 10 minutes with the dremel, and the top one is after, but I'm going to sand them down to the steel again before priming.
https://i314.photobucket.com/albums/ll431/grahamdrry/CD175/IMAG0280.jpg
Even the rear wheel looks like it will sucum to the charms of dear old mr dremel (first pic is before)
https://i314.photobucket.com/albums/ll431/grahamdrry/CD175/IMAG0281.jpg https://i314.photobucket.com/albums/ll431/grahamdrry/CD175/IMAG0283.jpg
Might change the spokes though, and the rims will never recover, too badly pitted, I see DS has them listed as spare parts and available so I could keep the hubs ad just change the spokes and rims.
Tried the dremel on that flaky corrosion on the engine and again it looks like it will come off ok
https://i314.photobucket.com/albums/ll431/grahamdrry/CD175/IMAG0286.jpg https://i314.photobucket.com/albums/ll431/grahamdrry/CD175/IMAG0287.jpg
XV1100, XV750
CD175 (Rebuild)
CHR15
Turbo nutter bastard
PostPosted: 20:13 - 21 Nov 2011    Post subject: Reply with quote
if your rebuilding the engine, might as well get it soda blasted. it ill bring it back to factory finish.
grahamd1
PostPosted: 06:24 - 22 Nov 2011    Post subject: Reply with quote
Yea will probably do that, after I've stripped her down
XV1100, XV750
CD175 (Rebuild)
grahamd1
PostPosted: 12:26 - 23 Nov 2011    Post subject: Reply with quote
Currently stripping down the carb, YUK the bottom was 1/2" of dried crud, tried brake cleaner and crappy carb cleaner from Halfrauds and nothing seemed to touch it, so I brushed it out with the dremel (copper wire brush). Again brake cleaner and carb cleaner wouldn't touch the stains left, so I called in on my local car garage, and got a tin of this, its the bees knees, first blast does nothing, second blast and the stain starts running, a quick wipe with a cloth, and another blast and it looks clean. I'm going to soda blast (from an article on here) the outside once I've repaired my compressor.
This was the stuff I got (£2 a tin,,, bargin)
https://i314.photobucket.com/albums/ll431/grahamdrry/CD175/IMAG0293.jpg
XV1100, XV750
CD175 (Rebuild)
grahamd1
PostPosted: 20:22 - 23 Nov 2011    Post subject: Reply with quote
Tonight I managed to remove the swinging arm, and I'm a happy bunny its in great shape, and so is the bottom of the frame, even the bolt came out easy, and the barings look ok, no slop, just as well.
Took the front forks off the frame, rubbed them down with wire wool and oil, and they also have come up nice, but I want to strip them down to replace the fork seals, BUT I cant remove the chrome lower fork covers (manual says they are screwed on), the haynes manual talks of a "Special" honda tool "Peg Spanner" being required, fat chance after all these years. They suggest an alternative is a strap of chain? Tried using a leather belt, nothings moving, reluctant to use a chain in case I further destroy the remaining chrome.
Anyone ?
XV1100, XV750
CD175 (Rebuild)
grahamd1
PostPosted: 13:48 - 24 Nov 2011    Post subject: Reply with quote
This morning I took the forks to a local engineering company, and we tried all manor of clamps (oil filter, canvas webbing, chains), and NOTHING budged, out of deperation we cut some steel tube and drilled two holes with two 10mm bolts screwed in that fitted into the pre-cut slots (used by honda with their peg spanner), and ?
NOTHING, even 3 of us pushing and twisting (they fit like a bayonet, 1/4" turn then pull off), no way were they shifting. Took a micro camera and inserted it into the stanchions to have a look at the fork seals, and they are in great shape, so worse case I aint gonna change them Twisted Evil
Got the swinging arm out of the frame last night, and I think where the enclosed chainguard has been removed sometime in the past, that has saved the old gal, by spraying chain oil over the frame and swinging arm.
XV1100, XV750
CD175 (Rebuild)
LongJohn22
PostPosted: 22:57 - 24 Nov 2011    Post subject: Reply with quote
This thread really needs more pictures.
grahamd1
PostPosted: 05:50 - 25 Nov 2011    Post subject: Reply with quote
Yea sorry, work keeps getting in the way, lol but I'm around this weekend so I will take some then, plus I need to get the frame stripped of both parts and paint by next week.
XV1100, XV750
CD175 (Rebuild)
deleted111
PostPosted: 10:47 - 25 Nov 2011    Post subject: Reply with quote
Watching with interest, my Grandpa had one of these!
grahamd1
PostPosted: 19:42 - 26 Nov 2011    Post subject: Reply with quote
Thought I'd strip off the controls from the handle bars and check if they were salvable. Once removed I gave them a good squirting with the carb cleaner shown in above posts, as it just blasts away greece and other grime. Then I cut off the old heatshrink tube (will replace that with new later), and set about cleaning/testing.
