Knocking driveshaft - Which one?!
garth
PostPosted: 11:06 - 21 Dec 2011    Post subject: Knocking driveshaft - Which one?! Reply with quote
I have a diesel 106.
When I turn left a drive shaft makes a noise like a helicopter, it's worse at speed.
Amirite in thinking this is a driveshaft, and if so, is it the O/S or N/S?
Walloper
PostPosted: 11:21 - 21 Dec 2011    Post subject: Reply with quote
It could be a wheel bearing or a CVJ (Constant Velocity Joint).
My Tip: Why not stick to Left Side and Right Side?
O/S and N/S are a bit redundant. (as far as I am concerned).
It confuses the fcuk out of people and for no practical reason.
And if you are talking to foreign people it makes it worsererer.
Mostly you can pinpoint which side if bad enough but if only subtly it can be more difficult and need more detailed inspection.
You could act stupid and see wot Kwikfit say.
Costs nothing but may be of some help.
garth
PostPosted: 12:09 - 21 Dec 2011    Post subject: Reply with quote
I've had it on the ramp and neither have play. Hence why it's confusing me. Laughing
It doesn't sound like a wheel bearing.
CV Boots visually look fine - I'd just do the whole driveshaft - It's £39 quid delivered and minimal hassle, but I'd rather not do both!
Walloper
PostPosted: 14:28 - 21 Dec 2011    Post subject: Reply with quote
Due to the differential action the outside wheel has to turn faster than the inside wheel (Or visa versa) when cornering/driving around in a circle.
I would guess the joint with the higher speed when cornering will be the one making the noise.
So if it is noisy when turning left the rightside joint/shaft will be fastest.
Maybe a load of shite mind you.
I found this pish:
https://kevin1533.hubpages.com/hub/How-to-diagnose-CV-joints-failure-and-repair-options
st3v3
PostPosted: 21:09 - 21 Dec 2011    Post subject: Reply with quote
When i had a knocking I replaced the O/S wheel bearing, it didn't go away. but the noise was clearest/loudest when this part was under stress.
I then replaced the N/S one and still no good.
I replaced the O/S drive shaft and still no good. Rolling Eyes
Then I replaced the N/S shaft and it went away, like magic it went.
Because the vibration travelled and sounded off the opposing disc or whatever it duped me, but well in the end it got a full set of brand new parts. Thumbs Up
Just be careful. Wink
Walloper
PostPosted: 23:47 - 21 Dec 2011    Post subject: Reply with quote
Were you OFF/set by the NEAR/ness?
Then LEFT to do it RIGHT?
Confused
Fisty
PostPosted: 23:51 - 21 Dec 2011    Post subject: Reply with quote
It's a driveshaft if it's a 106. my AX (same chassis/running gear as a 106) o/s went so I changed it. Within a month the n/s went too. If I were you I'd do both at once, as they are cheap and easy enough to do.
Fatter and faster than Fret
Shaft
PostPosted: 00:10 - 22 Dec 2011    Post subject: Reply with quote
^^^ This
At 40 quid a throw, I'd just do both; the law of sod says whichever one you choose, it will be the other one and, at that price, it's just not worth the aggro.
Martay
PostPosted: 00:52 - 22 Dec 2011    Post subject: Reply with quote
I had an AX and went through 3 in a year. IIRC you cant seperate the CV joint from the driveshaft so it all has to be replaced.
Eat well, poo hard Very Happy
Drives: Cavalier 2.0 16v
Blackwolf
Burgerfist
PostPosted: 01:34 - 22 Dec 2011    Post subject: Reply with quote
Intresting me o/s one in the AX is going. how big-a-job was it?
st3v3
PostPosted: 05:10 - 22 Dec 2011    Post subject: Reply with quote
True but it's a peice of piss.
I went to U Pull It, and found a car that had receipts for work done pre-MOT inc shafts and shockers so took them as replacements Laughing cost about £50 in the end. Cool
The shafts are a 5min job:
Slacken wheel bearing nut.
Wheel off.
Undo bottom bracket bolt for the hub.
Unscrew wheel bearing nut.
Pull disc/shocker outwords so shaft can be pushed in a touch before it pops out and off.
Repeat for other side and slip new ones in, in reverse. Thumbs Up
garth
PostPosted: 12:19 - 22 Dec 2011    Post subject: Reply with quote
Wheel off.
Gearbox oil and seals while I'm at it?
D O G
PostPosted: 12:31 - 22 Dec 2011    Post subject: Reply with quote
I'd LOVE to see St3v3 do this in 5 minutes. I think it took me around an hour all in to do one shaft on my Clio, from start to finish on my drive.
It is easy tho.
I would have thought that if you do both you'd have to drain the oil from the box - certainly on the Clio the n/s requires you to remove the boot from the gearbox, which then results in all the oil pissing out. Only the o/s is sealed. Of course the 106 may be totally different with sealed shafts both sides.
Gearbox oil is bloody expensive - prob another £30-40. I'd be inclined to drain and collect, if it looks terrible, change, but otherwise I'd be inclined to reuse.
I'm presuming you have all the tools etc to do it, but if not I'd be able to pop round with a few bits to assist - I'm only in Eastleigh.
garth
PostPosted: 12:46 - 22 Dec 2011    Post subject: Reply with quote
Thanks for the offer - Karma
I've got everything I need I believe, I'll just do both at the same time. It's not that bad yet, just irritating.
Cambelt was done Monday, I'll do an oil and filter on Saturday, then driveshafts next payday.
It hasn't done mega miles at all (44k) but I'll probably change the gearbox oil anyway.
garth
PostPosted: 12:54 - 22 Dec 2011    Post subject: Reply with quote
75/80 gear oil is £9/L in Halfrauds, so another £18.
Might as well.
Andy_Pagin
PostPosted: 13:02 - 22 Dec 2011    Post subject: Reply with quote
It's surprising how little wear you need on a bearing to make a lot of noise.
I had a wheel bearing on an old Escort making a horrific racket, I really thought the thing must have started to break up. So took it off, hardly any sign of wear, no noticeable play.
Fitting a new bearing cured the noise.
st3v3
PostPosted: 22:01 - 22 Dec 2011    Post subject: Reply with quote
Wheel off.
Wouldn't bother; unless there's something clearly wrong looking at the oil on the shaft when it comes out..
Maybe not 5 but definitely not much like half an hour, my nuts aren't all seized up, they're in good working order. Wink
Infact, fucing resentfully i'm starting the barstad clutch again tomorrow since daddy wants to look so il use my phone and video how long it takes to whip both out, from jacking up until both are on the ground?
The last post was made 14 years, 190 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.34 - MySQL Queries: 13 - Page Size: 100.65 Kb
