Im talking 'bout the BAD vibrations....
richie....
PostPosted: 23:08 - 01 Jan 2012    Post subject: Im talking 'bout the BAD vibrations.... Reply with quote
Well, as you may know, i have a Suzuki GS125 on a T plate with about 13,500 miles.
Its vibrating quite bad, its fine if you go easy, i.e ride proplerly upto 30 in 5th, but if i pull away in first, into second, as the revs get higher, its get worse.
Im starting to think it could be an engine bearing, the vibration feels like its coming from the engine, all the bolts around it are tight and i can feel the vibrations worse from the foot pegs upto the handle bars.
can anyone shed some light over this issue?
im worried about the bike going pop and i rely on it for work.
cheers guyts.
JoeDougieDoug...
PostPosted: 23:13 - 01 Jan 2012    Post subject: Reply with quote
You're doing 30mph in 5th gear??
And check the tyre pressure - That can result in bad vibration. Thumbs UpSmile
richie....
PostPosted: 23:17 - 01 Jan 2012    Post subject: Reply with quote
yea just cruising lol, aii i will do in the morn, the lad did pump them up with a car pump as i went to take a look, ill try at the garage in the morning.
richie....
PostPosted: 23:27 - 01 Jan 2012    Post subject: Reply with quote
hahadumball wrote:
Check the dildo switch is set to off.
ahhhh yes, the dildo switch. i did buy it from a woman....
hmmmmm
PostPosted: 00:58 - 02 Jan 2012    Post subject: Reply with quote
Is there timing on these liike the rs/ mitos?? But tyre pressure quick and easy check 1st eliminate that
JoeDougieDoug...
PostPosted: 14:22 - 02 Jan 2012    Post subject: Reply with quote
I'm fairly interested to see how this one plays out - Let us know what it was when you find out. Smile
richie....
PostPosted: 17:53 - 02 Jan 2012    Post subject: Reply with quote
well ive done the tyres, its helped a bit like (aswell as better handling andmore speed, obviously, waxs only 20PSI in them lol)
as doing the tires, i noticed that the rubber from the air filter to the carb hasnt got a jubilee clip on and its practically come off so obviously, the engine isnt running as it should!
illlet you know what happens when i sort this out later on back at home!
jimmyRS
PostPosted: 20:01 - 02 Jan 2012    Post subject: Reply with quote
a loose air filter wouldnt cause these bad vibrations your on about, although definitely fix that.
So the vibrations only happen when you increase rpm? not speed? In which case why bother with checking the tyres and wheel bearings? And bad timing also wouldn't make it vibrate like crazy; just run shit.
I know youve said you've checked all engine mounts and they're secure, but check where the mounts are actually welded onto the frame/cradle, no cracks or splits in them? I had a similar problem and that was the cause of it.
No knocking from the bottom end at all? Chain tensioned correctly? Sprockets and chain aren't worn?
Smile
Mikey3
PostPosted: 22:52 - 02 Jan 2012    Post subject: Reply with quote
Smile
always good to do some preventive maintenance on the tyres and bearings anyway Wink if he's not sure what they are it might be worth finding out, before another vibrative post :p
and if its the chain and sprockets revving wouldnt have any effect, but still worth checking :p
crankshaft/big end bearings... perhaps? higher the revs the more the vibration? and not speed related... guess its possible :/
'04 Yamaha WR450F
'99 SV650 Streetfighter Project - mid build
'Motorcycling is about what you do; not about what you own, or how much you spend on it'
hadden
PostPosted: 23:42 - 02 Jan 2012    Post subject: Reply with quote
i wanted a mechanic to rebuild my rs 125 engine just because i didn't want to fuck about with timing and he told me "its a 2 stroke.they don't have timing" so im in the process of doing it myself.please don't tel me there is!!!!
red bull gives you wing sting!!!
current:aprilia rs 125
previous:honda c90,honda cm 125,yamaha xt 550,2004 suzuki drz 400.(all used for off road back in the day)and a piagio zip 50cc..oooossssshhhh
jimmyRS
PostPosted: 23:52 - 02 Jan 2012    Post subject: Reply with quote
true dat
Sprocket attached to drive shaft in bottom end, if thats vibrating alot more than likely the chain'll be worn a fair bit more running round that front sprocket Razz
ditto
hate to be the bearer of bad news: there is.
