dirt in engine
flumpy7
PostPosted: 16:17 - 29 Dec 2011    Post subject: dirt in engine Reply with quote
Hi guys
May be a stupid question but i guess if you dont ask you never know. I was doing the valve clearances today on a suzuki gsx750f that i inherited from a mate. Anyhow, the valve cover was a motherf**ker to get off and out of the frame due to its close proximity to the carbs and me not wanting to take the carbs off. Having finally managed it - albeit a bit violently - there appears to be some small bits of grit or sediment around the valves and cams etc... Im wondering whether maybe this happened as a result of me manhandling the cover off a bit enthusaistically and disturbing some dirt that was on the cover/frame etc...
The question is, is a few small specs of dirt and grit cause for concern or can i just put the cover back on and forget all about it?
2012 Sinnis apache
The Artist
PostPosted: 16:31 - 29 Dec 2011    Post subject: Reply with quote
Most likely no, but if you can get it out, then do.
MickC
PostPosted: 16:51 - 29 Dec 2011    Post subject: Reply with quote
If it's an old bike then it could be build up from age. Remove as much of it as you can, then flush the engine. remove the sump plate and clean any crud out from it, check the oil strainer is free from crud as well. Give it a new oil filter and fresh oil (change after 500 miles - there will be leftover flush in the engine that will dilute your oil)
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
The last post was made 14 years, 270 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 35.48 Kb
