help in portsmouth asap
fbmbmx
PostPosted: 17:46 - 17 Dec 2011    Post subject: help in portsmouth asap Reply with quote
Hello people i fitted new brake discs today and everything went fine untill it came to putting the front wheel back on. The wheel went on but its out of line and the caliper is rubbing on the disc. I need someone to help me get my wheel on straight i tried about 5 times but the wheel was wobbleing side to side so i think im not putting the spacers in right, the wheel bearings should be fine as i had new head stock bearings fitted by steve jordan a month ago and nothing was said. If someone could pop round and help me tomorrow or just lend me a stand which goes in the steering stem that would be brilliant.
Thanks
Suzuki gsxr 600-2003
Quote Me Happy
PostPosted: 18:53 - 17 Dec 2011    Post subject: Reply with quote
Have you got a service manual for your bike so you can check?
fbmbmx
PostPosted: 19:03 - 17 Dec 2011    Post subject: Reply with quote
yeah, i have checked and seem to be doing everything correct :S
Suntan Sid
PostPosted: 19:26 - 17 Dec 2011    Post subject: Reply with quote
Did you check that the new discs are exactly the same as the old?
If they're not then you're going to have alignment problems.
fbmbmx
PostPosted: 19:37 - 17 Dec 2011    Post subject: Reply with quote
i cant see how they can be different, all the bolts line up perfect and they are the same size in diamitor so and flat
SirToU
PostPosted: 19:47 - 17 Dec 2011    Post subject: Reply with quote
Hi, would like to help, but I'm not in Portsmouth until next week.
Did you put the disks on the correct way round, cause even if you are putting the wheel on correctly, if the disks are wrong way round, they will rub.
You might also post a couple of pictures up here and someone might be able to spot the error of your ways.
Smile
Neil
Ride it like it was stolen.
2011 Motogymkhana UK Competition Winner
2012 Motogymkhana UK Series Champion
fbmbmx
PostPosted: 19:49 - 17 Dec 2011    Post subject: Reply with quote
nope, they are on the right way, its the wheel causing the problem as its not central and wobbling side to side but i cant get it to stop shaking
SirToU
PostPosted: 19:54 - 17 Dec 2011    Post subject: Reply with quote
You haven't accidentally left an additional spacer or bearing out?
Just trying to think of potential problems to help out.
Neil
Dave McCool
PostPosted: 19:55 - 17 Dec 2011    Post subject: Reply with quote
Sounds a hell of a lot like you lost a spacer, are you sure everything you took off went back on? Obviously this is hindsight talking, but I find the best thing to do is to reassemble the spindle on the bench as soon as it's out, in the right order of things.
In what way is it wobbly? Like, as in loose, or what? Better descriptions may help.
McGee - "When I go to the mall and see all the high school girls, I have to have DO NOT TOUCH THE GIRLS written on my hand. Every time I go to grope I see it and stop."
K7 GSXR750
fbmbmx
PostPosted: 20:00 - 17 Dec 2011    Post subject: Reply with quote
there are no spacers on the k4 to leave out just the axel and the holding part which sits it the fork leg it's driving me crazy as i am normally pretty good as this sort of thing but this just is not right Sad
Suntan Sid
PostPosted: 20:55 - 17 Dec 2011    Post subject: Reply with quote
Are these the parts you're dealing with and do you have them all?
https://www.bike-parts-suz.com/suzuki-recherche-bike-pieces_nn.php?compteur=1298&PartsListID=3448442
Suntan Sid
fbmbmx
PostPosted: 21:54 - 17 Dec 2011    Post subject: Reply with quote
yeah i have them all Smile
h00dwink
PostPosted: 22:03 - 17 Dec 2011    Post subject: Reply with quote
everything done up including the pinch bolts at the bottom of the forks?
Sahf East Winnah 4LYF
https://bikepics.com/members/h00dwink/00sv650s/
www.youtube.com/h00dwink updated regularly
Dave McCool
PostPosted: 23:55 - 17 Dec 2011    Post subject: Reply with quote
Not 100% sure it would affect it that much, but is the wheel definitely the right way round? Could be a fairly simple error?
K7 GSXR750
LeanIt
PostPosted: 01:33 - 18 Dec 2011    Post subject: Reply with quote
Most wheels tyres and discs are directional, worth a double check?
Very easy to get too focused, sit down have a fag/beer/cuppa and go back to it with a clear head. Wink
Life is like a shit sandwich. The more bread you have, the less shit you eat.
SirToU
PostPosted: 11:21 - 18 Dec 2011    Post subject: Reply with quote
How did you get on?
Neil
fbmbmx
PostPosted: 15:53 - 18 Dec 2011    Post subject: Reply with quote
found the problem, the axel nut-spacer is worn down and now tapered causing the movment, i can not get everything perfectly straight with it worn so i will order a new one bolt everything up then go to a tire shop and get it all line up there with a laser and what not
The last post was made 14 years, 268 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 96.29 Kb
