Honda regulator rectifier! UPDATE - REAR WHEEL WOBBLE??
shereen
PostPosted: 11:11 - 23 Dec 2011    Post subject: Honda regulator rectifier! UPDATE - REAR WHEEL WOBBLE?? Reply with quote
Need a new one. Options are £150 for genuine Honda Sick
Or one of these.....
https://www.ebay.co.uk/itm/350138647801?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
https://www.ebay.co.uk/itm/NEW-VFR400-VFR-400-NC30-REGULATOR-RECTIFIER-RECH001-/200606222985?pt=UK_Motorcycle_Parts&hash=item2eb5100a89
Thoughts?
PostPosted: 11:13 - 23 Dec 2011    Post subject: Reply with quote
Get one with fins and mount it next to a really good ventilated area. Possibly bolt near the front of the bike? More cooling the better Laughing
Oldie
PostPosted: 12:41 - 23 Dec 2011    Post subject: Reply with quote
The "flat" ones without the fins get really hot, at least on mine which is hidden beneath the saddle. Next time I'd go for "fins".
PostPosted: 13:13 - 23 Dec 2011    Post subject: Reply with quote
Work out the pin order and fit this one.
It wont break because it is a mosfet regulator rather than a zennor.
shereen
PostPosted: 16:07 - 23 Dec 2011    Post subject: Reply with quote
Thanks for the advice guys, I will get the one with fins Thumbs Up
I have no idea what yo mean by pin order Laughing Are you saying the reg in the link you posted will fit my nc30? Confused
PostPosted: 16:31 - 23 Dec 2011    Post subject: Reply with quote
Think he means check that your layout is the same as that one.
As in the 1st pin is 12v+ and the 2nd is 5v+
Yours could be 1st pin 5v+ and 2nd pin 3.3v+ or something along those lines?
Just making sure you plug it in the right way/adjusting your wiring to suit.
I bodge, so would cut and solder it... but I wouldn't recommend it Laughing
jjdugen
PostPosted: 16:41 - 23 Dec 2011    Post subject: Reply with quote
Use the R1, Fazer 1000 R/R. They come with a 'tail' out of the recs body, makes cutting and soldering easy. Good units, not had one fail and they are cheap as chips, probably because they DONT fail.
Dont know what the 5 or 3.5 volts are that has been refered to. These are simply 3 (same colour) in from the alternator, one regulated live output, one earth.
Some early R/R came with a 'voltage sensor' input, these are V old technology and are unreliable, you dont need the voltage sensor connection wirth these.
shereen
PostPosted: 16:43 - 23 Dec 2011    Post subject: Reply with quote
Hmmm, So im getting the garage to fit it for me. Will they consider fitting a part that is not a direct fit?
PostPosted: 16:46 - 23 Dec 2011    Post subject: Reply with quote
Fit it yourself?
Its REALLY simple Thumbs Up
shereen
PostPosted: 18:43 - 23 Dec 2011    Post subject: Reply with quote
##Paddy## wrote:
Fit it yourself?
Yes I am going to fit it myself now, as I'm going to pick my bike up tomorrow!!
Dance!
Exciting!! I miss her!!
PostPosted: 19:02 - 23 Dec 2011    Post subject: Reply with quote
If you really do need a hand, always willing Thumbs Up
Fizzer Thou
PostPosted: 16:07 - 26 Dec 2011    Post subject: Reply with quote
The 2001 R1 rectifier/regulator has only a connector with no 'tail' to it.This was a problem with my one - one of the spade connectors within the block burnt out due to dirt corrosion.Once I had a new 'RR' I soldered the spades directly to the 'RR' unit.This made ensuring that the connectors were put on in the correct order a priority.
Is the bike done now Shereen?
Always have a 'Plan B'
shereen
PostPosted: 17:54 - 26 Dec 2011    Post subject: Reply with quote
All done apart from the reg. I must admit pdq in slough have been extremely good once again. And let me pay cash Thumbs Up the bike has been tuned up nicely
shereen
shereen
PostPosted: 16:01 - 27 Dec 2011    Post subject: Reply with quote
So, I picked the bike up the other day, and when I pulled off and put it into second gear the rear wheel kicked out. i thought it might have been the wet road or the soggy leaves on the ground so I didnt think much of it. I take the bike out again today and the same thing happens, knock it into second and the rear wheel kicks out again. It doesnt do it any other time only seems to be the very first time it is put into second. I will take it out tomorrow and see if it happens again.
Does anyone have any idea what could be causing this?
I thought it might be because the rear wheel is slighty squared off, but it was like this before the clutch was changed and it never did this before.
PostPosted: 16:09 - 27 Dec 2011    Post subject: Reply with quote
First thing to check is the rear wheel bearings. Put the bike on the centre stand (if fitted) or a paddock stand if possible.Grip the type on opposite sides of the wheel and try and wobble it. See if you can feel a load of play (ie, no effort to move the wheel a couple of mm and then it stops moving).
shereen
PostPosted: 16:17 - 27 Dec 2011    Post subject: Reply with quote
Thanks Keith, I checked for play and also checked the alignment which both seemed fine to me.
chegg
PostPosted: 18:00 - 27 Dec 2011    Post subject: Reply with quote
cold tyres and cold road if its only the first time you put it in second when your out mines got a habit of doing the same when the rear is cold and with diablos fitted its even worse. and just check the shock and linkage bolts and then if i doubt hit it with the biggest hammer you can till it stops easyist way to fix a nc and as for the reg rec mines got a 2004 cbr600 unit fitted not had any trouble with it
well that fucked it, ive got more power in me left testicle and thats plastic
The last post was made 14 years, 252 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 107.48 Kb
