MOT changes 2012
st3v3
PostPosted: 17:23 - 06 Jan 2012    Post subject: MOT changes 2012 Reply with quote
Haven't seen this posted yet, but come across it on AA site and here:
https://uk.autoblog.com/2012/01/04/changes-to-mot-rules-in-2012-are-you-ready/ - although it appears to be published in relation to cars, surely bike's would be affected where relevent?.
For lazy sods:
On 1 January 2012, new rules were added to the current MOT by the Department for Transport (DfT) to comply with European testing procedures.
It's a pretty substantial list, but there's one which could mean big bills for thousands of drivers. If your car has any illuminated warning lamps, whether it is the airbag, seatbelt, ESP, SRS, ABS or others, it will soon fail the MOT.
It's not all bad news. If your car's MOT runs out before the 31 March 2012 and you have a warning light that needs addressing, the testers will treat it as an 'advisory', i.e. advice on what needs to be done for the next MOT.
However, if your MOT is due after 1 April 2012, you better get your skates on and get the warning light (or other faults in the list below) fixed, otherwise you'll receive the dreaded red fail sheet.
The AA has kindly published a summary of the new rules. If you think your car needs attention on any of the points below but still has a long MOT left, we recommend getting it seen to sooner rather than later.
The main changes from 2012:
Electronic parking brake
Electronic parking brake controls are now included and must be present and not inappropriately repaired or modified - repair obviously likely to adversely affect the roadworthiness of the vehicle or modification that has seriously weakened the component.
(The 'inappropriately repaired or modified' check is to be applied to a wide range of systems and components throughout the vehicle.)
The car will fail if an Electronic Parking Brake warning lamp is illuminated to indicate a malfunction.
Electronic Stability Control
Checks of anti-lock brakes will be extended to include Electronic Stability Control if fitted. The tester will check for the presence and correct operation of the ESC malfunction warning light together with looking for obviously missing, excessively damaged or inappropriately repaired or modified components and electrical wiring, as well as an ESC switch missing, insecure or faulty.
Warning lights
As well as electronic parking brake and electronic stability control warning lights (where fitted) the MOT test will also include checks for the correct function of the following, where fitted;
Headlight main beam warning light
Electronic power steering warning light
Brake fluid level warning light
Tyre pressure monitoring system warning light
Airbag warning light
Seat belt pre-tensioner warning light
Steering & suspension
The new test includes a check on the presence and correct function of the steering lock where fitted as standard.
Missing, or split/damaged dust covers on steering and suspension ball-joints will result in failure if they will allow dirt to enter the joint.
Power steering fluid level must be above the minimum level indicated on the reservoir.
Lighting
Products on the lens or light source that obviously reduce the light's intensity or change its colour will become a reason for failure – applies to front/rear position lamps, registration plate lamps, stop lamps, rear fog and direction indicators,
Headlight requirements are updated to take account of the particular characteristics of High Intensity Discharge (HID) lamps.
HID headlights can cause dazzle if they are dirty or aimed too high so car manufacturers must fit headlamp cleaning and levelling systems. A car will fail if a mandatory headlamp cleaning or levelling system is missing, doesn't work or is obviously defective.
Vehicles fitted with aftermarket HID systems must also be fitted with properly working washer and levelling systems.
If a headlamp bulb is not seated correctly the resulting beam pattern will be indistinct and this will result in a test fail.
Electrical wiring and battery
An insecure battery will be a reason for failure as will a battery that is leaking electrolyte.
Visible wiring that is insecure, inadequately supported or likely to cause a short will also result in a failure as will wires bared by damaged insulation.
Trailer/caravan electrical socket
There will be a basic security/damage check of 7-pin sockets,
13-pin sockets will be subject to a full electrical connectivity check and incorrectly connected or inoperative circuits will result in failure.
Tyres
Tyre pressure monitoring systems fitted to vehicles first registered after 1 January 2012 must be working correctly and not indicating a malfunction.
Supplementary restraints
The vehicle will fail the test if any airbag fitted as original equipment is obviously missing or defective.
A seatbelt pre-tensioner fitted as original equipment but missing or that has obviously deployed will be a reason for failure.
Seatbelt load limiters that are missing where fitted as standard or folding webbing type limiters that have obviously deployed are also reasons for failure.
The vehicle will also fail if an SRS malfunction light is missing, not working or indicating a fault.
Speedometer
The car will fail if a speedometer is not fitted, is incomplete, inoperative, has a dial glass broken/missing or cannot be illuminated.
Seats
It must be possible to secure the driver's seat fore and aft adjustment mechanism in two or three different positions. On electric seats the motors must move the seat fore and aft.
Doors
A rear door that cannot be opened from the outside using the relevant control is a new reason for failure.
Doors must be easy to open and close – hinges, catches and pillars will be inspected.
Towbars
Inappropriate repair or modification to the towbar assembly will be a reason for failure if judged likely to affect the roadworthiness of the vehicle/trailer.
Exhaust
A catalytic convertor fitted as original equipment but missing will be a reason for failure.
Fuel system
Damaged or chafed fuel pipes will result in failure.
B10Hazard
PostPosted: 17:47 - 06 Jan 2012    Post subject: Reply with quote
Thats fuckin stupid !
When i had my punto mot'd i had to sort the passenger side door out cus that wouldn't open from the outside due to no handle.
Its ridiculous having it that rule for that back tho
No longer any socks
PostPosted: 17:57 - 06 Jan 2012    Post subject: Reply with quote
The article isn't that accurate.
The changes for HID lights are a lot less strict than that.
