| richie.... |
 richie.... Renault 5 Driver
 Posted: 23:08 - 01 Jan 2012 Post subject: Im talking 'bout the BAD vibrations.... |
Well, as you may know, i have a Suzuki GS125 on a T plate with about 13,500 miles.
Its vibrating quite bad, its fine if you go easy, i.e ride proplerly upto 30 in 5th, but if i pull away in first, into second, as the revs get higher, its get worse.
Im starting to think it could be an engine bearing, the vibration feels like its coming from the engine, all the bolts around it are tight and i can feel the vibrations worse from the foot pegs upto the handle bars.
can anyone shed some light over this issue?
im worried about the bike going pop and i rely on it for work.
cheers guyts. |
| JoeDougieDoug... |
 JoeDougieDoug... World Chat Champion
 Posted: 23:13 - 01 Jan 2012 Post subject: |
You're doing 30mph in 5th gear??
And check the tyre pressure - That can result in bad vibration.   ____________________ CBT Passed - 22 / 10 / 11 >> Theory Passed - 16 / 02 / 2012 >> Mod 1 Passed - 07 / 03 / 2012 >> Mod 2 Passed - 18 / 05 / 2012. |
| richie.... |
| Pol Anorl |
 Pol Anorl Banned
 Posted: 23:22 - 01 Jan 2012 Post subject: |
Check the dildo switch is set to off. ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
20:30:37 Pyro.: I don't sort of like men, I take every advantage to choke on dick.
Jewlio Iglesias: You live in Liverpool - Chances are, the front door has already been kicked off the hinges |
| richie.... |
| Pol Anorl |
 Pol Anorl Banned
| hmmmmm |
 hmmmmm Two Stroke Sniffer
| JoeDougieDoug... |
 Posted: 14:22 - 02 Jan 2012 Post subject: |
I'm fairly interested to see how this one plays out - Let us know what it was when you find out.  ____________________ CBT Passed - 22 / 10 / 11 >> Theory Passed - 16 / 02 / 2012 >> Mod 1 Passed - 07 / 03 / 2012 >> Mod 2 Passed - 18 / 05 / 2012. |
| richie.... |
| jimmyRS |
 jimmyRS Scooby Slapper
 Posted: 20:01 - 02 Jan 2012 Post subject: |
a loose air filter wouldnt cause these bad vibrations your on about, although definitely fix that.
So the vibrations only happen when you increase rpm? not speed? In which case why bother with checking the tyres and wheel bearings? And bad timing also wouldn't make it vibrate like crazy; just run shit.
I know youve said you've checked all engine mounts and they're secure, but check where the mounts are actually welded onto the frame/cradle, no cracks or splits in them? I had a similar problem and that was the cause of it.
No knocking from the bottom end at all? Chain tensioned correctly? Sprockets and chain aren't worn?
| Mikey3 |
 Mikey3 World Chat Champion
| hadden |
 hadden Trackday Trickster
| jimmyRS |
 Posted: 23:52 - 02 Jan 2012 Post subject: |
| mredhead wrote: |
always good to do some preventive maintenance on the tyres and bearings anyway  if he's not sure what they are it might be worth finding out, before another vibrative post :p |
true dat
| mredhead wrote: |
and if its the chain and sprockets revving wouldnt have any effect, but still worth checking :p |
Sprocket attached to drive shaft in bottom end, if thats vibrating alot more than likely the chain'll be worn a fair bit more running round that front sprocket
| mredhead wrote: |
crankshaft/big end bearings... perhaps? higher the revs the more the vibration? and not speed related... guess its possible :/ |
ditto
| hadden wrote: |
i wanted a mechanic to rebuild my rs 125 engine just because i didn't want to fuck about with timing and he told me "its a 2 stroke.they don't have timing" so im in the process of doing it myself.please don't tel me there is!!!! |
hate to be the bearer of bad news: there is. |
| Mikey3 |
| jimmyRS |
| Mikey3 |
| jimmyRS |
 Posted: 00:17 - 03 Jan 2012 Post subject: |
course, but what im gettin at is if that chains worn and slipping around on the sprocket, or vice versa, thats not gonna help at all with vibrations  |
| Mikey3 |
| richie.... |
| jimmyRS |
 Posted: 00:36 - 03 Jan 2012 Post subject: |
| mredhead wrote: | | jimmyRS wrote: | course, but what im gettin at is if that chains worn and slipping around on the sprocket, or vice versa, thats not gonna help at all with vibrations  |
true... but perhaps very minor.
i shall dub this: productive bickering  |
yeah back down bitch
I'm smart, you're dumb; I'm big, you're little; I'm right, you're wrong, and there's nothing you can do about it.
much love mike
| richie.... wrote: | Well, carbs done, there a pain aint they?
Anways, we may have an answer.....the bikes a bodge.
Guy i bought it off said it had been powder coated but its been slung back together, random size bolts, tank having NO bolts in it, rubbers around fittings missing......
Also, the chain and sprokets look past it.
Are they easy to do, i mean i know how to do it, ot just getting the rear wheel true again... |
getting the rear wheel aligned is piece of piss, various methods of doing it but refer to your manual for that bike for their preffered step-by-step
and the fact its missing rubber on the fittings would definitely be a problem. Good luck with fixing it  |
| richie.... |
| jimmyRS |
 Posted: 00:52 - 03 Jan 2012 Post subject: |
nah it'll be worth it in the long run good to get to know the bike and do a bit of problem solving, itll help down the line
as for getting your money back, maybe not, just stick to a tight budget and if you're not in a hurry to sell it you should atleast break even
reminds me when i picked up my rs50 project bike, the guy wanted 500 initially, ended up riding it away for £190 aha! But its definitely been a project and a half, and still is  |
| Mikey3 |
| jimmyRS |
 Posted: 01:05 - 03 Jan 2012 Post subject: |
LOL, love that man
heres one for you
much love |
| Mikey3 |
The last post was made 14 years, 146 days ago. Instead of replying here, would creating a new thread be more useful? |
