| Rncv |
 Rncv Nitrous Nuisance
| Frost |
 Frost World Chat Champion
 Posted: 19:34 - 05 Dec 2011 Post subject: |
A spark isn't just a spark. Under compression it can weaken the spark to the point where it won't be strong enough. Swapping the coils over should eliminate them as the fault. It could also be the plug cap, so try swapping those over and see if the problem follows it.
Have you tried turning the engine over with the plug out to make sure the cylinder isn't full of fuel or oil?
Spitting on the exhaust headers will show you how hot things are.
It might be a carb issue, at very least i'd drain them and check the float hights. There's a little screw on the under side of the float bowl for draining them and checking the fuel level.
https://www.bbburma.net/FujiFotos/FloatHeight/DSCF2434.jpg
Other possibilities are:
Blocked jet
Choke problem
Carb not seated properly
Carb sync
Timing
Compression
Those last 2 are the sods to fix so it's best to try everything else first. |
| Rncv |
| P.addy |
 P.addy Formerly known as P.
| weasley |
 weasley World Chat Champion
| Rncv |
| Frost |
| jjdugen |
 jjdugen World Chat Champion
| Rncv |
| bwprice100 |
 bwprice100 Borekit Bruiser
 Posted: 12:11 - 12 Dec 2011 Post subject: |
Check the 3 basics.
Spark
Fuel
Compression
Are they happening and at the right time, if so should run.
Brian ____________________ www.eBolt.co.uk www.ToolRoomChucks.co.uk
My bikes 1956 BMW R26 250cc, !981 BMW R80 (was a TIC ex plod), 1994 R100RT, sold my 1981 Yam XS 250 |
| jjdugen |
| bwprice100 |
| Rncv |
| bwprice100 |
| Rncv |
 Posted: 15:40 - 12 Dec 2011 Post subject: |
Coil would likely affect 2 cylinders, although the HT lead, cap and plug would only affect one.
Fueling could affect it on one cylinder easily. However I would be inclined to believe it would normally work at either decent revs / load or at idle (as they are very different fuel circuits) if the float bowl has sufficient fuel.
I would suggest checking the valve clearances on that cylinder. Clearances on the tight side (which is what normally results from wear on shimmed valve engines) will result in low compression, and might well get worse as the engine warms up (ie, the steel valves expands more than the surrounding alloy head).
| Rncv |
| P.addy |
 Posted: 15:04 - 29 Dec 2011 Post subject: |
Get some thin needle usually found in the mothers sewing box and poke them through.
Leave them to soak in petrol or brake cleaner and blow them out again  |
| Rncv |
| Rncv |
The last post was made 14 years, 74 days ago. Instead of replying here, would creating a new thread be more useful? |
