Bike not running properly when it rains heavy !!!!!!
Iowcg
PostPosted: 00:20 - 16 Dec 2011    Post subject: Bike not running properly when it rains heavy !!!!!! Reply with quote
My 1996 honda cg125, It's happened to me twice. It's raining heavy and it after 3 miles it starts to lack in power then if I rev up it sounds like its coughing and back fires loudly I assume water is getting in somewhere but don't no where, or it's something todo with the wiring maybe, the first time this happened it was hammering it down and I went through a puddle than ended up the size of a small pond :-/. It ran ok but it's like it didn't have enough power to move only to run. I left it for a day tried to kick it but nothing so bumped it and started first time and ran fine!??!. Second time was tonight in the pointing rain it started to cough as I call it then started to loose power so pulled over reved it abit and every rev it back fired so turned it off and started pushing home :-/ 2 miles down the road dripping wet I kicked started it and it started and I reved it rite up and a huge bang with 2foot flame out the exhaust and rode home was abit juddery, can anyone help me? Oh and when it's not raining it runs fine. Also water might be getting in through my petrol cap not sure tho but if anyone can help I would be most thankfull Smile
M l poskitt
PostPosted: 01:16 - 16 Dec 2011    Post subject: Reply with quote
I'd go electrical, and I'd start with the sidestand switch. WD-40 and grease it, plus any connector blocks on its wiring route that could be exposed to the elements.
Eddie Hitler
PostPosted: 01:47 - 16 Dec 2011    Post subject: Reply with quote
That or a clogged air filter.
Frost
PostPosted: 02:10 - 16 Dec 2011    Post subject: Reply with quote
Runnning in is what you do to a new engine and means keeping the revs down low for a low period. It doesn't sound like you're having an issue with this but are instead experiencing an electrical issue resulting in power loss and back firing due to unburnt fuel.
multijoy
PostPosted: 02:15 - 16 Dec 2011    Post subject: Reply with quote
My money'd be on the HT cable/plug getting a soaking. Check it all seats right and then smear a load of vaseline around the join between the plug cap and the cable.
yambabe
PostPosted: 02:18 - 16 Dec 2011    Post subject: Reply with quote
I agree with multijoy, I reckon the rain is getting into your plugs.
Mr_Cynical
PostPosted: 08:26 - 16 Dec 2011    Post subject: Reply with quote
Mine did exactly the same a few months ago, and it turned out to be water getting into the plugs. That plus my battery was on it's way out...
Do what multijoy said and maybe get yourself a can of Damp Start. Seemed to work for me.
Bikes: '05 Better BT125-20 => '79 Honda CB750KZ (Now a project bike) => '99 Suzuki Bandit 600 => '01 Triumph Tiger 955i
"What's my motto? I like ham."
"It's a good motto, sir."
willis1337
PostPosted: 08:31 - 16 Dec 2011    Post subject: Reply with quote
I reckon this too - had it happen to me years ago when I had a MT50. Wrapping the HT lead in electrical tape the liberally spraying with WD40 will help for a bit. Long term fix is replace HT lead and spark plug cap - shouldn't be too expensive.
Current bike: KTM SD1290GT
Previous bike: BMW K1300S
BIKEVIDDER
PostPosted: 10:12 - 16 Dec 2011    Post subject: Reply with quote
Carry a small can of WD40 or similar, when It starts running rough next time pull into a bus shelter or garage forecourt & spray the WD40 over your plug lead as far up as you can & take the cap off & squirt into the cap.
If the magic fix occurs have a think on how you can water proof your electrics more permanently in future.
GROWING OLD DISGRACFULLY
robbieguy2003
PostPosted: 11:07 - 16 Dec 2011    Post subject: Reply with quote
The problem is clearly a bent subframe, fix that and the rest will be fine.
I've got no idea though, but my RR7 struggles if it's been out in really really heavy rain, i think it's because the air intake is right on the end of the nose.
Current Bikes: Honda CBR 600RR - '07, Suzuki GSX1250 FA ST '11
Old Bikes: Suzuki Intruder 125 LC - '2001, Honda CBR 600F - '92, Honda CBR 600RR - '03
Maverick Rigger
PostPosted: 20:04 - 16 Dec 2011    Post subject: Reply with quote
Same problem here Honda CB250W. Will check the connections in the morning, any moist in there is getting banished for good.
The motorcycle presents you a challenge to master the machine, a challenge to adventure. You ride through the wind, linked to the road by a vehicle that responds to your commands as no other does. Unlike an automoblie, there is no metal cage around you, Like and airplane, a pre-ride inspection and regular maintenance are essential to your safety. Your reward freedom.
The last post was made 14 years, 280 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.51 - MySQL Queries: 13 - Page Size: 68.61 Kb
