Float heights XS 400
pepperami
PostPosted: 20:52 - 13 Dec 2011    Post subject: Float heights XS 400 Reply with quote
Ok so I`m finally getting round to doing the float heights on my XS 400, Yipee! at fecking last Embarassed
According to the Haynes manual for that bike, the float height is 32.0 + 1mm give or take?
So if i`m still running a bit rich ie starts easy without choke, wont tick over, revs fine Thumbs Up , you can smell it in the exhaust smoke.
What next? I have the right jets in and the needles are in the right notch. Confused
I dont/did`nt have any air-leaks and am using a standard air-box.
also the floats are in good order, as is the float needle assembly.
I seek your wisdom BCF?
thank you Thumbs Up
Fizzer Thou
PostPosted: 16:42 - 04 Jan 2012    Post subject: Reply with quote
Only just come across this question while looking for something else,so apologies for not answering sooner.
32mm does seem a bit big,but Haynes get their info from the manufacturers,so it should be correct.
Are both set at 32mm?
If one is higher ie.31mm,is that spark plug for that cylinder showing as running too rich?
What does the other one show?Tan colour is good.
What happens if you set the float heights to 33mm?
Is the ignition working properly as insufficient spark could cause the air/fuel mix to not completely burn.
Are the spark plugs in good condition?Are they set at the optimum gap?A smaller gap should make the plug fire easier.
Is the air filter clean?
Is the air screw set to the manuals specification?Usually about 1.5 turns out but this is machine specific.Is the very small spring,washer and 'O' ring in place on each air screw?
Have you checked that the float chamber vent airways are passing air okay?
Always have a 'Plan B'
pepperami
PostPosted: 16:58 - 04 Jan 2012    Post subject: Reply with quote
Thank you for that Thumbs Up much info to digest.
Plugs, timing, sparks, battery = all good.
Small spring and o-ring in place = yes.
Airbox = airtight.
Airfilter = clean.
I will read your thread again when I have the bike in bits again Thumbs Up
MickC
PostPosted: 18:35 - 04 Jan 2012    Post subject: Reply with quote
I'd go with the mixture screw.
XX XXXx
Previous: CG125,XS250 (converted to 400),Z250A, GPZ550, Norton Commando, XS500, 78 Laverda Jota, GPZ1100,Harris bonneville, XV750 (mono shock),TR1
Bru
PostPosted: 13:16 - 05 Jan 2012    Post subject: Reply with quote
Also, you could check your diaphragms. A fine crack in a fold could cause the needle to move up more slowly, which would effectively richen the mixture.
bikenut
PostPosted: 14:09 - 05 Jan 2012    Post subject: xs400 Reply with quote
sorry dude nothing to add, cb ign yes? have xs250 parts, any interest?
pepperami
PostPosted: 20:59 - 05 Jan 2012    Post subject: Re: xs400 Reply with quote
you have pm
PostPosted: 00:17 - 06 Jan 2012    Post subject: Reply with quote
I just saw this too.
Why would your float heights have changed since the bike was last running properly.
If you can come up with a convincing answer, then fiddle with them. Otherwise leave them alone. As a general rule, floats heights don't/can't change themselves (with the exception of a punctured float).
bikenut
PostPosted: 11:20 - 06 Jan 2012    Post subject: pm? Reply with quote
sorry dude dont know what is meant by pm?
saw your e mail, 250 parts but no 400 parts, and interest?
also rd e mail any interest.
pepperami
PostPosted: 14:52 - 06 Jan 2012    Post subject: Reply with quote
COS it`s a XS 400 bitsa and when I got it, it was in many many many pieces
pepperami
PostPosted: 14:54 - 06 Jan 2012    Post subject: Re: pm? Reply with quote
go to the top right of the page where your name is and click on messages.
The last post was made 14 years, 17 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 70.11 Kb
