FZR 600 cylinder 4 not firing? :S [Problem solved!]
Rncv
PostPosted: 19:08 - 05 Dec 2011    Post subject: FZR 600 cylinder 4 not firing? :S [Problem solved!] Reply with quote
Hi all,
Recently i picked up my first big bike a fzr600.
I was told it was running perfectly, but when i got there turns out its only firing on 3/4 cylinders.
I have taken the fairings and tank off, and know its the 4th cylinder thats not firing.
Ive taken the plug out and check the spark against the head and it seems the ht lead/plug works okay.
Iv'e changed the plug from 3 to 4 and still it doesn't fire.
The problem is it fires sometimes as it gets warm (not hot)
Anyone have any ideas? could it be the coil pack even if the spark sparks?
im at a lost end :S
all help is appreciated thanks!
Edit: Blocked pilot jet on the 4th carb.
Current: 01' Bandit 600, 92' Goose 350
Previous: Lots!
Frost
PostPosted: 19:34 - 05 Dec 2011    Post subject: Reply with quote
A spark isn't just a spark. Under compression it can weaken the spark to the point where it won't be strong enough. Swapping the coils over should eliminate them as the fault. It could also be the plug cap, so try swapping those over and see if the problem follows it.
Have you tried turning the engine over with the plug out to make sure the cylinder isn't full of fuel or oil?
Spitting on the exhaust headers will show you how hot things are.
It might be a carb issue, at very least i'd drain them and check the float hights. There's a little screw on the under side of the float bowl for draining them and checking the fuel level.
https://www.bbburma.net/FujiFotos/FloatHeight/DSCF2434.jpg
Other possibilities are:
Blocked jet
Choke problem
Carb not seated properly
Carb sync
Timing
Compression
Those last 2 are the sods to fix so it's best to try everything else first.
Rncv
PostPosted: 19:44 - 05 Dec 2011    Post subject: Reply with quote
what coils can i switch over? can i swap 1 with 4? does it make a difference with the timing?
i have ran the engine over with the plug out and all is clean.
can i check the float hight without taking the carb apart?
the carb intake is cracked, but taped up until the new set arrives.
will check over the things either tomorrow or friday.
Previous: Lots!
Formerly known as
P.
PostPosted: 20:04 - 05 Dec 2011    Post subject: Reply with quote
Could be a plug fault. Swap plug 3 and 4, use spit or a water bottle to see which pipes are getting hot.
A taped up intake could still let air in. But better than being open.
You have to take the carbs apart to check float height.
weasley
PostPosted: 20:12 - 05 Dec 2011    Post subject: Reply with quote
I had this EXACT fault on my Thundercat; it was a duff plug cap. You can take them off the HT lead by simply unscrewing them and they can be tested with a multimeter. I replaced it and have had no problems since.
Rncv
i have swapped the plugs over and no luck.
i like to burn myself so i touched them haha Thumbs Up
Previous: Lots!
Frost
PostPosted: 20:50 - 05 Dec 2011    Post subject: Reply with quote
Float height is checked using that picture i posted. You put on a bit of hose, bend it up and undo the drain screw. The fuel then rises up in the pipe to the same level it is in the bowl.
You will probably have 2 banks of 2 coils. swap the way they are wired up, then move the plug leads around to match, labelling them would be a good idea!
jjdugen
PostPosted: 22:08 - 05 Dec 2011    Post subject: Reply with quote
I rebuilt an FZR this time last year. Had exactly this problem. Checked and double checked the lot. Turned out to be the rubber gasket that seals the 'emulsion tube block'. I'll explain.
Take off the float bowl on no. 4 carb. You will see the main and pilot jet holder. This is held in place by a nut. Undo this and take the block out. You can poke through the jet holders while you are there. You will see a black rubber type sealing gasket in the block. Check it for tears or pinches and make sure it hasn't become flat or hard. If it has, a QUICK dip in thinners and an immediate wash in soapy water will fatten it up again.
No.4 carb is the one that empties and drys when the bike is on the sidestand for any length of time and is the one that usually gives the most trouble.
Rncv
PostPosted: 08:46 - 12 Dec 2011    Post subject: Reply with quote
UPDATE]
Taken the carbs off and cleaned them all.
