Ktm 125exc possible water in engine >.>
Supermotard37...
PostPosted: 15:55 - 13 Dec 2011    Post subject: Ktm 125exc possible water in engine >.> Reply with quote
So after going out on a ride sunday and getting bogging i decided to wash the ktm when i got back and since today its been sitting in the garage...
I took the bike out for a spin and all of a sudden it starts bogging and spluttering when accelerating,so i thought wtf and managed to ride the bike home....
Since then ive....
.Cleaned air filter
.Cleaned the carb out twice
.Checked the plug looks all good
.Sprayed all the leads and ht lead with (WD40)
.Cussed alot and smoked all my fags Mad
Im really confused it ticks over fine dosent smoke revs freely, pulls fine untill its ready to hit the power band and then it bogs,splutters and if i kept the throttle open whilst it was spluttering it would just start dying its really got me stumped
Any ideas would be appreciated
Thanks
Scott Thumbs Up
Fuck off..!! "You absolute contraception malfunction"
at106
PostPosted: 16:12 - 13 Dec 2011    Post subject: Reply with quote
To me it sounds like a fuel supply problem, but as you've cleaned the carb it shouldnt be that. Is there a fuel filter, and is the fuel cap vent hole clear?
Supermotard37...
PostPosted: 16:16 - 13 Dec 2011    Post subject: Reply with quote
@ at106 cheers for the quick reply but i dont think its a fueling problem but its worth checking i geuss its got me really stumped i strip and clean this bike quite regularly to keep it in good order but i am really confused.
daemonoid
PostPosted: 18:02 - 13 Dec 2011    Post subject: Reply with quote
You don't sound like someone who'd fail to check the oil, but symptoms match...
current: ducati monster 750
Supermotard37...
PostPosted: 18:18 - 13 Dec 2011    Post subject: Reply with quote
i did and theres no water inside it its a complete mystery to me but i like a challange and im not determined to give up just yet Laughing
I just dont get it all the symptoms to me seem to be water in the engine where it shouldnt be ie pulled through the airbox though the carb and into the engine Thinking
daemonoid
PostPosted: 18:27 - 13 Dec 2011    Post subject: Reply with quote
I've had the same symptoms for a couple of causes - just recently my fiat did it due to low oil, my old fiesta for the same reason (but I usually stalled it before then). Previously my pulsar did it for about 30 mins before I ran out of fuel due to a misreading digital guage, glad I had reserve...
Let us know what it was in the end.
PostPosted: 18:51 - 13 Dec 2011    Post subject: Reply with quote
It doesn't sound like water in the engine to me. Water in the engine would be spat out rapidly, or just stop the engine turning over at all. Water in the fuel or carb is possible although I would expect it to screw up just off idle rather than once the revs were up plus you have cleaned the carb out already.
Water in the ignition is a possibility. Might be worth taking off the ignition cover from the engine and checking it is dry in there.
However to me the main guess would be the kill switch and ignition switch wiring. Presume it is a fairly crude ignition system and the kill switch works by earthing the coil. A dodgy contact in there can start to short out and earth the ignition. A quick check would be to disconnect the wiring that is used to earth the coil and then take it for a spin (stopping the engine afterwards is the fun bit).
Supermotard37...
PostPosted: 19:15 - 13 Dec 2011    Post subject: Reply with quote
yeah sure ile give that a bash but i doubt it will be the problem Neutral
Supermotard37...
PostPosted: 15:54 - 14 Dec 2011    Post subject: Reply with quote
Took it out for a ride today and its alot better im geussing there was water somwhere Rolling Eyes im gonna get a new spark plug and that will sort it out because its spluttering abit now and i need a new plug anyway cheers for your help lads ile let you know how it goes with the new plug Thumbs Up Karma
The last post was made 14 years, 270 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 64.72 Kb
