Oil Error
blindasabat
PostPosted: 20:03 - 10 Dec 2011    Post subject: Oil Error Reply with quote
I did an oil change on my bike, new filter etc just putting it to bed for a couple of months Cool now I bought Motul 5100 10w 40w (ester) 4T technosynthese oil and stuck a litre in proceeded to put the other litre in when I got to around 400ml I realised it was motul 300v factory line double ester 10w 40w 4T 100% synthese racing oil..
just nervous that this will feck things up or is it ok to mix Question I have not started the engine so can I just empty it out and put another new filter on, or is it safe to leave it in. any help would be much appreciated Thumbs Up
PostPosted: 20:08 - 10 Dec 2011    Post subject: Reply with quote
Personally don't like mixing oils, but that's a personal thing. Is the first one you've put in fully synth as well?
If so then leave it, if it's a semi synthetic, or mineral oil I'd definately drain and refill.
Dazbo666
PostPosted: 20:16 - 10 Dec 2011    Post subject: Reply with quote
If both oils are synthetic or semi-synth, personally I'd leave it as it is...
but if one of them is labelled as mineral oil I'd drain and refill
I'm no technical guru, but I've read that mineral and synth doesn't mix well?? Confused
Word of the day : DILLIGAF
temeluchus
PostPosted: 20:17 - 10 Dec 2011    Post subject: Reply with quote
you will be fine. the only real problem is when you try and mix castor oil with petroleum based oils.
blindasabat
PostPosted: 20:20 - 10 Dec 2011    Post subject: Reply with quote
no it is semi.. if I change the oil will the filter need changing as well..I havent started the bike yet so no problem just costing me
kestrel
PostPosted: 20:24 - 10 Dec 2011    Post subject: Re: Oil Error Reply with quote
It is ok to mix Motul 300v Factory Line 10W40 with other oils, both synthetic and mineral. See specification sheet here:-
https://www.motul.com/system/product_descriptions/technical_data_sheets/10/300V%204T%20Factory%20Line%2010W40_GB.pdf?1290086770
Isle of Man.........Road Racing Capital Of The World
PostPosted: 20:28 - 10 Dec 2011    Post subject: Reply with quote
Job jobbed. Thumbs Up
Noxious89123
PostPosted: 22:29 - 10 Dec 2011    Post subject: Reply with quote
Semi synthetic oils are a mix of synthetic and mineral, so mixing in some other either other type won't do any harm. Diluting expensive synthetic oil with mineral would be kinda silly though.
blindasabat
PostPosted: 00:09 - 11 Dec 2011    Post subject: Reply with quote
So if I was being a bit pernickity and decided to change the oil ..will I have to change the filter and would I have to start up the bike before hand or would you just drain the oil ... Rolling Eyes
PostPosted: 01:14 - 11 Dec 2011    Post subject: Reply with quote
Even if you were thinking about replacing it. If you're laying the bike up, leave what's in, in and change it in the spring.
The last post was made 14 years, 276 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 66.07 Kb
