Stuck Mirrors
QM
PostPosted: 20:53 - 03 Jan 2012    Post subject: Stuck Mirrors Reply with quote
I need to adjust my mirrorrs on my hornet but the stems have seized up and I cannot losen them off. I have tried soaking with WD40 and tapping them with a mallet but they will not release.
Anyone got any ideas?
05 Honda CG125 now 03 Honda CB600F Hornet
ninja_butler
PostPosted: 22:05 - 03 Jan 2012    Post subject: Reply with quote
When you say you tapped them with a mallet, do you mean you put a spanner on the base of the stem and tapped the spanner? One little hit should be enough to free them up.
QM
PostPosted: 22:07 - 03 Jan 2012    Post subject: Reply with quote
Thats what I did sorry if it wasn't clear.... I can loosen the top nut but not the lower one that the stem goes into.
ninja_butler
PostPosted: 22:23 - 03 Jan 2012    Post subject: Reply with quote
Did you use a rubber mallet or a steel mallet? Rubber mallets are very useful but a metal mallet or hammer will give more impact. The force should be more than enough to shock it free.
(edit)
I can't remember what the mirror stem actually looks like on the Hornet, I was assuming that it's got a hexagonal base so you can grip it with a spanner but I could be wrong.
Don't worry, I'm sure Teflon Mike will come along in a minute and say something like "pour some diet cola on it and it'll pop right out". He usually knows how to fix everything.
https://i1213.photobucket.com/albums/cc469/Ninja_Butler/random/hondahornetmirror.jpg
QM
PostPosted: 06:34 - 04 Jan 2012    Post subject: Reply with quote
I did use a hammer on it but it won't budge. As for the mirror its a 2003 model which is similar to the one in picture apart from the miror being rectangular not round.
ninja_butler
PostPosted: 09:56 - 04 Jan 2012    Post subject: Reply with quote
Have you got a bit of metal tubing around - like a metal table leg or something? You can use it as an extension bar on the spanner to give you more leverage but be careful not to snap the thread on the mirror stem or you'll have to mill it out.
yen_powell
PostPosted: 19:03 - 04 Jan 2012    Post subject: Reply with quote
Don't assume it's a normal thread. Some mirrors have left hand threads so when you think you're undoing it you're actually trying to tighten it.
XT1200Z and a DR350 in bits
Eddie Hitler
PostPosted: 19:10 - 04 Jan 2012    Post subject: Reply with quote
Let me know where the bike is, and ill have it undone in seconds.
*Flex*
Mikey3
PostPosted: 20:50 - 04 Jan 2012    Post subject: Reply with quote
Bit of WD perhaps? generally solves most stuck things.
Mike
'04 Yamaha WR450F
'99 SV650 Streetfighter Project - mid build
'Motorcycling is about what you do; not about what you own, or how much you spend on it'
Paris2
PostPosted: 21:01 - 04 Jan 2012    Post subject: Reply with quote
If tapping doesn't work, try whacking it.
Could work Laughing
Current Ride: Daytona 600
Mikey3
PostPosted: 21:04 - 04 Jan 2012    Post subject: Reply with quote
Could work Laughing
Our methods are the COMPLETE opposite Wink
'04 Yamaha WR450F
ninja_butler
PostPosted: 21:08 - 04 Jan 2012    Post subject: Reply with quote
This sounds like the most likely explanation to me. Thumbs Up
kestrel
PostPosted: 22:18 - 04 Jan 2012    Post subject: Reply with quote
This is the most likely scenario, usually the right hand mirror has a left hand thread, certainly was the case with older yamahas including my xs650.
Isle of Man.........Road Racing Capital Of The World
TheSmiler
PostPosted: 07:30 - 05 Jan 2012    Post subject: Reply with quote
IF all these methods fail you could always use my method which is using the spanner (correct size) grab hold at the bottom, then give the spanner a knock using a mallet/hammer with your other hand.
Best finding which way they tighten first though otherwise you can break the socket.
The last post was made 14 years, 42 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 78.7 Kb