Mikey3
PostPosted: 00:07 - 03 Jan 2012    Post subject: Reply with quote
[quote="mredhead"]
its the 3rd shaft after the crank, input shaft, and the output shaft which connects to the sprocket, which would be the gearbox, which doesn't reciprocate as much as spins, so the changing of direction which causes vibration isn't there.
this is reminding me of our facebook chat earlier :p
'04 Yamaha WR450F
jimmyRS
PostPosted: 00:10 - 03 Jan 2012    Post subject: Reply with quote
lol nout to do with input/output etc. If the engines vibrating enough to send it all the way through the frame to the pegs and up to the bars then it'll definitely be putting it through the sprocket/chain
n yeah aha ;D
Mikey3
PostPosted: 00:14 - 03 Jan 2012    Post subject: Reply with quote
n yeah aha ;D
But isn't that an effect more than a cause? Wink
'04 Yamaha WR450F
jimmyRS
PostPosted: 00:17 - 03 Jan 2012    Post subject: Reply with quote
course, but what im gettin at is if that chains worn and slipping around on the sprocket, or vice versa, thats not gonna help at all with vibrations Razz
Mikey3
PostPosted: 00:34 - 03 Jan 2012    Post subject: Reply with quote
true... but perhaps very minor.
i shall dub this: productive bickering Wink
'04 Yamaha WR450F
richie....
PostPosted: 00:36 - 03 Jan 2012    Post subject: Reply with quote
Well, carbs done, there a pain aint they?
Anways, we may have an answer.....the bikes a bodge.
Guy i bought it off said it had been powder coated but its been slung back together, random size bolts, tank having NO bolts in it, rubbers around fittings missing......
Also, the chain and sprokets look past it.
Are they easy to do, i mean i know how to do it, ot just getting the rear wheel true again...
jimmyRS
yeah back down bitch
I'm smart, you're dumb; I'm big, you're little; I'm right, you're wrong, and there's nothing you can do about it.
much love mike Wink
getting the rear wheel aligned is piece of piss, various methods of doing it but refer to your manual for that bike for their preffered step-by-step Razz
and the fact its missing rubber on the fittings would definitely be a problem. Good luck with fixing it Smile
richie....
PostPosted: 00:49 - 03 Jan 2012    Post subject: Reply with quote
cheers, need to het haynes first, could do with cables aswell, rear fairing is smahed and the headlights a mess, yeah £560 gone good lol.
I bought it to my test to sell on but feel its far too tatty to sell on for decent money back....
jimmyRS
PostPosted: 00:52 - 03 Jan 2012    Post subject: Reply with quote
nah it'll be worth it in the long run Smile good to get to know the bike and do a bit of problem solving, itll help down the line Razz
as for getting your money back, maybe not, just stick to a tight budget and if you're not in a hurry to sell it you should atleast break even Smile
reminds me when i picked up my rs50 project bike, the guy wanted 500 initially, ended up riding it away for £190 aha! But its definitely been a project and a half, and still is Razz
Mikey3
PostPosted: 00:54 - 03 Jan 2012    Post subject: Reply with quote
that would look like we have a winner!
and jamie - see the following
'04 Yamaha WR450F
jimmyRS
PostPosted: 01:05 - 03 Jan 2012    Post subject: Reply with quote
LOL, love that man
heres one for you Wink
much love
Mikey3
PostPosted: 01:11 - 03 Jan 2012    Post subject: Reply with quote
much love mike
i don't beleive i'm the one with the ego problem Wink
we should stop now...
'04 Yamaha WR450F
The last post was made 14 years, 144 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 2.82 - MySQL Queries: 13 - Page Size: 134.2 Kb
