My xr has a drink problem....
waffles
PostPosted: 12:27 - 27 Nov 2011    Post subject: My xr has a drink problem.... Reply with quote
..... hes addicted to *sob* oil! He spends all of my money on bottles of the stuff and chugs it down like its going out of fashion.
Over the summer I stripped it down, replaced loads of bits and finally had a bike with bolts that matched and could be undone without the need for heavy machinery. It could be a bit of a bitch to start but doing the tappets eliminated most of the rattle and it would normally burst into life after a couple of kicks. However it would still need topping up with oil after every ride and the exhaust was smelling pretty funky to boot. At the back of my mind was the worry that I would get stuck in the arse-end of nowhere faced with a dead bike and the prospect of roping mates in to help me push back to civilisation.
This is how the xr looked after its makeover in the summer....
https://i141.photobucket.com/albums/r71/siany_album/Fixin%20the%20XR/CIMG2885.jpg
Compression test was the first task, according to the Haynes manual compression for my bike should be between 180 and 191 psi and the xr was producing somewhere around 80. So here we go again, stripped down and back in the workshop for some engine tinkering.
https://i141.photobucket.com/albums/r71/siany_album/Fixin%20the%20XR/CIMG2917-2.jpg
The first thing to check over was the carb as it may have been tinkered with by the previous owner, the bike is running too rich so checking the settings would have been the logical place to start. Subframe had to be lifted up, wiring free'd up, cable ties cut and bolts out. Sadly I rounded one of the bolts holding the subframe in place so it needed some "persuasion", I need to add some of those onto my shopping list.
https://i141.photobucket.com/albums/r71/siany_album/Fixin%20the%20XR/CIMG2918-2.jpg
Taking the carb apart revealed there was some grit in there but nothing that would suggest the fuelling was set up incorrectly. Arse, time to tackle the engine it is then! I took off the exhaust (this needs repacking anyway) and headers which were starting to discolour where they bolt onto the engine. Another sign that all is not well and its running too hot.
https://i141.photobucket.com/albums/r71/siany_album/Fixin%20the%20XR/CIMG2919-1.jpg
This looked familiar, I got a lesson in how 4 stroke engines work by cranking the engine over and watching what happened. After finding all of the bolts (there are loads by the way, some of them are craftily hidden) off came the top of the engine. The plan was to strip the engine down to check out the barrel and piston.
https://i141.photobucket.com/albums/r71/siany_album/Fixin%20the%20XR/CIMG2920-1.jpg
Camshaft, just to the right of it is the camchain tensioner. The Haynes made it look very easy to remove using a high tech piece of equipment - the Honda opened-up-paperclip. Half an hour of struggling, head scratching and cursing later the executive decision was to leave the f*****g thing in place and carry on removing bits of engine. Clutch cover off with some difficulty as bolts were stuck and the gasket had welded everything together.
https://i141.photobucket.com/albums/r71/siany_album/Fixin%20the%20XR/CIMG2921.jpg
Im going to work on the clutch later as the bike has issues going from 1st to neutral when the bike is running.
https://i141.photobucket.com/albums/r71/siany_album/Fixin%20the%20XR/CIMG2922.jpg
By this point it was getting on a bit but may as well keep going and delve deeper. I pulled out the oil filter at the bottom of the engine and checked it over. Looked in good nick to me so I gave it a quick shake off and replaced. Time to go for broke and get to the piston. As the bolts came out they appeared to have baked on oil over them and they smelt like burnt chips. (As modelled by my assistant!)
https://i141.photobucket.com/albums/r71/siany_album/Fixin%20the%20XR/CIMG2924.jpg
https://i141.photobucket.com/albums/r71/siany_album/Fixin%20the%20XR/CIMG2925.jpg
Viola, it looks terrible! The smell was awful and there were chunks of oil sitting ontop of the piston. Turning the engine over so that the piston dropped back down revealed something interesting.
https://i141.photobucket.com/albums/r71/siany_album/Fixin%20the%20XR/CIMG2926.jpg
Around the side of the barrel is heavy corrosion and some pitting, pretty sure the engine has been drowned in a puddle at some point. Hopefully this is the cause of the poor compression and shitty oil comsumption!
