Oil level window looked steamed up
Mrjoolz
PostPosted: 17:55 - 07 Dec 2011    Post subject: Oil level window looked steamed up Reply with quote
Got on bike to leave for work this morning, and oil level window on side of crank case looked all steamed up. I was worried that water had contaminated the oil, however after a 30 min ride, I pulled over and it seemed to have disappeared.
Is it anything to worry about. Could it be slight water contamination or is it just condensation as its turned very cold.
Previous Bikes: TZR125, KMX125, RGV250, RD350YPVS, GXSR750H, GSXR600SRAD, R1 (2000), GSXR1000 (K1), ZZR600, CBR1100XX Super Blackbird
Current Bike: Suzuki GSX1300R Hyabusa.....
PostPosted: 17:57 - 07 Dec 2011    Post subject: Reply with quote
Condensation, no worries. Thumbs Up
Mrjoolz
PostPosted: 18:03 - 07 Dec 2011    Post subject: Reply with quote
Excellent I was worried. Especially, as I've just fitted £300 worth of Wavey discs and sintered pads to her. Thought if the engine, was on way out, it would have been a waste. :o(
but Thumbs Up Thumbs Up thanks for the reassurance.
Smile
yen_powell
PostPosted: 21:38 - 07 Dec 2011    Post subject: Reply with quote
The gremlins were having a shower.
Lots of short rides can do that sometimes.
XT1200Z and a DR350 in bits
Walloper
PostPosted: 21:46 - 07 Dec 2011    Post subject: Reply with quote
Have you maybe dropped a Power Band into the sump?
Or probably condensation due to local ambient conditions.
Excessive Pootle-ing causes massive condensation attacks FYI.... Razz
PostPosted: 22:40 - 07 Dec 2011    Post subject: Reply with quote
If there is no white smoke from exhausts and loss of coolant then it's probably condensation.
Next time you come back from a ride leave the oil filler cap off for a few hours. The sight glass will clear.
I have a couple of short journeys to do each week, 5 miles each way isn't long enough to completely warm the engine through so on return i wipe the cap and rest it on the ignition so i can't start it up with the cap off.
Walloper
PostPosted: 23:24 - 07 Dec 2011    Post subject: Reply with quote
Make sure the breather is clean.
There should be no real need to phaph with the filler cap.
The engine should vent through the breather.
PostPosted: 00:14 - 08 Dec 2011    Post subject: Reply with quote
^^^Agreed and my breather pipe does drip the occasional drop yet the window stays misted until either it gets a long run or i allow the moisture to vent via the filler. Maybe the routing of some breather pipes doesn't make this as efficient as others.
Mrjoolz
PostPosted: 10:19 - 08 Dec 2011    Post subject: Reply with quote
After my run into work it looked OK. I think it was probably cos the journey I did the night before I noticed it, was only about 3 miles.
Thanks for the info though Thumbs Up Thumbs Up
The last post was made 14 years, 306 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.03 - MySQL Queries: 13 - Page Size: 60.82 Kb
