brake shim ?
Valentino Mossy
PostPosted: 21:36 - 11 Sep 2004    Post subject: brake shim ? Reply with quote
Can any one tell me what is the brake shim for ? Confused
Its a thin piece of metal on the brakes close to the pads. (Well its off the ns125r front brake caliper).
It broke off the other day, but i took it for a test run with out it and the bike seemed okay,no squeeking,binding or lack of brakes.
WTF is it for, and does it harm the bike (or me !) by running without it ? Confused
Richard (I'm having no luck with these brakes,first it was the pads,then the easyouts snapped in the fluid pot thingy and now its bits falling off ! I wish i never touched them ! ) moss
ZRX61
Victor Meldrew
PostPosted: 21:55 - 11 Sep 2004    Post subject: Reply with quote
It goes between the pad & the piston to *alledgedly* stop brake squeel....
swampy
PostPosted: 22:16 - 11 Sep 2004    Post subject: Reply with quote
As ZRX61 says, its meant to stop brake squeal, should also use copper grease on back of pads for the same reason, buggered if I know how it works though Thumbs Up
Valentino Mossy
PostPosted: 22:25 - 11 Sep 2004    Post subject: Reply with quote
Meh !
Nah it goes on the caliper thingy and has a 2mm gap between it and the front edge of the pad.
If it is a form of stoping the pads from squeeking, how the hell does it do it ?
Me confused ? Wink
Liono
PostPosted: 19:55 - 12 Sep 2004    Post subject: Reply with quote
On mountain bikes when you set the brakes up you "toe them in" by setting them so that the front of the pad hits the rim first, closely followed by the rest of it. This prevents (or reduces) brake squeal. Just a guess, as I don't have a clue about how it fits, but does the shim do a similar thing for your brakes?
Valentino Mossy
PostPosted: 20:25 - 12 Sep 2004    Post subject: Reply with quote
These are pic's from the dreaded haynes manual ! Sick
Retro-Man
PostPosted: 20:32 - 12 Sep 2004    Post subject: Reply with quote
as the piston advances out it has a tendency to twist slightly the shim absorbs the resonation caused by this
as the piston returns in to the piston (It does this purely by a specially shaped piston seal) the shims take up any slack again preventing any squeak causing resonation..
the shims are only to be used with standard pads and a small smearing of copper slip (correct use of copperslip should leave a almost colourless smear).
some pads are available with a soft pad like backing already on the pad backing This type of pad does not require shims and in no circumstances should be copper slipped.
see my answer in the other post
https://domharnessphotography.webs.com
The last post was made 21 years, 217 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.42 - MySQL Queries: 13 - Page Size: 52.52 Kb
