YBR125 Vibrations
simon75
PostPosted: 18:57 - 05 Dec 2011    Post subject: YBR125 Vibrations Reply with quote
Hi Guys. Wonder if anyone can help me. Recently I have been riding my YBR125 to and from work and it has developed vibrations, started quite gently and has got progressively worse. I took it to a garage and the guy checked it over and said everything seemed fine. It always seems to be when i get over 30mph.
I have no idea what it could be as im not bike savvy but I googled and it was suggested I should check all nuts, bolts etc and then went into checking brakes etc which I dont have a clue how to do. Obviously I don't know if its safe to ride, and the earliest the garage can have a proper look is next week.
Any advice gratefully received. Thanks guys Very Happy
Torx
PostPosted: 19:35 - 05 Dec 2011    Post subject: Reply with quote
Check your head bearings perhaps. Making sure the nuts and bolts are tightened up properly is the first thing I'd do though.
Does the bike feel unstable when it's vibrating a lot? Have you checked your tyre pressure?
He who wants to keep his garden tidy doesn't reserve a plot for weeds.
simon75
PostPosted: 20:26 - 05 Dec 2011    Post subject: Reply with quote
Thanks Torx. Yeah, I've checked my tyre pressures as I do this regularly anyway. Il check the nuts and bolts in the morning. iT doesnt feel unstable, just uncomfortable Confused
craigT19
Jolly Green Giant
PostPosted: 10:48 - 06 Dec 2011    Post subject: Reply with quote
Without more detail its hard to say tbh.
But based on what u have said so far if it were me looking at it i would check the wheels are balanced?
Vibrations getting worse based on speed rather than rpm (im assuming in all gears at 30mph? well 4th and 5th anyways because any lower than that u wont hit 30) smacks alittle of a wheel being out of ballance.. probably your front look around the rim and check for signs that you have thrown a wheel weight, i.e a clean spot on a dirty rim etc.
Bikes owned :- 2001 nsr125, 1999 zx6r, 2006 yzf-r1, 2009 xmax 250, 2012 yzf-r1, 2015 MT-07
Current bike : - 2016 MT-10
Crying or Very sad BCF member pops. sadly missed Crying or Very sad 1945-2003
Redoko
PostPosted: 12:22 - 06 Dec 2011    Post subject: Reply with quote
Sure you're not just revving too high?
Torx
PostPosted: 12:35 - 06 Dec 2011    Post subject: Reply with quote
Never thought about wheel weights. I thought they put the weights on the inside on tubeless rims?
dansidi
PostPosted: 17:50 - 06 Dec 2011    Post subject: Reply with quote
I had the same problem. Turns out it was just me shivering in the freezing cold morning air. Rolling Eyes
current bike to first bike: SV650s K3, YBR125, Vespa GT125, Vespa ET4-125, Suzuki CS-50 (!!)
Mod 1 passed 02-11-2012
Mod 2 passed 05-12-2-12
simon75
PostPosted: 20:49 - 09 Dec 2011    Post subject: Reply with quote
Thanks for the advice guys. I have checked the revs and they are fine. It does vibrate like mad at about 30mph. Il get the wheels checked for balancing as the mechanic said there are no loose nuts/bolts etc. Il report back. Very Happy
simon75
PostPosted: 12:57 - 10 Dec 2011    Post subject: Reply with quote
It was the balancing! Thanks for all the advice Very Happy
Frost
PostPosted: 13:33 - 10 Dec 2011    Post subject: Reply with quote
The wheel and tyre needs balancing together, so the weights would have to go on the outside.
richie....
PostPosted: 12:07 - 30 Dec 2011    Post subject: Reply with quote
daft question, but where would i get wheels balanced? my bike vibrates like hell and want to rule this out...
The last post was made 14 years, 266 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.25 - MySQL Queries: 13 - Page Size: 67.62 Kb
