Bike wont start after being run dry
grandmasterbo...
PostPosted: 00:49 - 23 Dec 2011    Post subject: Bike wont start after being run dry Reply with quote
As it sais i ran the bike dry by not paying attention to the
Fuel level it started choking n stuttering near a bp so i pushed it there put £5 in and it started fine i gave it a few twists on the throttle and it was okay but as i was pulling away it stalled n now wont start, i let it sit for a bit then gave the throttle a few twists n tryed again and nothing wouldnet sart on a push either its the first time iv let it run empty
Please someone help
suzuki CS50 roadie (exploded) Gilerea Runner VX 125 (sold)
CBR125 rw6 (crapped itself and died) YBR 125 2004 (its okay)
daaan
PostPosted: 01:55 - 23 Dec 2011    Post subject: Reply with quote
maybe alil bit of crap go thru when it ran dry id suggest cleaning out your tank, filters etc
temeluchus
PostPosted: 07:05 - 23 Dec 2011    Post subject: Re: Bike wont start after being run dry Reply with quote
Please someone help
drain the float bowl on the carby-look for a screw right on the bottom.
Dazbo666
PostPosted: 07:21 - 23 Dec 2011    Post subject: Reply with quote
As mentioned you've probably pulled some crap from the bottom of the tank into the carb...
I had a similar issue with the Bandit only firing on three cylinders after an emergency fill up about this time last year
Had a mate to help get the carbs etc cleaned out, and it's been fine ever since Thumbs Up
Word of the day : DILLIGAF
UrbanRacer
PostPosted: 10:00 - 23 Dec 2011    Post subject: Reply with quote
I reckon you've got air in the fuel lines if you ran it dry, i'll be surprised if its got shite in the tank.
PostPosted: 10:20 - 23 Dec 2011    Post subject: Reply with quote
Vacuum tap on the CBR, when we emptied the tank and lines on mine it took about 30-45 seconds of on off cranking the bike over to get fuel back through.
Just put the choke on and dont touch the throttle, crank it for about 10 seconds, stop to let it cool down then do it again.
Robby
Dirty Old Man
PostPosted: 17:14 - 23 Dec 2011    Post subject: Reply with quote
Paddy is correct. Vacuum taps can take a good while to prime the system again after running dry, certainly long enough to flatten a battery that isn't in great condition.
Also I'm not sure on your fuel tank size, but if you ran it dry then put in a fiver's worth you may still need to be on reserve, so don't turn it to on until it's full.
Crap in the bottom of the tank would get sucked in as soon as you flick to reserve. The crap sits right at the bottom, and is heavier than fuel. If there was enough crap or water to stop it starting then the bike would have run very poorly or cut out within a few minutes of switching over to reserve.
grandmasterbo...
PostPosted: 17:18 - 23 Dec 2011    Post subject: Reply with quote
its fine now managed to bump it earlyer with the help of a mate n just kept the revs at about 8000 for a few mins
PostPosted: 17:35 - 23 Dec 2011    Post subject: Reply with quote
Why 8000?! Your poor engine Laughing Sitting at 1500 would have been sufficient Rolling Eyes
Robby, for info, tank is like 13 litres.
grandmasterbo...
PostPosted: 17:39 - 23 Dec 2011    Post subject: Reply with quote
because it wouldent idle when u let the throttle go it cut out
PostPosted: 17:43 - 23 Dec 2011    Post subject: Reply with quote
CBR's dont, the choke NEEDS to be on for a few minutes, atleast until the temp gauge moves, no idea why... they all do that.
Just up the idle speed, should be 1350-1400 when warm.
grandmasterbo...
PostPosted: 17:45 - 23 Dec 2011    Post subject: Reply with quote
i never use the choke it dosent move anyway the metal spring thing around it is rusted i just start the bike and go
PostPosted: 19:03 - 23 Dec 2011    Post subject: Reply with quote
Then I feel sorry for your bike.
Sort the choke issue, its stupidly simple.
Walloper
PostPosted: 20:02 - 23 Dec 2011    Post subject: Reply with quote
And download a FREE spell chaecker for your 'Smart' phone.
Theryeie majik at speelieng.
The last post was made 14 years, 288 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 81.13 Kb