The to-do list now stands at:
New subframe bolts
Rebore
Oversized piston
New gasket set
Inspect clutch plates
Repack exhaust
Stop fiddling with my bikes!
mrtEE
PostPosted: 12:52 - 27 Nov 2011    Post subject: Reply with quote
Time for a 280 kit?
Quote Me Happy
PostPosted: 12:55 - 27 Nov 2011    Post subject: Reply with quote
My XR400 needed a rebuild after ploughing in to a deep (much deeper than I thought Laughing ) muddy puddle and me flying over the handlebars.
Good luck with it Thumbs Up
waffles
PostPosted: 13:02 - 27 Nov 2011    Post subject: Reply with quote
mrtEE wrote:
Time for a 280 kit?
Quite possibly Twisted Evil
Joe - good luck with yours!
ajbsmirnoff
PostPosted: 15:01 - 27 Nov 2011    Post subject: Reply with quote
There's something ever so pornographic about those photos of the engine disassembly. Probably just me.
salty21
PostPosted: 18:54 - 27 Nov 2011    Post subject: Reply with quote
your not alone, i love seeing an engine in bits Laughing
CHR15
Turbo nutter bastard
PostPosted: 18:57 - 27 Nov 2011    Post subject: Reply with quote
y'all need to go and jiz in my thread Wink
i love how you can just tilt the subframe up to get at the carb, wish you could do that on mine!
Teflon-Mike
tl;dr
PostPosted: 20:03 - 27 Nov 2011    Post subject: Reply with quote
Yours has a carb?
I would have though it would have had a bit of gas main plumbing, a domestic isolator tap for a throttle and a fire hydrant valve for a mixture screw!
ajbsmirnoff
PostPosted: 20:30 - 27 Nov 2011    Post subject: Reply with quote
Your thread nearly made me go blind. But the increased muscle definition on my right arm was a nice bonus.
salty21
PostPosted: 21:32 - 27 Nov 2011    Post subject: Reply with quote
I'm looking forward to the rebuild Thumbs Up
Fizzer Thou
PostPosted: 22:36 - 27 Nov 2011    Post subject: Reply with quote
https://i666.photobucket.com/albums/vv23/WiNot_Rhencullen/Picture230.jpg
See also https://www.bikechatforums.com/viewtopic.php?t=222728
Nice workshop.
Always have a 'Plan B'
waffles
PostPosted: 18:57 - 30 Nov 2011    Post subject: Reply with quote
More bits fell off the bike today
This is the corrosion inside the barrel as a result of a dunking in some water.
I whipped the clutch basket off to get to the bottom of the camchain tensioner, more of that later. Off came the barrel with some careful thumping with a hammer and some wiggling of different engine bits. With a final tug the piston and barrel parted company and I could finally see the extent of the corrosion inside. Its fairly deep but will come out with a rebore. Go up 0.5mm or 1mm is my biggest decision. The fact that I can't seem to source a 1mm oversize piston unless I import from the states is a bit of a PITA. I'll keep looking!
https://i141.photobucket.com/albums/r71/siany_album/Fixin%20the%20XR/CIMG2930.jpg
Gratuitous engine porn, its got no clothes on!
https://i141.photobucket.com/albums/r71/siany_album/Fixin%20the%20XR/CIMG2931.jpg
Here is the clutch basket, horribly discoloured on the outside and didn't fare much better on the inside.
https://i141.photobucket.com/albums/r71/siany_album/Fixin%20the%20XR/CIMG2932-1.jpg
https://i141.photobucket.com/albums/r71/siany_album/Fixin%20the%20XR/CIMG2933-1.jpg
Closeup showing pitting and wear marks. This will be buffed/polished out later and I wobn't bother replacing it. Its had a hard life but everything is well within limits according to the Haynes.
https://i141.photobucket.com/albums/r71/siany_album/Fixin%20the%20XR/CIMG2934.jpg
https://i141.photobucket.com/albums/r71/siany_album/Fixin%20the%20XR/CIMG2935.jpg
https://i141.photobucket.com/albums/r71/siany_album/Fixin%20the%20XR/CIMG2936.jpg
I have my shopping list, off to hammer the credit card into submission!
Tim..
