| Mikey CB500 |
 Mikey CB500 Scooby Slapper
 Posted: 22:38 - 22 Dec 2011 Post subject: got my first welder :) sealey 160xt arc welder, help me haha |
basically i really need to learn to weld as im a motorcycle mechanic and time and time again im having to pay other people to do jobs for me
so the kind aunts and uncles got me one and all the appron healmet and gloves etc for my 21st which was a week ago
basically for a start i need some setup advice and also advice on good things to practice and learn
ive looked on youtube but fed up of the stupid american pointless videos
im using 2mm rods so what ampage do i need? and more importantly how do i calculate this for different rods etc?
many many thanks  |
| Robby |
 Robby Dirty Old Man
| Mikey CB500 |
| Robby |
 Robby Dirty Old Man
| Mikey CB500 |
| Ichy |
 Ichy World Chat Champion
 Posted: 23:01 - 22 Dec 2011 Post subject: |
Assuming that the welder is running the correct voltage etc then roughly 70-80amps for 2mm should be good. I've seen some cheap welders that need to be set at 110amps for 2mm. Try and get some 1.5mm and run at 50-60 amps. To be fair the welder should be capable for basic repairs but you really need to look at MiG for a future upgrade.
Practise makes perfect and all that. I can weld two bits of 0.5mm with an arc welder but it would be my last choice. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| Mikey CB500 |
| Ichy |
| Mikey CB500 |
 Posted: 23:17 - 22 Dec 2011 Post subject: |
more than anything i just want to be able to do good strong welds, can make them look better with a little grinding and paint anyway  |
| Ichy |
 Posted: 23:24 - 22 Dec 2011 Post subject: |
If your welding bits of angle iron together then an arc welder is fine. Its the thin stuff, less than 3mm, that requires a bit more finesse. While I personally think that gas welding is the best starting point for gaining knowledge arc will certainly give you an understanding of weld pools and such like. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| Mikey CB500 |
| Ichy |
 Posted: 23:42 - 22 Dec 2011 Post subject: |
I'm not saying that you shouldn't just that it's not easy. Most arc welders are very aggressive and will blow holes at the first opportunity. 3mm plus will dissipate some of the heat slowing the welding process down and making it easier for the novice to see what is going on. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| Mikey CB500 |
| Rogerborg |
 Rogerborg nimbA
 Posted: 01:12 - 23 Dec 2011 Post subject: |
I've done 2mm exhaust with an arc welder, but it's not pretty and it'll blow quicker than Lindsay Lohan trying to score a line of nose candy.
Arc will teach you to do it the hard (or the cheap) way, but there's really no call to go that route if you're intending to do it professionally. ____________________ Biking is 1/20th as dangerous as horse riding.
| Okeydokey |
 Okeydokey Scooby Slapper
| Mikey CB500 |
 Posted: 13:18 - 23 Dec 2011 Post subject: |
I have a quick reactin black out lens in my helmet so thats a good thing to know  |
| bwprice100 |
 bwprice100 Borekit Bruiser
 Posted: 15:06 - 23 Dec 2011 Post subject: |
Hi Micky
An arc welder is a good starting point for welding on a budget.
Limitations are:
Difficult to do thin stuff and a 15amp socket won't supply enough juice for really thick stuff.
Get hold of some scrap bits of steel and practice loads and cut some of your welds apart to see how good the penetration is.
Things not to do:
Weld any thing with galv on it, it gives off cyanide gas,
When welding any mechanical piece of kit be careful where you attach the earth as any tracking through bearings etc. can wreck them.
Keep your rods dry.
Tools needed:
Proper welding gloves,
Welders hat, they are like cotton baseball caps worn back to font and stop the top of your head and the back of your neck getting burnt.
Good non flammable overalls preferable cotton.
Chipping hammer,
Wire brush,
6" grinder,
Various welding clamps
Fire extinguisher (Lidls sell good ones)
If you wear glasses be prepared to get welding spatter on them. Even if you are wearing a welding helmet weld spatter can bounce around all over the place and ruin them.
Be aware of what can catch fire in the vicinity of what you are welding and keep an eye out. i have seen many people who have been happily welding away and have not been aware that the workshop is on fire behind them. You wont smell the smoke; better still have a mate with you, if possible.
