Legality of riding bike like this
wilz1234
PostPosted: 15:01 - 03 Jan 2012    Post subject: Legality of riding bike like this Reply with quote
So, basically my cbr tail fairing on my zxr400 decided it wasn't happy with itself and ditched my tail lights and numberplate while riding.
This week i'm meant to be taking the bike to a dyno place to have the carbs set up.
Is it going to be a problem to ride with no tail fairing, rear indicators, and with the numberplate strung onto my backpack.
truslack
PostPosted: 15:04 - 03 Jan 2012    Post subject: Reply with quote
Yes. It's illegal. Fix it. Rolling Eyes
JoeDougieDoug...
PostPosted: 15:05 - 03 Jan 2012    Post subject: Reply with quote
Doesn't a road-worthy bike have to have both sets of indicators fully functional? I suppose you could indicate with your arms... failing that, rebook your dyno test and get your bike fixed up again.
Teflon-Mike
tl;dr
PostPosted: 15:07 - 03 Jan 2012    Post subject: Re: Legality of riding bike like this Reply with quote
Yes; number-plate LEGALLY needs to be attached to the bike.
We had this 'debate', with a Learner who had attached his L-Plates to a Hi-Vis rather than the bike.... his logic was impeccable, if he was 'On' the bike, and the L-Plate on HIM then the L-Plate was 'on' the bike, wasn't it?
Instructing Bike Cop, however, had alternative interpretation; and that under RTA, defanition of what ought to be attached to the 'vehicle', meant 'to the vehicle' not something carried ON the vehicle...
Lack of tail-lamp, (& Indicators?) if you have front lamps and front indies, and the switch, then its an obviouse vehicle 'Defect' there not being there.
If you got stopped; think it would depend on the coppa's mood whether you got a 'little word' or a rectification notice, or worse.
Worth the risk?
wilz1234
PostPosted: 15:12 - 03 Jan 2012    Post subject: Reply with quote
I was worried that would be the case Sad
I could mount the numberplate without too much hassle I guess.
So you need tail lights if you have front lights? I know it may seem stupid, but could i not just remove the front lights as well and ride during daytime.
Bezzer
PostPosted: 15:19 - 03 Jan 2012    Post subject: Reply with quote
Nope, you have to have no lights AND no switches etc, if you've got part of a lighting system then it all has to work. Why don't you just cancel the dyno, sort it out properly then go to the dyno because you can't be out riding it legally anyway the state it's in.
Teflon-Mike
tl;dr
PostPosted: 15:31 - 03 Jan 2012    Post subject: Reply with quote
You can get an MOT under exemptions for a machine 'adapted' for off-road use, provided it has a solo seat, no pillion accomodation (pegs, seat, grab-strap); no lights, front or back, but importantly no switches for them.
THAT is the MOT rules.
Road Traffic Act reverts to the C&U regulations; and what equipment is mandated for a production motorcycle.
THEN if you were to 'adapt' part way through an MOT period you would be in a grey area, as if it was tested with lights, then removing them, or having them non-functioning, would be a 'vehicle fault', as they WERE there when tested.
Bottom line is YOU know, and WE know you have a bike that is defective, and not in a road-worthy condition; any plod that stopped you would also know that, and you are merely looking for a loop-hole to get round riding an unroadworthy vehicle, on the road....
Loop-hole is there; BUT to be 'in the clear' to use it; you would have to do full 'off-road' converstion and probably re-MOT the bike to validate it..... OR fix it up to as MOT'd standard with lamps.
Anything in between, you are on shakey ground; and best; you dont get stopped, or get stopped & let off with a word; worst they sieze the vehicle as 'Dangerouse & Unroad worthy'... most likely a rectification notice; possibly a fine & points for non regulation number-plate (as they seem to like that one)
Back to you? Is it worth it, for the sake of a phone call to change the Dyno date?
wilz1234
PostPosted: 15:35 - 03 Jan 2012    Post subject: Reply with quote
Cheers for the quick responses. I guess itll have to wait till summer Sad
bazza
PostPosted: 15:35 - 03 Jan 2012    Post subject: Re: Legality of riding bike like this Reply with quote
You won't get points and a fine for not having your carbs set up. You figure out what you need to do..
truslack
PostPosted: 15:38 - 03 Jan 2012    Post subject: Reply with quote
Have you got a reference for that rule?
Teflon-Mike
tl;dr
PostPosted: 15:49 - 03 Jan 2012    Post subject: Reply with quote
Nope; it's somewhere in the MOT testers hand-book; if there's a switch for indies or lights; the lights must be there. Think it's echoed somewhere in the C&U regs and lighting amends; possibly in the VOSA Single-Vehicle-Approval guide-lines.
As far as we are concerned; if you want to get an MOT under 'off-road' exemption; handle-bar switches for head-lamps & indies must be removed entirely, or from the cluster, 'blanked' or taped over so as to be 'inoperable'.
