Instrument Panel Bulbs
Mrjoolz
PostPosted: 12:53 - 21 Dec 2011    Post subject: Instrument Panel Bulbs Reply with quote
Does anyone know the type of bulbs I need for instrument panel on ZZR600, as I have two that have blown, and I cannot read the speedo or rev counter at night.
Saw a pic of a ZZR600 with blue bulbs in panel, so all the dials were a luminous blue like the Volkswagen Golfs. (looked pretty nice) but I just wanna replace them really.
Is it a pain to get at them ? Is it a fairing off job ?
thanks
Previous Bikes: TZR125, KMX125, RGV250, RD350YPVS, GXSR750H, GSXR600SRAD, R1 (2000), GSXR1000 (K1), ZZR600, CBR1100XX Super Blackbird
Current Bike: Suzuki GSX1300R Hyabusa.....
Bomberman
PostPosted: 13:44 - 21 Dec 2011    Post subject: Reply with quote
Can't speak for the ZZR but in my experience it's always going to be top fairing off at least. Did my GPZ last week (speedo bulb went) and I managed to do it with the fairing pulled forward and resting on the wheel (unbolted, but left the light wiring connected) rather than totally removing it... Was still a fiddle but only a ten minute job.
Beelzebob
PostPosted: 22:50 - 21 Dec 2011    Post subject: Reply with quote
Find out the bulb type - probably a common automotive bulb (they were on the Hornet). Then go to Halfrauds and take advantage of their "let me fit that for you" service.
Job done.
'09 YBR 125 -> '92 XJ600 S Diversion -> '99 Hornet 600
"Stronger than your average female lifeguard"
PostPosted: 22:57 - 21 Dec 2011    Post subject: Reply with quote
Not sure it is a top fairing off job (which is a pain on the ZZR). I have a feeling you might be able to get away with taking off the surround around the clocks, then unbolt the clocks and get behind them.
If that doesn't work then you need to remove the whole fairing which is way harder than it should be.
Mrjoolz
PostPosted: 10:36 - 22 Dec 2011    Post subject: Reply with quote
I tried to remove the fairing to get to the bottom fork clamps but after taking out 13 bolts/screws the dam thing still wouldnt come off.
Dont know what order you need to start in to remove the whole fairing, but it seriously wound me up try to get it off.
:o(
PostPosted: 14:03 - 22 Dec 2011    Post subject: Reply with quote
This is from memory. And it is a pain so might have forgotten something.
Remove the trim piece around the top of the belly pan (bolt on either side then slide forward). Remove the belly pan. Remove the fairing inner trim (one bolt is hidden in the lockable compartment). Remove the side fairings. Remove the screen. Think you can then get at the bolts to remove the mirrors and top fairing, and clocks.
Doesn't actually help much when tying to get at the bolts on the bottom yoke. There is VERY little clearance between them and the plastic ram air intake tubes, and frankly I couldn't be bothered to remove the tubes. Either use an allen key which us cut down, or use a small allen key bit and a spanner (ratchet spanner makes it easier), done from below having removed the small access panel under the headlight.
Mrjoolz
PostPosted: 11:44 - 23 Dec 2011    Post subject: Reply with quote
Cheers Keith. I undid the two bolts on the fairing inner panel on the right, and it still wouldnt come off, so I assume I have missed a bolt on it.
PostPosted: 11:53 - 23 Dec 2011    Post subject: Reply with quote
Thought there were a couple on each side. However once unbolted it is still a pig to remove. You will find it moves a bit but requires a lot of force to remove (ie, feels like you are putting in enough force to break it).
The last post was made 14 years, 295 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 58.24 Kb