PostPosted: 19:25 - 30 Nov 2011    Post subject: Reply with quote
Be a good time for some new stem seals and lap the valves in Thumbs Up
www.marshallracing.co.uk
Frost
PostPosted: 20:56 - 30 Nov 2011    Post subject: Reply with quote
Give it a new cam chain too.
nightshaddow
PostPosted: 17:06 - 01 Dec 2011    Post subject: Reply with quote
good test for the valves are to put the plug back in turn it upside down and fill with fuel, if the fuel drips through valve seats need redoing if it dont they should be fine Smile
agreed as its apart wont hurt any
waffles
PostPosted: 20:35 - 01 Dec 2011    Post subject: Reply with quote
Added to The List Thumbs Up
Cam chain looks brand new, no wear on it at all but I will scrutinise it more closely once the clutch basket is cleaned up and ready to go back on.
Edit - think I may polish up the old piston and use it as a paperweight/missile at work.....
Tim..
PostPosted: 20:54 - 01 Dec 2011    Post subject: Reply with quote
You don't normally see wear on a cam chain, they just go.
It'll prob be fine to re-use, but why take the risk when you have it all so stripped apart.
waffles
PostPosted: 21:01 - 01 Dec 2011    Post subject: Reply with quote
Oh really? I assumed that you would see a gradual wearing out of them. They are pretty expensive though, if my budget will stretch I will consider it.
Cheers for the tip Thumbs Up
CHR15
PostPosted: 21:09 - 01 Dec 2011    Post subject: Reply with quote
ring tony at galea camchains 01268 735355 he'll do you a good price.
MaybeGuy
PostPosted: 21:17 - 01 Dec 2011    Post subject: Reply with quote
That isn't Ste's old XR250 by any chance is it? I seem to recall that being sat up with a top end full of water.
Fizzer Thou
PostPosted: 23:03 - 01 Dec 2011    Post subject: Reply with quote
Already factored in.They should come as part of the top-end gasket set.
The Assistant.
Fizzer Thou
PostPosted: 23:07 - 01 Dec 2011    Post subject: Reply with quote
This was discussed yesterday.We were going to do this test to see which valve seats might need more attention than the others.Valve guide seals are going to be replaced as a matter of course.
The Assistant
Fizzer Thou
PostPosted: 23:19 - 01 Dec 2011    Post subject: Reply with quote
On the Lings honda website they are £89 or so.
On the M&P website a similar camchain is a lot less
https://www.mandp.co.uk/productinfo.aspx?catref=514250&tier1url=Spares&tier2url=Camchains&tier3url=Economy
But having looked at the chain and the fact that the paperwork suggests that the bike has only done about 10,000km (8,200 miles?) I would not have thought that this needs replacing just yet.But then it is not my money being spent.
The Assistant
waffles
PostPosted: 13:28 - 02 Dec 2011    Post subject: Reply with quote
Last owner was called Adrian something or other
waffles
PostPosted: 23:36 - 10 Dec 2011    Post subject: Reply with quote
After a cruddy week at work it is again time to take out some aggression on an inanimate object, this time Mr Clutch Cover parted company with its gasket thanks to a razor blade. I gave it a bit of a clean up and it went into a bag ready to go back on once I have cleaned up the various clutch plates.
https://i141.photobucket.com/albums/r71/siany_album/Fixin%20the%20XR/CIMG2937.jpg
Ooh, shiny! Next up, the exhaust. I bought this from fleabay and it sounds pretty brutal. My bike became one of those antisocial wankers that I complain about. I could hear things rattling around in there! Time to bust out the drill and drill bits of various sizes. I read an article about how to do this in Ride, how hard could it be????
https://i141.photobucket.com/albums/r71/siany_album/Fixin%20the%20XR/CIMG2938.jpg
First few rivets came out with very little effort.
https://i141.photobucket.com/albums/r71/siany_album/Fixin%20the%20XR/CIMG2939.jpg
Two kept spinning round with the drill and they had to be chiselled off. The exhaust tip was stuck in place with silicone so I tapped all the way round with a hammer and chisel (gently!) and the end slid off finally. And with it came a small pile of carbon and the ends of the rivets.
