fzr 400
helenexup
PostPosted: 19:49 - 29 Dec 2011    Post subject: fzr 400 Reply with quote
hi everyone need a bit of help im a new biker just bought an fzr 400 exup 3tj and wondered if i would be able to change the clocks on it to mph ones if anyone could help i would be grateful cheers Laughing
PostPosted: 19:52 - 29 Dec 2011    Post subject: Reply with quote
Ebay kmh to mph converter, should make it read MPH
Failing that a sticker can be put over the clocks Thumbs Up
PostPosted: 21:44 - 29 Dec 2011    Post subject: Reply with quote
Buy stickers and do it that way. If you change the clocks everyone will think that it was done to hide the true mileage of the bike. Mileage converters also have the same issue.
PostPosted: 12:41 - 30 Dec 2011    Post subject: Reply with quote
Pretty much agree with the above. There are people around who can modify clocks to put on a better looking MPH dial.
You might be able to use the clocks from an FZR600, but in addition to the hassle mentioned above with losing the original mileage you might have problems with the speed restrictor on Japanese market bikes. Generally limited to 180kmh (112mph), these often use a sensor in the speedo, so the wiring might well not match up. Also on some bikes they really don't like it if the sensor for this is disconnected - the CBR250 will land up losing a LOT of its top speed although not sure if the FZR does.
Al
PostPosted: 13:16 - 30 Dec 2011    Post subject: Reply with quote
On the 3tj speedo it sends a signal at start up and another when it reaches 112mph, if it doesn't receive the signal at start up it sets a rev limit at 12,500rpm so you can't simply unplug it, I'd go with the stickers like others have said.
Mines a 4dx model so I don't have that problem however when I removed my exup valve it didn't like it and put it into some kind of safety mode with an 8000rpm limit.
Yamaha FZR400RR 3tj
My Instagram Thingy
helenexup
PostPosted: 18:12 - 30 Dec 2011    Post subject: Reply with quote
thanks for you help guys looks like i might be staying with the stickers Sad
TUG
PostPosted: 00:31 - 31 Dec 2011    Post subject: Reply with quote
There are some UK Spec clocks but they will be so over priced it wont be worth it, just find the speedo converter on ebay, IIRC it fits at the base of the fork leg instead of the clocks like it did on my 3EN1.
Haz ER-5, innit!
The last post was made 14 years, 291 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.37 - MySQL Queries: 13 - Page Size: 51.6 Kb
