Cagiva Mito 125 with 98 octane fuel..
Bike_craze1
PostPosted: 13:27 - 13 Dec 2011    Post subject: Cagiva Mito 125 with 98 octane fuel.. Reply with quote
Thinking of trying 98 octane fuel out in the Mito, is it worth it? any up/downsides?
Yamaha R125 - Cagiva Mito 125 - Honda CBR 600
CBT passed: 22/07/08 Bike Theory passed: 28/03/09
Bike Test passed: 15/04/09
Bike_craze1
PostPosted: 13:37 - 13 Dec 2011    Post subject: Reply with quote
Its just a full powervalve Mito with an arrow exhaust.. sure I read in the book 98 octane minimum. cheers pal.
supZ
PostPosted: 13:38 - 13 Dec 2011    Post subject: Reply with quote
pro - err
con - costs more
waste of time running any car/bike on super/optimax etc.. unless its actually tuned to run on it. some people say 'oh it runs better' etc.. but its mostly just in their head.
on a modern car/bike the ecu adjusts to counter any change so its just a waste of money. on an old one you wont see any benefits unless you tune it to match.
on the flip side if it is tuned for 98 then thats what you should use.
my mate does this. always puts super in his bike. i've only ever put normal and the difference? his pocket is emptier than mine.
CBR954RR - Daily toy
CBR600RR - Trackbike
EXC-Rider
PostPosted: 13:43 - 13 Dec 2011    Post subject: Reply with quote
i asked the same question maybe just fill the tank once a mouth with the high octane will keep the engine clean (or what ever) but no point just using it all the time only thing you will notice is a hole in your wallet.
owned bikes: DR50, Thumpsta 110 , Honda CR85, Speedfight 100, Yamaha XT125X, Honda CRF450, Honda Hornet '07
current bikes: KTM EXC525 AKA the wheelie machine
A friend in need is a friend indeed but a friend with weed is better!
PostPosted: 13:51 - 13 Dec 2011    Post subject: Reply with quote
Cagiva specify 98-100 octane fuel anyway. So using normal unleaded puts you at a risk of holing a piston.
Higher octane fuel alone will not give you any more power.
This might give you a bit more info:-
https://www.bikechatforums.com/viewtopic.php?p=2921369
pits
PostPosted: 14:06 - 13 Dec 2011    Post subject: Reply with quote
supZ wrote:
pro - err
con - costs more
Actually carbbed will make a slight difference, it is fuel injection that wont care unless it is mapped to run on it, but the difference is not something you would actually notice on a bike.
However if your vehicle is designed to run on it and you have been running cheaper stuff with lower octance, chancing a hole in the piston or power being turned down (per se) by the ECU due to increased knock.
I always run my bikes on Vpower, but my bikes have always been set up on a dyno and tuned to run on Vpower, also it means I earn double points as I am in the Vpower club Embarassed Embarassed
PostPosted: 14:13 - 13 Dec 2011    Post subject: Reply with quote
Carbed engine by default likely has nothing to take any advantage of higher octane fuel so won't gain anything.
To take any advantage of it you need a knock sensor. While there is nothing to prevent the ignition system on a vehicle with carbs from having a knock sensor it is pretty unlikely. With a fuel injected engine it probably has the ignition and injection integrated in a rather more sophisticated unit with more chance of a knock sensor being used (but still very rare on bikes).
Only exception to this would be the cleaning additives, with a fuel injected engine with a lambda probe being able to compensate for wear / slightly blocked injectors while a carbed engine can't do this. But those cleaning additives are independent of the octane rating of the fuel.
PostPosted: 14:37 - 13 Dec 2011    Post subject: Reply with quote
Why? Using what mechanism?
pits
PostPosted: 14:51 - 13 Dec 2011    Post subject: Reply with quote
The Rotary Splint, duh, I thought everyone knew that Rolling Eyes Rolling Eyes Rolling Eyes Mr. Green Mr. Green Thumbs Up Thumbs Up
To be honest I haven't mucked about with carbs in ages, but I know my old VW wouldn't run on certain lower grade fuels, and would hit a whopping 85mph on the speedo as opposed to the 78ish when on regular, but then again that engine did have similar MPG in fuel and oil Thinking Thinking
The last post was made 14 years, 298 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 70.21 Kb
