| BigGeeking |
 BigGeeking Scooby Slapper
 Posted: 22:39 - 22 Dec 2011 Post subject: Brake fade |
Hi all well going home this morning from a night shift and well had some fun and being a bit silly thinking about it but after some very heavy braking from high speed a couple of times and the brake fade was unreal at one point it just give up.
Know i know that the very high temps you get when heave braking but why do the brakes go like that, what causes it. is it gasses between the pads and disk or is it something else  ____________________ Bendy "Flip front. I can filter down the M4 while shoving a Twix in my face."
honda CG 125 2001 SOLD-- current Bandit 400--SOLD. current SV650s 2000
MOD 1 ON 20/7/2011**passed** MOD 2 ON 17/10/2011***passed***,,
| fatpies |
 fatpies World Chat Champion
| BigGeeking |
| BigGeeking |
 Posted: 22:57 - 22 Dec 2011 Post subject: |
so as always google knows all
Green Fade
Green fade is the most common. It is the result of new brake pads being fitted. New brake pads need time to cure, a process which happens naturally through use, before they become fully effective. If they are not fully cured, they can release gases under the heat of intense braking and those gases form a cushion which reduces friction between the pad and the disc or drum.
Fading Due to Overheating
Brake pads are made of a complex mix of materials. One is a resin. Sustained heavy braking can cause the brakes to heat up so much that they melt the resin and the melted resin acts as a lubricant between the pad and the disc or drum which causes the brakes to slip.
Fluid Fade
Brake fluid is capable of absorbing water from the air. When water is absorbed, the boiling point of the fluid is lowered. If the boiling point of the fluid becomes too low, then heat from braking can cause it to boil. When the fluid boils a gas is released which remains in the tubes. When the brakes are pressed, instead of compressing the fluid, the gases are compressed and less power is applied to the brakes
Read more: Main Cause of Brake Fade | eHow.com https://www.ehow.com/facts_7337140_main-cause-brake-fade.html#ixzz1hIr7li9E ____________________ Bendy "Flip front. I can filter down the M4 while shoving a Twix in my face."
MOD 1 ON 20/7/2011**passed** MOD 2 ON 17/10/2011***passed***,, |
| Daytona Paul |
 Daytona Paul Scooby Slapper
 Posted: 00:47 - 23 Dec 2011 Post subject: |
I was running a machine control day earlier this year and we were doing emergency braking exercises from approx 100mph.
One of the guys had done a few runs when he came towards me again and started braking, as he passed me, still doing around 50mph, I noticed that the front brake lever was back to the bar
He continued past me, off the end of the runway and onto the grass some 20m or so.
The front discs were so hot the brake fluid had boiled. The fluid, along with his underpants, needed changing. Apparently all was ok the next day  ____________________ www.angliaroadtraining.com
CBT FROM ONLY £85
Back to Biking Refresher Day £99! Book with a friend and get 20% Discount! |
| Kickstart |
 Kickstart The Oracle
 Posted: 01:04 - 23 Dec 2011 Post subject: |
Fade is normally from heat, with fluid boiling or the pads overheating.
If you have changed the pads and replaced the fluid then they should be OK. But cheap pads might well not work that well, and low spec fluid might not work well either (and if you used DOT 5 fluid it won't absorb water to flush it out).
However dragging brakes (from sticking calipers) will likely heat the brakes up without using the brakes, and also keep them warm after braking hard.
| WannaBeDude |
 WannaBeDude World Chat Champion
 Posted: 01:24 - 23 Dec 2011 Post subject: |
Can anyone tell me the history of brake pads, like when we used our trainers on bmx tyres.
In less than 5000 words ??
 ____________________ Jogging on, destination living. |
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 11:40 - 23 Dec 2011 Post subject: |
I hate break fade. You just know that you're going to have to do some work again soon. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Previously : CB100N > CB250RS > XJ900F > GT550 > GPZ750R/1000RX > AJS M16 > R100RT > Bullet 500 > CB500 > LS650P > Bullet Electra X & YBR125 > Bullet 350 "Superstar" & YBR125 Custom > Royal Enfield Classic 500 Despatch Limited Edition (28 of 200) & CB Two-Fifty Nighthawk > ER5 |
| matlow |
 matlow Scooby Slapper
 Posted: 12:36 - 23 Dec 2011 Post subject: |
I always thought brake fade was to do with fluid heat causing the rubber brake lines to become more maleable therefore you had to squeeze through that movement. hence braided lines stopping the cable expanding and increasing braking pressure, although losing feel.
Always sounded feasible ____________________ Hornet 600, CBR600F, 929 blade, 07 R1, R1200GS, 09 Blade, 750 SRAD, ZZR1200, 954 Blade, KTM 990 Adventure, Ducati 749s |
| Kickstart |
| pits |
 pits World Chat Champion
 ..... Quote Me Happy
| bunglebubs |
 bunglebubs Spanner Monkey
 Posted: 18:03 - 23 Dec 2011 Post subject: |
Why oh why can't people spell BRAKE properly? Even in this thread the OP spells it wrongly break as in a coffee or tea break but spells braking properly in his first sentence!!
Ok got it off my chest now and breathe, phew ____________________ 899 Panigale, K7 GSXR 750 |
| parkmoy |
 parkmoy Scooby Slapper
| parkmoy |
| BigGeeking |
 Posted: 21:21 - 23 Dec 2011 Post subject: |
There you are happy now  ____________________ Bendy "Flip front. I can filter down the M4 while shoving a Twix in my face."
| Walloper |
 Walloper Super Spammer
 Posted: 22:44 - 23 Dec 2011 Post subject: |
Brake/Break/Braik fade/faid is caused by excessive use of the breaks/brakes/braiks.
During normal use there/their/they're will be no incidence of fade/faid.
Learn to look ahead and time/Thyme your gearchanges/geerchainges.
 ____________________ W-ireless A-rtificial L-ifeform L-imited to O-bservation P-eacekeeping and E-fficient R-epair |
The last post was made 14 years, 273 days ago. Instead of replying here, would creating a new thread be more useful? |