PostPosted: 15:51 - 03 Jan 2012    Post subject: Reply with quote
You'll see at the all you can eat... no you dont Laughing
OP, you dont "need" lights at all. You would need to tape over the remaining lights, switches and whatever else.
To pass an MOT you need a reg plate, horn and a rear reflector I think.
Make sure your plate is mounted and ride it. I ride mine currently with no fairings and that means no indicators.
PostPosted: 16:01 - 03 Jan 2012    Post subject: Reply with quote
Not sure there is anything about the switch needing to be there.
Regulations basically depend on the existence of any lamp, and a rear position lamp is compulsory without any exceptions under the C&U rules (except that the C&U rules do not apply to any vehicle that has no lighting). Have one of those and the rest become mandatory (including the front position lamp).
No tail light means no rear position lamp hence an easy nicking.
Teflon-Mike
tl;dr
PostPosted: 16:03 - 03 Jan 2012    Post subject: Reply with quote
I think that bikes first used after 1986 require Indicators under the Construction & Use regulations, AND are a requirement for MOT.
They may only be 'removed' if the vehicle is 'adapted primerily for off-road use', where the exemption applies.
Also a grey area for bikes built before 1986, where indicators were fitted as 'standard'; technically as original equipment, a pedantic MOT man can insist they ought to be there and be functional.
The rest is down to interpretation; YOU may interpret it to mean that lack of indies doesn't make the bike un-roadworthy; and site the 'off-road adaptation' precedent; but plod; not known for giving the benefit of the doubt would probably not accept it; and if you pressed 'off-road adaptation', start querying the other requirements of the exemption, and suggest that IF as it stands at the side of the road bike would not pass an MOT, then it was not road-worthy.
PostPosted: 16:12 - 03 Jan 2012    Post subject: Reply with quote
You do not need an off road exemption. That does allow some things (such as having lights but no indicators), but the MOT rules allow a bike to pass if it has no lights (including and especially no front or rear position light) irrespective of whether it is an off road bike or not, or the date it was first registered as do the C&U rules.
Whether there is another older regulation still on the books mandating lights is another question (ie, something to match up with the MOT comment on bikes from before 1931 not needing a headlight).
PostPosted: 16:14 - 03 Jan 2012    Post subject: Reply with quote
Quite happily put the 06 CBR125 in my sig through the MOT with no indicators, track bikes can also be put on the road with no lights... Also putting the CX50 in the MOT with no indicators or lights Laughing
PostPosted: 16:33 - 03 Jan 2012    Post subject: Reply with quote
As it isn't an off road bike and it still has the other lights then it should have failed.
kestrel
PostPosted: 16:37 - 03 Jan 2012    Post subject: Reply with quote
An MOT is a basic inspection to determine that a vehicle is safe for use on the road, it does not mean that the vehicle is road legal, in accordance with the Construction and Use Regulations.
Isle of Man.........Road Racing Capital Of The World
Tarmacsurfer
Tef, I'm astounded. Those have to be your shortest posts ever Shocked
I'm immortal. Well, so far.
PostPosted: 16:41 - 03 Jan 2012    Post subject: Reply with quote
Taped up by MOT place... might be a very flexi tester but has passed nearly everything I threw at him.
That said, GSXR has no indicators on the front currently as they are attached to fairings which are unmountable.
That illegal? Neutral
PostPosted: 16:44 - 03 Jan 2012    Post subject: Reply with quote
In which case he has given you a daytime MOT with the other lights being irrelevant as they are classed as being taped up. Take the tape off and without working indicators it should fail and is also not legal under C&U.
As to the GSXR, yes that is an offence by not complying with C&U. Which you could get round by taping up / removing all the other lights and not using it at night / when visibility is dodgy.
PostPosted: 16:49 - 03 Jan 2012    Post subject: Reply with quote
Thumbs Up Insightful.
Commute to work in the dark Thumbs Down I have a feeling im going to have to really badly mount 2 indicators on the nose cone... great Laughing
wilz1234
PostPosted: 16:59 - 03 Jan 2012    Post subject: Reply with quote
So this is all i need to do to get my bike to the dyno place....?
"Sorry officer, it just fell off, but I did my best with the numberplate." Smile
PostPosted: 17:11 - 03 Jan 2012    Post subject: Reply with quote
You need the numberplate attached properly and would need all the lights taped up / removed (well, technically you could get away with a brake light, but as those tend to be built into tail lights they would probably just treat that as a non working rear position lamp being fitted, and if fitted all the others would be mandatory).
But have a real think about whether you want to ride a bike without lights at this time of year (when visibility is poor much of the time, and dark will fall rapidly) even if it can be technically legal.
The last post was made 14 years, 317 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.10 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 141.63 Kb
