Axle nut tightness
nutter
PostPosted: 23:02 - 24 Dec 2011    Post subject: Axle nut tightness Reply with quote
Hello
I really need to adjust my chain as its very loose, which wouldn't be a problem on my cbr 125 as they do a haynes manual
Now I have a kawasaki ZR7, no manual (nothing from previous owner) and need to know how tight the axle nut needs to be after adjusting the chain, preferably in NM as this is what my torque wrench works in. I'm waiting for a manual from the US but I need to ride the bike to work on boxing day and its very loose
Is there a general torque that can be considered generic or is every bike different?
Many thanks
Mark
Current bike is kawasaki ZR7 - Previous is CBR 125 (40,000 long long miles). Mod 2 passed 11/08/11 - Hope to become an instructor
robocog
PostPosted: 23:53 - 24 Dec 2011    Post subject: Reply with quote
What size bolt?
(shaft and head diameter)
Armed with that info ..
https://www.engineershandbook.com/Tables/torque.htm
or
https://www.cncexpo.com/MetricBoltTorque.aspx
or
https://www.cncexpo.com/MetricBoltTorqueNm.aspx
(as you wanted NM)
Regards
Rob
Needs a bigger garage...
robocog
PostPosted: 00:07 - 25 Dec 2011    Post subject: Reply with quote
https://www.scribd.com/doc/19825977/ZR7
Is this the manual?
If so...
Front is 98 N-m
Rear is 110 N-m
Regards
Rob
nutter
PostPosted: 00:17 - 25 Dec 2011    Post subject: Reply with quote
22/23mm head using adjustable spanner and tape measure (you can see what your dealing with lol).
EDIT
thanks to yours and my dads help we think we've figured it out lol. Its got split pin so there's little chance of the wheel coming off....I sound so thick lol
2ND EDIT
Thank you so much Rob
Thats the sports version but its as good as the same bike chassis wise. We had thught, through the tables extra that it was up near 220lb/ft, 110NM sounds a lot softer, my cbr 125 was 69NM
3RD EDIT :/
After converting it all back to lb/ft (i actually looked at the torque wench to find it different) I have settled on the correct figure from what you've found for me and what my dads told me
MANY THANKS ROB, and merry xmas
PostPosted: 11:12 - 25 Dec 2011    Post subject: Re: Axle nut tightness Reply with quote
I wouldn't overly worry -lots of people just do them up "pretty damn hard" and don't suffer ill effects.
The usual ratings (80-150) still really aren't THAT tight and generally they don't seem to suffer from someone with a big spanner putting a decent bit of force on them.
nutter
PostPosted: 17:52 - 25 Dec 2011    Post subject: Reply with quote
Well I tried it today as I could see what I was doing, and it appears the adjustment nut is locked somehow that I can't see. On my 125 it was a locking nut so was easy, so I'm taking it into my local garage and ask if they can show me whats going wrong as i started rounding off the nut.
shaft drive all the way from now on I think....just another excuse to get a BMW R1200RT lol
PostPosted: 18:04 - 25 Dec 2011    Post subject: Reply with quote
A picture, maybe?
PostPosted: 18:46 - 25 Dec 2011    Post subject: Reply with quote
Adjustable spanner is a cannibal's tool - you'll do damage every time you put it on a nut or bolt. Even a cheap ring/combination spanner is beter than using one of those.
nutter
PostPosted: 20:20 - 25 Dec 2011    Post subject: Reply with quote
I know, thanks though, I was just using it to get the measurement of the bolt head A/F because I had no idea.....and then i found the tape measure.
Here is a picture. Sorry its not the clearest but it was taken on my phone. it appears to only have one adjustment screw (rather than the adjustment one and a locking nut) and there are two tiny holes around the axle thread (in the middle of the metal guide bit), one at the top and one at the bottom
When I mentioned my chain to the garage (i thought it was a bit loose even though they said it was fine as its a bigger bike) they said i need a special tool, but i though this would have been for for the split pin. It will be friday before I can get it up the garage which means at least 80 miles on a very loose chain (you can see the sag)
Many thanks
Mark
PostPosted: 21:11 - 25 Dec 2011    Post subject: Reply with quote
Okay, firstly there is no lock-nut for that adjuster, it just pulls up tight on the endcap. Many people swap the nuts for nylock nuts to stop them self-loosening.
Secondly, you appear to be close to, if not at, the maximum adjustment for your chain. The carrier is covered in chain grease as is the outside plates of the cahin but there seems to be little or none on the rollers themselves. Going by the way the side of the wheel spoke has grease sprayed on it, I would guess that you are used to greasing the chain by spraying the area of the carrier, you should improve your chain lubing technique to get better coverage on the chain and less where it's not needed.
Thirdly, judging by the way the plate is dished, that bolt has been seriously over-tightened in the past.
The last post was made 14 years, 275 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 66.95 Kb