Make sure no areas of skin are exposed as arc welding gives off serious amounts of ultraviolet light and gives a nasty sun burn; as well as causing long term health issues.
Warn others in the vicinity that you are about to strike an arc. You show that you are an experienced welder by saying 'EYES' in a firm voice before striking the arc. Arc eye is not a pleasant thing to have, believe me. A welding curtain may be worth considering.
To get the weld started it is a good idea to drag the welding rod across the work piece as this minimises the chance of the rod sticking to the work. if it still stick you could try increasing the amps. Most welders have a lump of metal to hand to test on before attacking the work piece.
I hope this is of some help Brian ____________________ www.eBolt.co.uk www.ToolRoomChucks.co.uk
My bikes 1956 BMW R26 250cc, !981 BMW R80 (was a TIC ex plod), 1994 R100RT, sold my 1981 Yam XS 250 |
| woll |
 woll World Chat Champion
 Posted: 15:18 - 23 Dec 2011 Post subject: |
| Robby wrote: | Arc? Sell it and buy a MIG.
Then just fiddle with the settings until your welding sounds like sizzling bacon. |
If it sounds like bacon you ain't doing it right. Should just get the humming from the welder if it's set right. ____________________ Current Bike- Suzuki DRZ400 SM K6
Damaged spleen, damaged kindey, 2 popped lungs, 2 broken ribs, broken face, broken wrist and 5 back fractures... remember kids walls hurt |
| Mikey CB500 |
 Posted: 15:21 - 23 Dec 2011 Post subject: |
| bwprice100 wrote: | Limitations are:
How thin do you think i can weld with a arc welder once ive got some good practice in?
Things not to do:
Also reguarding this should i just grind of the surface to expose bare un-galvanised metal underneath?
Tools needed:
Chipping hammer,
Wire brush,
6" grinder, (ive got a 4.5inch with a quick release guard, really handy for changing the angle of the guard quick to get into difficult areas etc. I pressume this will be surfice?)
Various welding clamps (Got any suggestions? this is the only thing i dont have atm)
To get the weld started it is a good idea to drag the welding rod across the work piece as this minimises the chance of the rod sticking to the work. if it still stick you could try increasing the amps. Most welders have a lump of metal to hand to test on before attacking the work piece. (Will certainly bare this in mind mate ) |
Hi brian ive quoted what you said above and added in my questions in bold mate, if youd be kind enough to read it through and answer them. If you could give me anymore setup advice then that would be great help also. Ive only got 2mm rods atm so thats what ill be starting out with
Thanks Mike |
| Gothtec |
 Gothtec Renault 5 Driver
| bwprice100 |
 Posted: 16:07 - 23 Dec 2011 Post subject: |
How thin do you think I can weld with a arc welder once I’ve got some good practice in?
1.6mm is feasible after practice 1mm can be done but preparation of the joint is the key; for example a bent up lip on each edge to artificially raise the metal thickness.
Weld any thing with galv on it; it gives off cyanide gas,
Also regarding this should I just grind of the surface to expose bare un-galvanised metal underneath?
Yes but make sure it has all gone and well past the area you are going to weld. If you get exposed but always seek medical advice. It fucks your lungs up badly.
6" grinder
I’ve got a 4.5inch with a quick release guard, really handy for changing the angle of the guard quick to get into difficult areas etc. I presume this will be suffice?
Yes fine, the bigger one is handy for cutting notches out of things.
Various welding clamps.
Got any suggestions? this is the only thing I don’t have atm
Depends on what your doing but there are two basic types; those based on mole grips and posse-able magnetic ones.
See
https://www.google.co.uk/search?q=welding+clamps&hl=en&prmd=imvns&source=lnms&tbm=isch&ei=ZZX0TuLqF8j0-gbfxcTDAQ&sa=X&oi=mode_link&ct=mode&cd=2&ved=0CGAQ_AUoAQ&biw=1113&bih=840
| Damon |
 Damon World Chat Champion
| Davo |
 Davo Davo To The Rescue!
| Robby |
 Robby Dirty Old Man
| Damon |
The last post was made 14 years, 287 days ago. Instead of replying here, would creating a new thread be more useful? |
