Have I buggered up rear wheel bearing etc?
GREENI3
PostPosted: 00:47 - 24 Dec 2011    Post subject: Have I buggered up rear wheel bearing etc? Reply with quote
I attempted to adjust my chain for the first time and think I may have f'd up something.
I watched a video on youtube that said to put an 8mm allen wrench in between the chain and sprocket to tighten everything up to ensure correct adjustment, which is what I did, but I think I may have over tightened it by rotating the wheel too far, because I heard a loud 'snap'.
I checked the sprocket teeth and chain links and couldn't see any damage.
I've rotated the rear wheel a few times and the sprocket isn't rotating in a straight line. It wobbles slightly from left to right.
And I think the wheel does the same thing.
There was also a squeak coming from the wheel as well.
Any ideas?
Damon
PostPosted: 01:22 - 24 Dec 2011    Post subject: Reply with quote
Check the chain adjusters on each side. Are they at the same adjustment? Never heard the 8mm Allen key thing before... Do you have a link to the video?
Thanks,
Damon
GREENI3
PostPosted: 01:28 - 24 Dec 2011    Post subject: Reply with quote
Thanks,
Damon
The adjustment markers on each side of the swing arm are the same and I've also measured the length of thread on the adjusters and they too are equal.
https://www.youtube.com/watch?v=zB4DsHV8SAQ
Allen wrench is mentioned at 4:24.
I'm just slightly paranoid about the wheel being out of alignment and what the 'snap' might have been.
PostPosted: 02:53 - 24 Dec 2011    Post subject: Reply with quote
I have got no idea what you or that guy are yakking on about or what you've done or think you've done.
For all intents and purposes, your Lexmoto Street is just another CG-drivetrain-clone. Chain tension is covered here or a million other places.
The rear sprocket is connected to the sprocket carrier through rubber cush drives that give (and are designed to give) some, uh, give.
If the wheel is straight and the chain has the right amount of slack, and the rear sprocket isn't wobblier than a Greek government, then take the bike for a ride. If it feels OK, then it is OK. Stop worrying about it, it's fine.
totalllama82
PostPosted: 10:32 - 24 Dec 2011    Post subject: Reply with quote
Are you sure the spacers at each side of the spindle are seated correctly?
Does the wheel wobble when lifted up (paddock/centre stand)? If it does then the wheel bearings are a likely cause.
Is it only the rear sprocket thats moving about? It shouldnt move in and out as it should be held in place by the spindles tension.
Lets see some pictures of the setup - should help us diagnose the problem.
Gone: Haotian HT125-8 / Yamaha YZF 600R Thundercat / Kawasaki ZX9R C2
Current: Kawasaki ZZR 1400 A7F
GREENI3
PostPosted: 17:37 - 24 Dec 2011    Post subject: Reply with quote
This is the type of adjuster on my bike.
https://img824.imageshack.us/img824/5600/img0057ez.jpg
The wheel doesn't wobble when lifted up, but I can move the rear sprocket ever so slightly with a degree of strength.
I've also done a quick video of the wheel spinning.
https://www.youtube.com/watch?v=HqVLWhsY_HI
There's a click sound when the chain rotates past a certain point, not sure what it is though.
But it only happens when the wheel is rotated forwards and not backwards.
Raffles
PostPosted: 22:15 - 24 Dec 2011    Post subject: Reply with quote
That youtube clip shows us nothing. You need to shoot it again using a tripod or something similar to hold the camera steady.
mccluskeyd
PostPosted: 14:12 - 25 Dec 2011    Post subject: drive train.... Reply with quote
I would personally take the wheel off and the tensioners to see if there is a problem with the wheel spacers,or if the wheel bearings have been mis-aligned somehow ??
With the clicking - if you over tension a chain or mis-align it, it will give you this ; it needs to be set up correctly with the correct amount of play when you put it back together ; too tight and it will click and overstress the whole drive train, too slack and it will wear badly and may jump the sprocket in extreme cases.
Make sure when you take everything off ; you have all the parts in the one place & in clean conditions ; examine it all carefully & you will probably see any broken bits etc.
With these CG type rear sprockets, the four bolts that you can see go into rubber bushes in the wheel (cush drive) ; sometimes they split and make the sprocket wobble !!
All the best with it.
David.
PostPosted: 14:26 - 25 Dec 2011    Post subject: Re: Have I buggered up rear wheel bearing etc? Reply with quote
Putting a tool inbetween the chain and sprocket pulls the wheel forward so it's pressing against the adjusters - ensuring that when you tighten it, it's not moved off the adjusters.
This is a random example I founds on the 'nets.
https://www.miniriders.com/images/uploads/thump140/pitbikesetuptips/24239-achtung-noobs-your-new-pitbike-you-set-up-tips15.jpg
I suspect it was just the chain/tool moving slightly that you heard.
When you consider the forces on it doing a wheelie, say - it's unlikely you'll have damaged anything by doing this by hand. If you, it suggests it's quite likely to have failed pretty soon anyway.
(However, certainly does sound like there other issues.)
PostPosted: 15:23 - 25 Dec 2011    Post subject: Reply with quote
Your sprocket carrier will always have a little bit of movement both axially and radially since it's mounted on rubbers - that is normal for most bikes with some mileage on them.
If you have broken anything it will be either a chain sideplate or a cracked a roller. My money is on the sideplate. Small possibility you have broken a pin I guess but I've never seen a broken pin yet.
BTW there is no good reason to jamb a screwdriver in between the chain and sprocket like that. It puts an incredible strain on the chain. You can easily move the axle without doing , just gently nip up the bolt then knock the wheel forwards - I use a hammer on the tyre.
