potential clutch problems. need diagnosis
eddclarke
PostPosted: 07:16 - 08 Dec 2011    Post subject: potential clutch problems. need diagnosis Reply with quote
Hey,
I'm having a couple problems with my XR250. It stalls when setting off unless I give a huge amount of revs.
I put it up on the stand and started to fiddle around. The back wheel spins freely when it is in neutral but if I put it in gear and pull the clutch in then the wheel wont move (I can put a bit of effort in and it will move, but not freely).
At first I thought it could be that the clutch cable needed adjusting but even if I pull the 'arm' that sticks out of the clutch casing up as far as it goes, same problems.
Any ideas guys? I could really do with getting this sorted ready for the snow!
Ed
Honda XR125L 06 ----> Yamaha FZ6 05 + ex SAS XR250 --> VFR800 + XR250r
Walloper
PostPosted: 11:25 - 08 Dec 2011    Post subject: Reply with quote
Try adjusting the cable first.
Clutch is a fairly easy-ish job to do though.
Parts are maybe more of a headache as you really need to replace the whole lot.
Fizzer Thou
PostPosted: 18:37 - 13 Dec 2011    Post subject: Reply with quote
Have a look at the clutch basket pics on the 'Show & Tell' page where Waffles has put up pics of the worn surfaces in the post about the XR drinking too much oil.
https://www.bikechatforums.com/viewtopic.php?t=234319
This may or may not have been causing the difficulty with selecting neutral with all of the cable adjusters set up correctly.
Always have a 'Plan B'
The last post was made 14 years, 342 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.53 - MySQL Queries: 13 - Page Size: 35.9 Kb
