K&n air filter
Lap9387
PostPosted: 19:54 - 15 Dec 2011    Post subject: K&n air filter Reply with quote
I've just received my k&n filter for my Cbr...
I've been told by someone I can't just bung it in because the carbs wont run right with more air and that if I wanted to use the k&n it would need to be dynojetted??
Is this true, i thought k&n filters were a direct replacement that didn't need any extra work??
Smokin Joes CBR 600 - 52plate
Theory: 12/10/2011
Mod 1: 28/11/2011
EazyDuz
PostPosted: 20:19 - 15 Dec 2011    Post subject: Reply with quote
Will run lean, carbs need rejetting to allow more fuel. Why did you want a k&n airfilter?
dangerousdave
PostPosted: 21:46 - 15 Dec 2011    Post subject: Reply with quote
Its the clamp on K&Ns that you have to re-jet for. These clamp onto your carbs and do away with the air box.
If you're just replacing the filter in your air box with a K&N it wont need to be re-jetted.
1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50
EazyDuz
PostPosted: 21:51 - 15 Dec 2011    Post subject: Reply with quote
Depends how much more air the new filter lets in compared to stock, just do a plug chop to make sure.
Lap9387
PostPosted: 23:10 - 15 Dec 2011    Post subject: Reply with quote
I like the idea of not needing to buy a new filter every service... The filter in my air box is goosed, it's so clogged it could of been solid!
I was told by the place i bought it said that it shouldn't effect the way the engine runs... You get a baffle to replace the o rings
Theory: 12/10/2011
Mod 1: 28/11/2011
The Artist
PostPosted: 23:13 - 15 Dec 2011    Post subject: Reply with quote
Those pod filters are a PITA unless set up perfectly.
You don't need to replace the filter in your air box every service, just clean it.
PostPosted: 00:01 - 16 Dec 2011    Post subject: Reply with quote
You'll need to upjet. Tried a K&N on my 05 CBR...went back to stock.
Very very lean running when its attached and not jetted.
Must mention though I had a full Venom system and was jetted standard.
BIKEVIDDER
PostPosted: 10:04 - 16 Dec 2011    Post subject: Reply with quote
If you mostly pootle around the jets can be left alone as they only come on song after 1/2 throttle, or is it 3/4's ??
Bung it in, go for a slow ride, if the engine doesn't seem right get back home quick (ride slow !!)
Have a look at the plugs after a slow ride, if the mixture seems fine then get the engine warm & go for a short thrash & take your plug spanner with you for a looksie.
Look at your plugs before though to make it obvious if anything has changed.
GROWING OLD DISGRACFULLY
PostPosted: 10:22 - 16 Dec 2011    Post subject: Reply with quote
So leave the fairings and front indicators off and go for a ride? Laughing
OP, just put the stock filter on, there is no advantage to a K&N despite what anyone has told you. It's a 125, it will last far longer if you leave it stock.
Check the oil also..and the filter. CBR's have a nice habit of eating their cams/bearings.
Lap9387
PostPosted: 12:03 - 16 Dec 2011    Post subject: Reply with quote
It's a 600, but I'm not the most technical person in the world... I'll just take it out and clean it!
What's the best way to clean my current dock filter that looks like something a cat coughed up
Theory: 12/10/2011
Mod 1: 28/11/2011
PostPosted: 13:12 - 16 Dec 2011    Post subject: Reply with quote
My apologies, thick as shit Laughing
Your current filter, best thing to do is replace like for like, unsure if your bike is fuel injection or not... if its carbed I'd not bother with an uprated filter unless you get the bike set up to do so.
Wemoto or ebay are probably the cheapest place for these.
Sorry for the blind post... should read sigs more often Laughing
Lap9387
PostPosted: 20:44 - 16 Dec 2011    Post subject: Reply with quote
Its going back and I've a stock filter on order...
Theory: 12/10/2011
Mod 1: 28/11/2011
PostPosted: 21:00 - 16 Dec 2011    Post subject: Reply with quote
If you run a 52 plate CBR600 (as per your sig) then it's fuel injected and thus doesn't have carbs so the advice in this thread is pretty meaningless with regards to plug chops and whatever.
If you want to get it set up properly you'll need a Power Commander III and an afternoon on the dyno. Should also get rid of the snatchiness that early FI Hondas are known for. It's a bit pricey though.
Alternatively you could just bung it in and get a dyno run done for £30 or so, then you'll be able to see if it's fuelling dangerously lean anywhere.
Lap9387
PostPosted: 21:04 - 16 Dec 2011    Post subject: Reply with quote
It's an f3... But stood in a showroom for a year and a half before it was registered...
Hence the 52 plate
Theory: 12/10/2011
Mod 1: 28/11/2011
PostPosted: 21:06 - 16 Dec 2011    Post subject: Reply with quote
Hence the 52 plate
If it's an F3 it's been stood in the showroom for more like 4-5 years, given they stopped making them in 1998. Thumbs Up
Lap9387
PostPosted: 21:09 - 16 Dec 2011    Post subject: Reply with quote
Ah well... Not to worry
Theory: 12/10/2011
Mod 1: 28/11/2011
The last post was made 14 years, 315 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 88.79 Kb
