| EazyDuz |
 EazyDuz World Chat Champion
 Posted: 19:35 - 07 Dec 2011 Post subject: How to remove downpipe bolts? |
As on my bike the heads on them are rounded so you cant grip them
https://www.cmsnl.com/suzuki-gz125-1999-x_model13795/partslist/FIG11.html
On the engine side. Just need to know as i might be replacing the exhaust soon but on some GZ125's its one unit rather than a seperate muffler and downpipe.
Thanks ____________________ To shreds you say? Tss tss tss |
| pepperami |
 pepperami Super Spammer
 Posted: 20:03 - 07 Dec 2011 Post subject: |
WTF is that link?
As for removing rounded off exhaust bolts.
I had a similar issue and had to resort to cutting a new slot into the top with a Dremel, then soaking the area with diesel for a week, before using a well fitting large flat bit onto a socket (for leverage) to turn it.
luckily for me the stud let go, but because of the consant heat exhaust studs are exposed to, thier meturaligy changes and they can become brittle.
So I would suggest that using an impact driver is your very last resort. ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
| EazyDuz |
| ZebraDriver |
 ZebraDriver Scooby Slapper
| EazyDuz |
| pepperami |
| Noxious89123 |
| 0l0dom0l0 |
 0l0dom0l0 World Chat Champion
 Posted: 23:10 - 07 Dec 2011 Post subject: |
| Noxious89123 wrote: | Take the head off, take it to a engineering place and get them to drill out the stud and rethread the hole? |
You'd be very lucky if you managed to keep the thread.
I had a rocker cover bolt sheared in the head of a crf 450 I was given the joyful task of drilling. It was easy to get the drill square etc but just was impossible to actually keep the drill square with the shite surface where the bolt had snapped.
I probably could have put it on a mill with a 6mm bit, and squared off the top, then drilled a pilot hole, drilled the 5mm hole and re tapped it to an M6 if I'd really wanted to.
In the end I just ended up drilling it out at 6mm as it was the only drill that would stay square and fitted a helicoil.
I can't imagine the hassle it would be trying to tackle exhaust studs that. Something I'd really rather not face if possible and if it did happen it would almost certainly be cheaper to buy a new head on a bike like this.
Anyways back to the op, you just need to see what the bolt needs and hope and pray they come off or out. If they do snap, then fingers crossed you do get left with some of the bolt some you can get a stud extractor on them (which do work well). Post a pic maybe? ____________________ CBT Passed: 30/08/2009, Theory Passed: 31/08/2010, Mod 1 Passed: 6/9/2010, Mod 2 Passed: 13/09/2010. Restriction ended 13/09/2012.
Bikes: 2007 Derbi GPR 50, 1998 Yamaha Fazer 600 (written off), 2002 Yamaha Fazer 600, 1994 CBR 600F, 2003 Triumph Daytona 600, Kawasaki ZX6R J1.....Current: 2006 Yamaha FZ6, 1998 Suzuki TL1000R and a Honda VFR 400 NC30. |
| Bezzer |
 Bezzer World Chat Champion
| Vincent |
 Vincent Banned
| Johnser |
 Johnser Renault 5 Driver
 Posted: 13:56 - 08 Dec 2011 Post subject: |
| EazyDuz wrote: | what would happen if the head snapped off flush so you cant grip the thread to remove it? |
The above replies can work but in my opinion by far the easiest, cheapest and safest (in terms of chances of keeping the threads intact) for the home mechanic is with a welder.
weld onto the sheared face of the stud with a high heat, keep blobbing onto the stud until you build up the protrusion. I generally keep blobbing on until I have made a "T" shaped bit that you can then grab with a pair of mole grips.
Twist the stud out carefully. Lots of penetrating oil (in between weld blobs if you like - it cools and contracts the stud as well helping to loosen) work it out back and forth carefully. If you feel it "give" a little and just go to wind it all the way out, chances are it'll grip and you'll shear it off again. once welded, the metal of the stud is significantly more prone to shearing. no worries if it does though... just try again!
You might be worried you'll weld the head to the stud. its actually surprisingly difficult to do this as generally heads are ali and studs steel. easy to tell if you do slip and attache the two though - you can see the glowing red hot stud loose its heat (colour) much faster as the heat conducts through the head.
I have had 100% success rate with this method; bike heads, car heads, brake calipers, brake bleed nipples, rusted car wing bolts, sheared tractor wheel studs.....e.t.c usually takes less than 10mins
Oh, and if you're doing a head be sure not to let any weld detritus into the engine! |
| D O G |
 D O G World Chat Champion
| Vincent |
 Vincent Banned
| Johnser |
The last post was made 14 years, 302 days ago. Instead of replying here, would creating a new thread be more useful? |
