CBR600FW brake light
arry
PostPosted: 16:44 - 28 Dec 2011    Post subject: CBR600FW brake light Reply with quote
Hi Smile
Noticed today after a ride that it appears the microswitch in the brake lever up front has gone intermittent - works on occasion but then doesn't every so often, or lights the brake light for a split second before it goes out again.
Connections all seem to be tight and clean. Would this point towards a dodgy switch and how difficult is it to replace / come by a replacement part?
Cheers Smile
dodgydog
PostPosted: 17:35 - 28 Dec 2011    Post subject: Reply with quote
I'd try giving it a good spray inside the switch with something like electrical contact cleaner first.
Dog
I know that you believe that you understood what you think I said, but I am not sure you realise that what you heard is not exactly what I meant
arry
PostPosted: 17:42 - 28 Dec 2011    Post subject: Reply with quote
Dog
Cheers. I take it I'm right that it's the bit behind the sort of black dust cover that the level pin makes contact with and pushes in?
Do I just pull the dust cover to one side and give it a squirt?
Chris750
PostPosted: 18:17 - 28 Dec 2011    Post subject: Reply with quote
In my experience the switch is very easy to change for bikes I have done this on.
They are often fairly generic parts that can be picked up from most bike shops. They can usually be bought cheaper via the internet but with post this time of year, delivery times will be unpredictable.
Test voltage both sides of the switch, one will normally be 0 and other 12 ish.
If you remove the cables from the switch and touch them to each other and the light comes on each time it is definately the switch.
For the price of a switch I usually changed them rather then attempt to get them working as they inevitably die from time to time through age and wear.
I had a dodgy rear brake light switch which needed replacing and I kept putting it off. Eventually it shorted out and melted while it was stood with the ignition switched on.
Current Rides: GSXR-750 WS, GSXR-1000 K5, KTM EXC 300
arry
PostPosted: 18:25 - 28 Dec 2011    Post subject: Reply with quote
Thanks for the advice. Think you're probably right, for the sake of a few quid it's not worth its failure to perform.
I'll get one on order Smile
The last post was made 14 years, 252 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 44.49 Kb