https://i141.photobucket.com/albums/r71/siany_album/Fixin%20the%20XR/CIMG2940.jpg
Minging!
https://i141.photobucket.com/albums/r71/siany_album/Fixin%20the%20XR/CIMG2941.jpg
Apparently FMF pipes are ones that you have to dismantle at both ends before you can take the packing out. I didn't know this. Hence myself and Fizzer Thou spent 10 minutes with the molegrips trying to pull the middle section out of the exhaust..... Embarassed
https://i141.photobucket.com/albums/r71/siany_album/Fixin%20the%20XR/CIMG2942.jpg
Drilled out two of the rivets at the other end, had to chisel off the other four. With the link pipe bend in the way this became pretty difficult to get a good purchase on the tiny rivet. Eventually they decided to part company and the exhaust finally came apart. "How hard could it be????" Bloody difficult apparently!
https://i141.photobucket.com/albums/r71/siany_album/Fixin%20the%20XR/CIMG2945.jpg
https://i141.photobucket.com/albums/r71/siany_album/Fixin%20the%20XR/CIMG2946.jpg
Hold your noses, here comes the old packing!
https://i141.photobucket.com/albums/r71/siany_album/Fixin%20the%20XR/CIMG2947.jpg
I left that outside to think about what it had done. Part of it was solid carbon, it stank and there were little balls of carbon rolling around in it that had caused the rattling I mentioned previously. I gave everything a good scrub with a wire brush but had to leave repacking it for another day as I don't have any replacement rivets of the correct size to hand. Time to tackle the cylinder and cylinder head instead. During the week I picked up a replacement cylinder, piston, gudgeon pin etc etc from a member of a Honda forum. Putting my replacement piston and the OEM piston side by side it was clear that it wasn't an original one. I measured it up and I have managed to buy a .5mm oversize piston and rebored cylinder. Awesome! There is an uneven burn pattern on the dome of the piston though but im going to worry about that another day.
https://i141.photobucket.com/albums/r71/siany_album/Fixin%20the%20XR/CIMG2948.jpg
Some detective work later and the general consensus is that it is a Wiseco piston, here is a side by side comparison with an xr400 Wiseco.
https://i141.photobucket.com/albums/r71/siany_album/Fixin%20the%20XR/CIMG2949.jpg
But mine is definitely a higher compression piston, check out ma dome!
https://i141.photobucket.com/albums/r71/siany_album/Fixin%20the%20XR/CIMG2950.jpg
On to the cylinder head. First, screw the spark plug back in and pour white spirit in there to check for leaks.
https://i141.photobucket.com/albums/r71/siany_album/Fixin%20the%20XR/CIMG2951.jpg
Two valves were fine, no leaks at all. The other two showed small leaks. Time to pull the valves out then! Using a handy valve spring compression tool!
https://i141.photobucket.com/albums/r71/siany_album/Fixin%20the%20XR/CIMG2952.jpg
I have completely forgotten what the bits are called, but I pulled out the *thingys* that held the valve springs and seals in place, made me jump as they make a loud pop when they loosen up. To keep track of what came out of where, heres the map what Fizzer drew in his bestest biro. Under each valve is either a 1 or a 2 depending on where they came from, the top of each spring has red paint to make it easy to work out which way they go back on again.
https://i141.photobucket.com/albums/r71/siany_album/Fixin%20the%20XR/CIMG2954.jpg
Cylinder head minus valves
https://i141.photobucket.com/albums/r71/siany_album/Fixin%20the%20XR/CIMG2955.jpg
An inlet valve (left) and exhaust valve (right). Something looks odd here.
https://i141.photobucket.com/albums/r71/siany_album/Fixin%20the%20XR/CIMG2957.jpg
A little closer, this time. Both of the inlet valves are worn. Instead of showing a 45 degree angle they are more curved.
https://i141.photobucket.com/albums/r71/siany_album/Fixin%20the%20XR/CIMG2958.jpg
So I need to add a pair of inlet valves to my shopping list. List price of them is coming up at £18 each, fortunately the exhaust valves seem to be in the region of £30 each! Im shopping around to find some cheaper Smile
Next up, probably the clutch. Stay tuned.
The last post was made 14 years, 345 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 152.96 Kb