Intake rubber for cylinder 4 is split all the way around, Have a new set waiting.
Will assemble the bike today as yesterday I forgot my keys and couldn't get the seat off DOH!
Will update you again asap.
Previous: Lots!
bwprice100
PostPosted: 12:11 - 12 Dec 2011    Post subject: Reply with quote
Check the 3 basics.
Spark
Fuel
Compression
Are they happening and at the right time, if so should run.
Brian
www.eBolt.co.uk www.ToolRoomChucks.co.uk
My bikes 1956 BMW R26 250cc, !981 BMW R80 (was a TIC ex plod), 1994 R100RT, sold my 1981 Yam XS 250
jjdugen
PostPosted: 13:38 - 12 Dec 2011    Post subject: Reply with quote
bwprice100. And just how many 20 year old bikes have you tried bringing back to life?
bwprice100
PostPosted: 14:03 - 12 Dec 2011    Post subject: Reply with quote
Blown up and brought back to life many Smile
The best blow up was my old plastic maggot but that was a while ago Smile
Brian
Rncv
PostPosted: 14:47 - 12 Dec 2011    Post subject: Reply with quote
bwprice100 wrote:
Check the 3 basics.
Spark
Fuel
Compression
Brian
Yeah it has all of them Thumbs Up
trying to find out what's wrong, could be a coil pack on the way out although it sparks against the engine casing.
Main and idle jet are clear. And its getting fuel.
Unable to do a compression test as i have nothing to do it with.
Previous: Lots!
bwprice100
PostPosted: 14:56 - 12 Dec 2011    Post subject: Reply with quote
Unable to do a compression test as I have nothing to do it with.
The danger is that you could spend a lot of time and money and possibly find the compression bad on that cylinder.
it may not be the compression but as the bike is a bit of an unknown its best to check the fundamentals first.
Brian
Rncv
PostPosted: 15:23 - 12 Dec 2011    Post subject: Reply with quote
Brian
will pick one up for £20 and do a test at the weekend.
Previous: Lots!
PostPosted: 15:40 - 12 Dec 2011    Post subject: Reply with quote
Coil would likely affect 2 cylinders, although the HT lead, cap and plug would only affect one.
Fueling could affect it on one cylinder easily. However I would be inclined to believe it would normally work at either decent revs / load or at idle (as they are very different fuel circuits) if the float bowl has sufficient fuel.
I would suggest checking the valve clearances on that cylinder. Clearances on the tight side (which is what normally results from wear on shimmed valve engines) will result in low compression, and might well get worse as the engine warms up (ie, the steel valves expands more than the surrounding alloy head).
Rncv
PostPosted: 15:01 - 29 Dec 2011    Post subject: Reply with quote
Update for you all;
i took the carbs off again to clean them. I was messing around and i had a can of carb cleaner and was spraying around to see what is unblocked/blocked and noticed when i spray carb cleaner down the idle jet it sprays out of what seems to be the pilot air jet. its blocked for the 4th carb but not any others...
my question is;
would this cause the 4th cylinder not to fire? and how do I unblock it?
many thanks.
Previous: Lots!
Formerly known as
P.
PostPosted: 15:04 - 29 Dec 2011    Post subject: Reply with quote
Get some thin needle usually found in the mothers sewing box and poke them through.
Leave them to soak in petrol or brake cleaner and blow them out again Thumbs Up
Rncv
PostPosted: 15:15 - 29 Dec 2011    Post subject: Reply with quote
can you remove them the same as the idle/main jets?
Previous: Lots!
PostPosted: 11:43 - 30 Dec 2011    Post subject: Reply with quote
Not sure from the top of my head on removing them on the FZR, but probably.
Be careful with poking anything down the jets. They are accurately made to tight tolerances and easily damaged. If you do need to do so then try and use something made from a softer metal than the jets so it can't easily damage them (ie, maybe some copper wire)
Rncv
PostPosted: 17:59 - 30 Dec 2011    Post subject: Reply with quote
Advice taken, will get up to my uncles and have a poke around thanks! Thumbs Up
Previous: Lots!
The last post was made 14 years, 73 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 116.65 Kb
