piston rings have gone and little end
mgs41987
PostPosted: 17:11 - 05 Jan 2012    Post subject: piston rings have gone and little end Reply with quote
its a honda clr 125cc single cylinder 4 stroke, went down to local engineering workshop, they said i will have to supply my own piston and give it to them so they can work out the dimensions of the re bore as little damage has been done can anyone recomend a size piston wouldnt mind going bigger cc maybe 150-170 depending on what i can find if anybody could point me in the right direction would greatly appreciate it
bore and stroke is 56.5 x 49.5 mm (2.22 x 1.95)
if anyone can help with me finding a cylinder kit would be very grateful
P.
PostPosted: 17:40 - 05 Jan 2012    Post subject: Reply with quote
There is no upgrade to these... you can only go 1mm oversize and will need the cylinder to be bored out to suit.
https://www.startright.co.uk/index.php?main_page=product_info&cPath=458_527_99_16&products_id=74108
While you are there, get rid of the useless excuse for an exhaust. If you are good at welding, you can remove the rear half of the exhaust (after downpipe, just before HUGE silencer) and fit a nice pipe and end can. Will help it breathe a bit easier... check the jetting of your bike though.. as I'd also upgrade the air filter in there. Thumbs Up
All of the above was going to be done to my last CLR but I had to sell it in the end, was going to budget about £150 to sort it all out Thumbs Up
mgs41987
PostPosted: 17:42 - 05 Jan 2012    Post subject: Reply with quote
so couldnt i go any bigger the engine is based on a xlr
P.
PostPosted: 17:47 - 05 Jan 2012    Post subject: Reply with quote
The engine is from an XL125, engine is more ancient than the dinosaurs.
Aside from fitting a CG engine and getting a chinese 150cc kit there isn't anything to do to the bike.
mgs41987
PostPosted: 17:49 - 05 Jan 2012    Post subject: Reply with quote
fair enough thanks any way
P.
PostPosted: 17:51 - 05 Jan 2012    Post subject: Reply with quote
Curious... what is a part of the reg number of your CLR? I sold mine not that long ago and rarely see them about Thumbs Up
mgs41987
PostPosted: 18:08 - 05 Jan 2012    Post subject: Reply with quote
v *** eta
MickC
PostPosted: 18:25 - 05 Jan 2012    Post subject: Reply with quote
It might cost you a bit more but try to find a company that specializes in re-bores. If it's done wrong you could end up with a right-off for an engine and at the very least an expensive (probably beyond the value of the bike) re-build.
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
Fizzer Thou
PostPosted: 19:13 - 05 Jan 2012    Post subject: Re: piston rings have gone and little end Reply with quote
Is the original piston worn out?
What is the result of a compression test?
If the little end has gone it may well need a new con-rod as well.Which means having the crankshaft out to push out the big-end bearing.If the piston is okay it may only need new rings after a glaze-bust job.
Or has the engine been run without sufficient oil in it causing the engine damage?
Always have a 'Plan B'
Mikey CB500
PostPosted: 19:47 - 05 Jan 2012    Post subject: Reply with quote
If its a CG 125 piston then you should be able to bore the standard barrel out to atleast 2.5mil oversize which would give you a boost in torque. Its not practicle but if preformance boost is your only aim then it should be possible.
Althogh 2.5mil is the maximum overbore and if it ever got that damaged that honing wouldnt clean it up then youd need either a resleve or new barrel.
humanbeing
PostPosted: 10:26 - 06 Jan 2012    Post subject: Reply with quote
Read my old post https://www.bikechatforums.com/viewtopic.php?t=228991 BUT that country is in holiday mood, so forget shipping it home untill February. Wink
mgs41987
PostPosted: 17:28 - 06 Jan 2012    Post subject: Reply with quote
when i bought the bike i checked the oil and it was full but very fresh, 3 weeks later i heard the knocking i suspected rings or little end checked oil it was empty ? found that the valve cover gasket gone
if i can go 2.5 over then i will luckily for me there is a motor engineering shop withing 2 mins walk convenient i know but he said i have to supply my own piston, im going to order the piston for it and gasket set ready for when i strip it down i cant locate a bearing size for little end so i will have to wait for that bit for when i strip it take measurements and order it,
could anyone tell me were i can find a 2.5 over size piston for a cg / xr i have had a look but no joy only find a 1mm if i can find it i will have it rebored to size whilst its apart
P.
PostPosted: 18:13 - 06 Jan 2012    Post subject: Reply with quote
Can only find 1.5mm
https://www.ebay.co.uk/itm/NEW-HONDA-CG125-CG-125-PISTON-KIT-RINGS-78-00-1-50mm-/230443912671?pt=UK_Motorcycle_Parts&hash=item35a7870ddf#ht_1457wt_754
Although photo looks far different to the CLR piston I had, had valve recesses on the piston crown.
mgs41987
PostPosted: 18:24 - 06 Jan 2012    Post subject: Reply with quote
##Paddy## wrote:
Can only find 1.5mm
yeah mine does to lol gonna get hold of a bike shop that does rebores and supply pistons to they might have one there
P.
PostPosted: 18:28 - 06 Jan 2012    Post subject: Reply with quote
Not likely able to match one up for you.
Call David Silver Spares tomorrow, ask about an oversize one for a CLR125 specifically.
The last post was made 14 years, 15 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 86.7 Kb