Walloper
PostPosted: 01:54 - 26 Dec 2011    Post subject: Reply with quote
Who wants to Twat that dude who's in his Mrs' Apron?
I had to turn the sound off.
Shocked
Youtube is so bifuffled by irritating cnuts.
PostPosted: 02:06 - 26 Dec 2011    Post subject: Reply with quote
Any basis for this?
I find it hard to believe it puts 'incredible strain' on the train, unless you do something very silly - not compared to what a chain generally has to deal with.
Walloper
PostPosted: 02:15 - 26 Dec 2011    Post subject: Reply with quote
G wrote:
Any basis for this?
I think it is the same as do not hammer a screwdriver through an oil filter.
1 because you may not have the correct filter to replace the one you just stabbed to death.
2 Yuo could stab through the filter and into something more vital like the sump or a hose.
The strain on the chain would probably not damage the chain but if a newish chain too much load could damage the race of the front sprocket or the rear.
It causes point loading that the chain and wheel are not normally subjected to.
Bumps in the road are absorbed by tyre and suspension.
If I were to use this method I would be careful and not put too much force on the chain. But not all folk are as competent as I am. Cool
PostPosted: 02:32 - 26 Dec 2011    Post subject: Reply with quote
I hammer screwdrivers into oil filters Smile.
(Well, if I don't have the correct tool handy, anyway.)
When accelerating hard, each link in a chain is going to be taking a hell of a lot of force.
I can't see a person turning the wheel back by hand to wedge it up against the blocks coming anywhere near the force needed to move a bike and rider to 60 in 3 seconds, nevermind when a bit more throttle is used and the front of the bike is lifted and held off the ground with said chain. Find it hard to believe that even with some force at a bit of a different angle it would do any damage when it should be able to take the above.
If you had an entirely alloy sprocket and really smashed it round, could see it possibly damaging that. But enough force to do that and you've probably already knackered your bike in several other ways Smile.
Robby
Dirty Old Man
PostPosted: 13:14 - 26 Dec 2011    Post subject: Reply with quote
The snap could have been because one of the end caps wasn't seated squarely on the end of the swingarm, and the snap was it rotating and seating into place under lots of pressure.
You need to put a lot of strain through a chain to break something. You would be putting quite considerable force through the adjuster to do so, difficult if you were using an allen key, it would be starting to hurt your hand. Was the chain really bowstring tight at this point?
Some clicking when rotating the wheel is not unusual, you have a chain rotating on sprockets, lots of contact points and lots of moving parts. I've had loads of bikes that do it with no problems in the drive chain.
If it is tensioned correctly, lubed up, and you can see no visible damage in the chain, then ride it and see. If there is a serious problem with the chain then it will become apparent and break in the first few miles. Make sure your chain guard is installed and don't try any top speed runs for 20 miles or so if you're not sure about it.
PostPosted: 14:20 - 26 Dec 2011    Post subject: Reply with quote
Britain's first jet (Gloser E28/39) made 850lbs of thrust. Ducati 1198 manages around 950lbs peak in first gear.
OK not entirely comparable, but find it hard to believe that a chain designed to take that is going to have issues being turned by hand with a screwdriver stuck in it!
Walloper
PostPosted: 20:08 - 26 Dec 2011    Post subject: Reply with quote
Freewheel sticking???
Thinking
Very Happy
GREENI3
PostPosted: 22:24 - 26 Dec 2011    Post subject: Reply with quote
Well I think I've found out whats causing the clicking; from what I can see, it's the split link brushing against one of the screws on the chain guard, which may suggest a misaligned wheel?
Walloper
PostPosted: 16:00 - 27 Dec 2011    Post subject: Reply with quote
Well you single-handedly just ruined our Christmas celebrations worrying about what it could be...
Sad
Smile
Google
https://www.google.com/search?client=gmail&rls=gm&q=motorcycle%20wheel%20alignment
PostPosted: 16:21 - 27 Dec 2011    Post subject: Reply with quote
Yes, or a bent chain guard mount or an over long bolt used to mount the chain guard.
Take next to no notice of the marks on the swinging arm when checking alignment. They can easily be way out. A couple of long straight edges held against the side of the rear wheel and with the gap either side of the front wheel checked (ie, with the bars straight the gap should be the same either side of the front wheel).
PostPosted: 19:15 - 27 Dec 2011    Post subject: Reply with quote
Vincent wrote:
It may fit where the chain meets the sprocket but if you turn the wheel, as the screwdriver gets to the back of the sprocket, it'll be stretching the chain even further and, if there's not enough slack, something will go bang, wether it be the chain, sprocket bearing, rear wheel bearing or whatever.
The whole point is to turn it until it pulls the wheel onto the stops and hold it there.
However, if a chain is designed to take over 950lbs of force at the wheel, I find it very hard to believe a person turning it by hand would manage to stretch it - and if they could, perhaps a better quality chain is needed? And of course this is presuming someone is doing it absolutely as hard as they could - which is like saying you shouldn't use a spanner because it's possible to horribly over-tighten a bolt with a spanner.
PostPosted: 21:29 - 27 Dec 2011    Post subject: Reply with quote
Vincent wrote:
Dunno, you've got a lot of leverage on that wheel.
But you don't have to use it.
However, still reckon not near enough to damage a half decent motorbike chain - if you're worried about it, I certainly wouldn't want to be riding it!
If it was, say, a mountain bike chain on a motorbike - I could understand.
The last post was made 14 years, 252 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 130.04 Kb
