Honda NSR 125 rear shock replacement
meatloaf
PostPosted: 20:31 - 07 Dec 2011    Post subject: Honda NSR 125 rear shock replacement Reply with quote
Hi my nsr recently failed its MOT, mainly due to the rear shock needing to be replaced. it's from 1997 and after looking round a bit on the internet i found this and wondered if it would fit my bike?
https://www.patternparts.net/p-Honda_NSR_125_Shock_Absorber_%28Mono%29_FN_92_93-28313.aspx
mr jamez
PostPosted: 21:39 - 07 Dec 2011    Post subject: Reply with quote
That states it is for a 92/93 FN. So I presume that means the unfaired model. I owned a FL which was made in 1990 and know first hand that the shocks are not a simple swap, the eyelet on the top was different and the suspension linkages are not the same.
However by 1992/1993 this may have changed as the FL seemed to have quite a few unique parts. You need to get the dimensions of the shock that is advertised.
It is always worth giving david silver spares a call if you need honda parts.
alains
PostPosted: 11:01 - 08 Dec 2011    Post subject: Reply with quote
knowing that english people (sorry) are not very often precise on the year of their bikes , look serial number . if it begins by HI-xxxx year is 1989-1992 and by ZDCJC22 it's 1993-2001 (foxeye)
faired or unfaired doesnt change anything but the 2 models cannot be exchange
here is a pict of a foxeye , you can see the adjustable spring compression
c_dug
PostPosted: 12:32 - 08 Dec 2011    Post subject: Reply with quote
alains you must have some sort of 6th sense for NSR questions! You pop out of nowhere the second those three letters are mentioned Laughing
meatloaf
PostPosted: 20:45 - 08 Dec 2011    Post subject: Reply with quote
it's a 1997 foxeye model. on the website it says the part is for 92-93, does this mean it won't fit then?
alains
PostPosted: 12:51 - 09 Dec 2011    Post subject: Reply with quote
look or not look isnt the question , read what i wrote : the 2 models are not exchangeable !
alains
PostPosted: 13:35 - 09 Dec 2011    Post subject: Reply with quote
to be sure only the length (between the fixing axis) which the point , because JC20 use 17" wheels and JC22 use 18"
The last post was made 14 years, 281 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.55 - MySQL Queries: 13 - Page Size: 70.88 Kb
