| Kickstart |
 Kickstart The Oracle
 Posted: 13:55 - 22 Nov 2011 Post subject: Household radiators |
Just looking at the radiator in the spare room which I want to turn off. There appear to be 2 valves on the radiators in the house, one at each end. But on most one has a knob to enable it to be turned and the other has a blanking piece over the top.
Can either be used to turn off the radiator or is there a reason only one has a knob on it?
Reason I ask is the radiator I want to turn off has at one end no knob or blanking piece (would be easy enough to turn with a spanner, if I should) while the other end is hidden behind a filing cabinet and I can see it let alone turn it if it has a knob on it.
| Raffles |
 Raffles World Chat Champion
| Kickstart |
| Raffles |
| Kickstart |
| Robby |
 Robby Dirty Old Man
| stinkwheel |
 Posted: 15:08 - 22 Nov 2011 Post subject: |
Although it must be said, I have found that if you turn them fully off using the outlet valve only, they can leak a little round that valve.
Doesn't happen if you turn them off using the inlet valve.
I think the pressure coming up the pipe tends to hold the inlet valve closed against its seat. If there is a little slack in the outlet one, the pressure tends to force it the other way and it can seep a little up round the shaft.
So I'd always turn it off using the inlet valve, which is the one with a proper knob on it or the one on the hotter of the two pipes when it's first turned on. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| JonB |
 JonB Afraid of Mileage
| Kickstart |
| TomCB |
 TomCB Scooby Slapper
| Kickstart |
| swampy |
 swampy World Chat Champion
 Posted: 18:13 - 22 Nov 2011 Post subject: |
I'm just waiting for G to move this to Dear Aunty BCF...
Its gonna be like a golden blob clash of the titans...
Oh, and if you turn off using the TRV, isn't there a risk of the valve opening and flooding your carpet ? ____________________ "I hate to advocate drugs, alcohol, violence or insanity to anyone, but they've always worked for me." Hunter S Thompson
"Faster, faster, faster, until the thrill of speed overcomes the fear of death..." Hunter S Thompson |
| herulach |
 herulach World Chat Champion
| Kickstart |
| TomCB |
 Posted: 08:41 - 23 Nov 2011 Post subject: |
my bad, i was thinking you just wanted it turning off, not actually disconnecting  ____________________ Faldo: "Classic BCF. A thread about sky diving is NSFW on post #2." |
| McJamweasel |
 McJamweasel BCF Junkie
 Posted: 10:10 - 23 Nov 2011 Post subject: |
When you turn it off you might find that it leaks a little from the valve, if it does just tighten the nut thats on top of the valve a little and it will stop.  ____________________ BCF: Be yourself, just don't be an arse. |
The last post was made 14 years, 292 days ago. Instead of replying here, would creating a new thread be more useful? |
