Aprilia Tuono 125cc
vjezerick
PostPosted: 20:10 - 03 Dec 2011    Post subject: Aprilia Tuono 125cc Reply with quote
Hi guys. Hope you're all well.
I have recently bought my aprilia "april" heh and there's has been afew problems along the way.
#1 I heared the starter motor sound(when you press the ignition button) when I pulled up, at the lights.
#2 in third gear(sometimes 2nd) just as I'm about to hit power band the bike cuts out.
solution: i checked the rave valve and there was half of the circle missing, so I replaced it with a new part.
#3 now that I thought I fixed the issue, I attempt to start the bike up and noticed there was petrol firing out into the exhaust and when I took the exhaust off previous to fitting the RAVE VALVE, there was plenty of petrol in the actual exhaust. I'm talking PLENTY. almost all full of petrol.
attempted solution: I removed the carb and check it out, there was a piece of red type hard material in there, not in a position of harm, but, there non- the less. I removed that and re-fitted the carb and went onto decoke the piston head.
that's basically it, i have no idea what's going on. My main concern is the petrol and where it is going.
any speculation would be massivelty appreicated.
take care, Dan.
vjezerick
PostPosted: 13:52 - 05 Dec 2011    Post subject: Reply with quote
no-one has any ideas. anybody? :[
PostPosted: 13:58 - 05 Dec 2011    Post subject: Reply with quote
I don't think you've described the issues very well... So you're saying a piece of your exhaust valve has gone missing? And the exhaust is very full of fuel? And there was a piece of plastic in your carburettor?
Jeez, sounds like it's been looked after by a right monkey. I assume the bike is out of warranty?
vjezerick
PostPosted: 01:20 - 06 Dec 2011    Post subject: Reply with quote
i replaced the part of the rave valve that was damaged that was my initial thought as to why the exhaust chamber is puking petrol into the pipe. it's not though.
sorry, i'm not that well educated.
the bike is out of warranty.
what would be the first thing to check if petrol is mass flowing where it shouldnt be, or, if it should be flowing into the pipe, why is it flowing so much?
thank you for replying, man. many thanks Very Happy.
WannaBeDude
PostPosted: 01:30 - 06 Dec 2011    Post subject: Reply with quote
For that line you deserve all the help you need Smile
Have you cleaned the carb, air filter, can you tell us more about the bike age and condition ?
How olds the sparkplug ?
Checked the fuel line is in A 1 conidtion ..
That will do for now Thumbs Up
PostPosted: 10:04 - 06 Dec 2011    Post subject: Reply with quote
Well, if that is true it honestly doesn't show. You can write, and spell and can describe things better than a lot of people, its just that with three problems going on at once, its a little confusing to try to diagnose the ultimate issue. I'll have a think about it and get back to you... I am pretty flummoxed by what you're saying. I think I'd need more detailed knowledge of Tuonos/RS125's to give you a proper answer. There must be a common thread here, but I can't see what it is. Or, you've bought a lemon and there are three seperate problems!
PostPosted: 11:08 - 06 Dec 2011    Post subject: Reply with quote
Finding a piece of 'stuff' in the carb explains the petrol.
This part probably jammed the float open.
The float stops fuel coming down to the carb from the tank when the carb is full - so if this is jammed open, fuel will keep flowing down.
As it's a 2 stroke, fuel can flow right through from the inlet to the exhaust. This isn't uncommon.
Note in future that when you've got the carb off it's worth cleaning out the jets. Take each jet of indivdually, inspect it by eye and blow through it hard by placing it between your lips (so it's sealed) and giving a decent puff out.
c_dug
PostPosted: 11:15 - 06 Dec 2011    Post subject: Reply with quote
If petrol is flowing to the exhaust then it may be worth checking your oil to make sure the petrol hasn't seeped past the piston rings and into the crank case. When I had my TDR250 I had a similar issue with fuel in the exhausts, can't remember the cause though, a few years without a stroker and my mind is blank!
PostPosted: 11:25 - 06 Dec 2011    Post subject: Reply with quote
It would seem so! Wink
Being a 2 stroke you'd be just as worried about the fuel flowing FROM the crankcase past the piston rings INTO the combustion chamber, as fuel is first drawn into the crankcase on most 2 strokes. (And thus 2 stroke oil is added to the fuel to lubricate the crank case.)
c_dug
PostPosted: 11:33 - 06 Dec 2011    Post subject: Reply with quote
Confused I really am confused then, I'll take this opportunity to STFU and stop offering advice Laughing
PostPosted: 11:42 - 06 Dec 2011    Post subject: Reply with quote
https://2.bp.blogspot.com/_gAgQvbXCkxQ/TSOvje5ZKnI/AAAAAAAAACw/cKFpF0H_mWI/s1600/2+stroke.gif
The crank case area is used to pressurise the fuel/air mixture and force it into the combustion chamber.
c_dug
PostPosted: 11:49 - 06 Dec 2011    Post subject: Reply with quote
As it goes I remember my dad explaining something like that when I had my TS50, probably should have listened better!
PostPosted: 22:35 - 06 Dec 2011    Post subject: Reply with quote
So wait a minute... Now you've removed the hard red substance from the carb... Is there still fuel coming out of the exhaust? If not, then I suspect you've fixed it. If yes, then there is something else wrong.
vjezerick
PostPosted: 17:37 - 24 Dec 2011    Post subject: Reply with quote
This is a super late reply. been so busy lately. After I removed the substance from the carb, the fuel did continue to spit out into the exhaust. I haven't been able to do anymore on the bike, so, there's no updates.
as far, as I know; the carb is my problem. but, I can understand why there is fuel after the explosion :/. (if that's how it works).
Noxious89123
PostPosted: 19:43 - 24 Dec 2011    Post subject: Reply with quote
Got a picture of what you removed from the carb?
vjezerick
PostPosted: 23:21 - 24 Dec 2011    Post subject: Reply with quote
No. Imagine a 1cm squared stone. but, red and semi-transparent.
The last post was made 14 years, 286 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.65 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 93.02 Kb
