confused about my reserve tank
mossi123uk
PostPosted: 19:14 - 05 Jan 2012    Post subject: confused about my reserve tank Reply with quote
I have a yamaha XJ600S Diversion 1998 and i filled it up to see how many miles i could get on a full tank (185 miles).
Then when i ran out of petrol i flipped the toggle to reserve tank and nothing happened, so i had a look in tank and it was empty and had to push it a mile to tesco luckily all on flat ground.
Any idea why my reserve doesnt work?
Maruchino
PostPosted: 19:19 - 05 Jan 2012    Post subject: Reply with quote
Maybe the reserve tank was removed by a previous owner?
Sorry.. bad attempt at humour
Maybe the switch is configured incorrectly, maybe ON is infact reserve by mistake?
Serendipity
PostPosted: 19:25 - 05 Jan 2012    Post subject: Reply with quote
I never dismantled the fuel tap on my Diversion to see the layout, but if it’s anything like the simple tap on an RXS100 the filter on the main inlet may have come off.
https://i221.photobucket.com/albums/dd227/serendipity_uk/RXS100/IMGP7033.jpg
In this picture the longer filter tube had fallen out meaning that unfiltered fuel was passing into the tap regardless of tap position. In my case I noticed because my carb got blocked with specks of rust from the tank, but the effect would have been to fully drain the tank before reserve was even engaged.
2007 CBF1000 & 2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation
Perhaps the reserve pipe is blocked with shit. It happens.
Chris750
PostPosted: 19:27 - 05 Jan 2012    Post subject: Reply with quote
Are you sure you had it the right way and it wasn't on reserve to start with.
Some taps can be ambiguous which way they are pointing.
Try it on what you think is reserve to start with and see if it works that way around.
Maybe carry a jerry can with you when it starts getting really low so you don't get caught out again.
Current Rides: GSXR-750 WS, GSXR-1000 K5, KTM EXC 300
PostPosted: 19:28 - 05 Jan 2012    Post subject: Reply with quote
But then he would still have fuel in the tank Wink
Stalk
Had the same with mine, the pipe in the tank had fallen out of the tap. It's a push fit. If you shine a torch into the empty tank you will see the pipe sticking out of the tap or you will see where the pipe should be. Tank off, tap off, tank upside down and shake till pipe falls out, reassemble and refit.
Hope that helps.
Stalk.
mossi123uk
PostPosted: 19:35 - 05 Jan 2012    Post subject: Reply with quote
Defonately sure i had it the right way this time because i ran out of fuel on it the other week while it was set to the reserve tank right next to a petrol station lol.
I never noticed any pipe sticking up in my tank maybe it has fallen through thanks for info
Stalk
PostPosted: 19:46 - 05 Jan 2012    Post subject: Reply with quote
Op. Where are you?
Stalk
PostPosted: 19:47 - 05 Jan 2012    Post subject: Reply with quote
Op. Where are you?
mossi123uk
PostPosted: 20:05 - 05 Jan 2012    Post subject: Reply with quote
Stalk wrote:
Op. Where are you?
nice and warm at home!
i live near rotherham
Kwaks
I'm not a fast rider
PostPosted: 20:55 - 05 Jan 2012    Post subject: Reply with quote
simplest remedy is to never run that low Wink
www.cliqueycuntsmcc.co.uk
mossi123uk
PostPosted: 21:00 - 05 Jan 2012    Post subject: Reply with quote
there is no fuel gauge but now i know to fill it up before the 180 miles mark so should all be good from now on
Stalk
PostPosted: 21:10 - 05 Jan 2012    Post subject: Reply with quote
If you where local I would show you the inside of my tank as a comparison but I am a bit far away in northampton. Will see if I can get a photo at the weekend and post it up.
sidewinder
Right just rechecked Embarassed
sidewinder
PostPosted: 21:12 - 05 Jan 2012    Post subject: Reply with quote
There is a reserve on the divvy just reserve/ prime/ and on
down = run
middle = prime
up = reserve
Very Happy
Stalk
PostPosted: 21:15 - 05 Jan 2012    Post subject: Reply with quote
No. Run, prime, reserve. Vacuum operated so will be off if the engine is not running
iooi
PostPosted: 21:23 - 05 Jan 2012    Post subject: Reply with quote
sidewinder wrote:
There is no reserve on the divvy just run/ prime/ and off Thumbs Up
Oh dear......
Rolling Eyes Embarassed
XJ600 S
Has a reserve......
Well at least the one I rode for over 2 years did, as did the others in the owners club.....
My guess is the OP forgot to return to main tank after running on reserve.
sidewinder
PostPosted: 21:26 - 05 Jan 2012    Post subject: Reply with quote
Mine has ?
Think the older models were vacum. then any thing 97 on had the 3 way tap Thumbs Up
Muscle Bike Rider
PostPosted: 21:43 - 05 Jan 2012    Post subject: Reply with quote
94 divvy has reserve = up prime = middle towards ight, On is down.
No off position as its a vacum pump which only works with engine running after vacum is ceated hence why you can take tank off with tap turned on. 97 onwards had electic pumps fitted, unless your older model has had the electic pump mod done as they are notoriously bad starting if left to run dry with a vacum pump.
Previously Known As A5tra_G
Old Bikes :2010 Kawasaki ER6 F & 2000 Honda VTR Firestorm
Current Bike : XJR1300
Stalk
PostPosted: 22:13 - 05 Jan 2012    Post subject: Reply with quote
sidewinder wrote:
Mine has ?
Look again, let us know.
mossi123uk
PostPosted: 23:16 - 05 Jan 2012    Post subject: Reply with quote
defonately is a reserve on my bike, says so in the manual i got Smile
also i defonately had it on the right setting the thing i turn has 3 options to turn t
up = res
right = pri
down = on
Beelzebob
PostPosted: 01:36 - 06 Jan 2012    Post subject: Reply with quote
The tap on the Divvy is the same general arrangement as this - apart from the tap positions ofc.
The only way you'll find out is whipping it off and having a look. It's a very simple operation though. Seat off, disconnect fuel pipes (don't forget to take the black plastic bit off the tap - there's a screw inside - otherwise it'll break when you try and remove the tank), then 2 bolts to take tank off. It's just two bolts into the bottom of the tank.
'09 YBR 125 -> '92 XJ600 S Diversion -> '99 Hornet 600
"Stronger than your average female lifeguard"
The last post was made 14 years, 245 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 114.86 Kb