This is the RH unit (turn) before using a dremel with Solvol
https://i314.photobucket.com/albums/ll431/grahamdrry/CD175/IMAG0310.jpg
and a few hours later
https://i314.photobucket.com/albums/ll431/grahamdrry/CD175/IMAG0311.jpg
Heres the otherside
https://i314.photobucket.com/albums/ll431/grahamdrry/CD175/IMAG0308.jpg
And the set together
https://i314.photobucket.com/albums/ll431/grahamdrry/CD175/IMAG0312.jpg
I've also checked the switch/wires for continuity (sprayed some switch/contact cleaner in for lubrication) using the circuit diagram and my fluke dvm.
https://i314.photobucket.com/albums/ll431/grahamdrry/CD175/IMAG0319.jpg
Amazing 20 years of sitting in the damp and a little bit of love and they work and look fine.
XV1100, XV750
CD175 (Rebuild)
grahamd1
PostPosted: 19:49 - 26 Nov 2011    Post subject: Reply with quote
Also attacked the front and rear hubs and brake arms (using same treatment)
https://i314.photobucket.com/albums/ll431/grahamdrry/CD175/IMAG0315.jpg
https://i314.photobucket.com/albums/ll431/grahamdrry/CD175/IMAG0317.jpg
https://i314.photobucket.com/albums/ll431/grahamdrry/CD175/IMAG0314.jpg
XV1100, XV750
CD175 (Rebuild)
herulach
PostPosted: 20:02 - 26 Nov 2011    Post subject: Reply with quote
Those control pods are pimp, want.
YBR 125>FZS600
LongJohn22
PostPosted: 22:38 - 26 Nov 2011    Post subject: Reply with quote
I love this stuff, keep it coming!
grahamd1
PostPosted: 17:07 - 27 Nov 2011    Post subject: Reply with quote
Wahay, frame now naked, ran a wirebrush (on my battery drill) over the frame to check for any holes or problems, and shes good to go. So first coat of paint stripper has been applied, and rubbed off, second coat will be applied tomorrow.
https://i314.photobucket.com/albums/ll431/grahamdrry/CD175/IMAG0320.jpg
XV1100, XV750
CD175 (Rebuild)
grahamd1
PostPosted: 17:12 - 27 Nov 2011    Post subject: Reply with quote
Also did some more rubbing down of some of the grubby parts.
In this case the rear wheel adjusters
https://i314.photobucket.com/albums/ll431/grahamdrry/CD175/IMAG0322.jpg
And after
https://i314.photobucket.com/albums/ll431/grahamdrry/CD175/IMAG0325.jpg
XV1100, XV750
CD175 (Rebuild)
grahamd1
PostPosted: 17:17 - 27 Nov 2011    Post subject: Reply with quote
Now lets see whats lurking under the head stock ?
https://i314.photobucket.com/albums/ll431/grahamdrry/CD175/IMAG0323.jpg
https://i314.photobucket.com/albums/ll431/grahamdrry/CD175/IMAG0326.jpg
https://i314.photobucket.com/albums/ll431/grahamdrry/CD175/IMAG0324.jpg
https://i314.photobucket.com/albums/ll431/grahamdrry/CD175/IMAG0328.jpg
Camera doesn't do the parts justice, in fact they are so shiney you can see your face in them.
XV1100, XV750
CD175 (Rebuild)
grahamd1
PostPosted: 16:52 - 29 Nov 2011    Post subject: Reply with quote
Frame is almost stripped of paint, I'm amazed at the condition for a 40 year old Jap bike Shocked
So far 2ltrs of nitromors, and two copper wire brush attachments for the drill, worn down to the hub.
I also took the rear tyre off the rear wheel, NIGHTMARE, the rubber seems to have gone rock hard, took me over an hour with 3 tyre leavers (by the way Poundland has motorbike tyre leavers at the moment £1 each), damn tyre fought me every inch. I think the rim is a no,no I see Davis Silver has new rims, but doesnt mention spokes, also some time back someone mentioned somewhere that did wheels and offers a rebuild service ? Anyone ?
XV1100, XV750
CD175 (Rebuild)
Damon
PostPosted: 08:24 - 30 Nov 2011    Post subject: Reply with quote
I'm liking this build very much. Keep up the good work Thumbs Up
Gonna be great hearing it start up again after all these years! Are you going to replace the bearings in the engine? or just oil it and see?
Thanks,
Damon
grahamd1
PostPosted: 12:02 - 30 Nov 2011    Post subject: Reply with quote
Thanks,
Damon
Gonna strip and rebuild
XV1100, XV750
CD175 (Rebuild)
The last post was made 14 years, 352 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 11
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.12 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 133.71 Kb
