Reverse Bleeding Brakes
HD
PostPosted: 00:23 - 22 Dec 2011    Post subject: Reverse Bleeding Brakes Reply with quote
Is it worth forking out a fiver on a massive syringe to do it that way or is it really definite that if you bleed it the conventional way you will get the optimum performance? The only reason why you wouldn't being a component, not the bleeding procedure?
Out of interest, anyone used the big syringes?
UrbanRacer
PostPosted: 00:29 - 22 Dec 2011    Post subject: Re: Reverse Bleeding Brakes Reply with quote
never used a syringe, i have a proper vacuum bleed kit tho, cost me about £60 and does the job very quickly. has multiple uses.
I don't understand your last question, component?
The conventional method is good enough as long as you do it properly.
HD
PostPosted: 00:31 - 22 Dec 2011    Post subject: Reply with quote
As in master cylinder seals, hoses leaking, banjo loose, calliper seals Smile
Stalk
PostPosted: 00:33 - 22 Dec 2011    Post subject: Reply with quote
Yes I have a big syringe. Did this a while back, hope it helps a bit
https://www.bikechatforums.com/viewtopic.php?t=217959&highlight=
Stalk
UrbanRacer
sorry mate, i still don't understand your question.
You can strip the brakes down to there component parts, rebuild and use whatever method you want.
el_oso
PostPosted: 00:35 - 22 Dec 2011    Post subject: Reply with quote
reverse bleeding was the only way to bleed the brakes on the thundercat effectively. traditional methods were taking ages as i created an air lock in it. it's also quite hard to use the traditional method with one person. reverse bleeding is very easy with one person. i'd go for it
Duke 390
Car: Jeep Wrangler 4.0L
cb1rocket
PostPosted: 14:11 - 22 Dec 2011    Post subject: Reply with quote
I always reverse bleed so much quicker! Just have a really full syringe and do it in one shot
Dazbo666
PostPosted: 14:59 - 22 Dec 2011    Post subject: Reply with quote
I've heard and read lots about this reverse bleed technique, but only ever used the conventional method on my cars and bikes.
Never had a problem, so I've never felt the need to change (If it ain't broke, don't fix it, etc)
Might be curious enough to have a go at some point and see if there's any noticeable difference... Thumbs Up
Word of the day : DILLIGAF
Souleh
PostPosted: 15:19 - 22 Dec 2011    Post subject: Reply with quote
Great to get the ball rolling after a full strip down on the brakes. Ive a 100ml syringe for each caliper and couldnt live without them Cool
Always bleed normally after the "traditional" way to finish the job too
HD
PostPosted: 16:16 - 22 Dec 2011    Post subject: Reply with quote
Yeah that was the plan.
Hell, I'm going to do it, cheers guys!
It says one use only but surely if I do both at the same time, then wash it out quickly with water to neutralise it, it should be fine, right?
Souleh
PostPosted: 16:54 - 22 Dec 2011    Post subject: Reply with quote
Oh sorry I wasnt clear, only one at a time but believe me when I say having one per caliper will save you effort. Youll need to get some fish tank airline tube to connect them and its a very tight fit so swapping them can be annoying going back and forth Very Happy
Happy bleeding Smile
volvodai
PostPosted: 21:11 - 22 Dec 2011    Post subject: Reply with quote
i bought a big syringe from a cattle vet for £3 including pipe worked a treat just be carefull of getting brake fluid everywhere
HD
PostPosted: 23:29 - 22 Dec 2011    Post subject: Reply with quote
Yeah mate, the one I am looking at comes with a hose anyway, but I ain't buying two Laughing
The last post was made 14 years, 301 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 80.73 Kb