Manual is here:-
https://www.motinfo.gov.uk/htdocs/m4_int.zip
Main section covering the HID lights says:-
Vehicles equipped with High Intensity Discharge 3. (HID) or LED dipped beam headlamps may be fitted with headlamp washers and a suspension or headlamp self levelling system.
Where such systems are fitted, they must work; however, it is accepted that it may not be possible to readily determine the functioning of self levelling systems. In such cases, the benefit of the doubt must be given.
Headlamp washers may work in conjunction with the windscreen washers (when the dipped beam headlamps are switched on) or by a separate switch.
virus
PostPosted: 18:06 - 06 Jan 2012    Post subject: Reply with quote
half of that stuff is current MOT legislation. Laughing
John
own: 81 xs1100g...
jimbothe
PostPosted: 18:29 - 06 Jan 2012    Post subject: Reply with quote
Exhaust
Does that also cover diesels? My 96 Disco hasn't had a cat on for about two years and goes through ok currently. Does this mean I'm going to have to fork out £120 for a pattern replacement and then go through the hassle of putting it on and taking it back off every year?
Check out our tackle shop on Facebook:
https://www.facebook.com/#!/JklTackle
PostPosted: 21:31 - 06 Jan 2012    Post subject: Reply with quote
And so another tranche of older vehicles will be forced off the road because it's not financially viable to pay the labour charges on replacing a £5 component. Ask me about the fruitless hours I've spent searching for the child lock relay on my C3. Mad
Blackwolf
Burgerfist
PostPosted: 21:45 - 06 Jan 2012    Post subject: Reply with quote
So, how long you spent looking for your child lock relay then Rogerborg?
PostPosted: 22:46 - 06 Jan 2012    Post subject: Reply with quote
Hours. Fruitlessly. Razz
I'm not joking, I can't find the thrice damned thing. I've disassembled half the dash; it's not in or near the main BSI box there, it's not in the secondary relay/fusebox next to the battery, and the Haynes Book of Lies doesn't give any clue. I can find a wire that leads to it, but it just vanishes into the loom and I can't find the other end. An electrical specialist had it in for 3 days then admitted defeat.
It's not cost effective to pay a Citroen dealer to find it, not that they're likely to know either, so the car is now essentially junk for the sake of a single relay, and sooner or later I'll have to chop it in for a newer vehicle even though mechanically it's as fine as a Citroen gets. Happy now, ecomentals? Mad
Shaft
PostPosted: 23:48 - 06 Jan 2012    Post subject: Reply with quote
If I can find out where it is for you, do I win a prize?
D O G
PostPosted: 23:49 - 06 Jan 2012    Post subject: Reply with quote
Another example of why you should not buy any French car less than 12 years old.
Hockeystorm65
PostPosted: 23:57 - 06 Jan 2012    Post subject: Reply with quote
So what you are saying is that my wife's car is now a scrapper despite being only 3years old! She was rear ended at a junction (by another driver...not me) and the car has been repaired and returned but still shows an airbag warning light...as it started doing after the the crash (it is an 08 plate Suzuki) the insurance company said that the airbag warning light was not due to the crash...even although it didn't show up until after the crash! Rolling Eyes
Good judgement comes from experience.....experience comes from bad judgement!
Hockeystorm65
Walloper
PostPosted: 00:15 - 07 Jan 2012    Post subject: Reply with quote
I love tight MOTs.
But only if it can block those Eastern Block Pickey fcukers from rolling off European ferries onto our Fair lands.
I don't think some of the shite they drive could pass a basic Tyre Kicking test.
They all have a predilection for Mangy Auld 3 Series Beemers too.
binge
Emo Kiddy
PostPosted: 00:38 - 07 Jan 2012    Post subject: Reply with quote
Wire the airbag warning light up to the oil pressure warning light, and hey presto, your airbag light functions correctly. Thumbs Up
I work in an MOT testing station, and yup, the new rules are indeed a lot more in depth than the original rules.
Some more daft than others.
And STILL, after an update of MOT ruling and checks, it doesnt state that prop shaft support bearings on a rear wheel drive motor need to be fully functional. Laughing
A few things have changed for the better though.
An example of one, is the rear load sensing valve for the brake compensator. Mainly applys to Vauxhall Astras and Vectras with the sensing valve on the rear beam.
The orignal note stated that the valve must not be seized. Even though, the valve never seizes, and the linkage is the point of common failure.
The new ruling states that the linkage must not be seized. Which works better.
And to be fair, it's a pretty important part on those cars. Get that valve seized the wrong way, and you'll not have any control whel braking. The foot brake will literally be a hand brake. Laughing
If anybody has any questions around some of the points, feel free to gimme a shout and I'll find out the best / cheapest way around it.
I do agree, it's a way to remove all the sh*t cars from the road.
In regards to the CAT converter question.
Yes, it does need one, regardless of how it goes through the emissions.
If they have them as a factory fitment, then they need to be there.
Out of interest, why are you going to fit one, then remove it again?
Why not just fit one, and leave it on?
Ben
st3v3
PostPosted: 01:21 - 07 Jan 2012    Post subject: Re: MOT changes 2012 Reply with quote
So you have a crash, there's a fire at the front and your only rear passenger is trapped. The door handle inside broke during the collision but the outside one doens't work and they cant be let out to escape.
Sound fuckin stupid now?
Mine is ~15, can't see why it will fail. That's without me doing anything.
I'd imagine if the warning light is on then yes, something is wrong. Maybe a dodgy sensor or wire not quite right?
What about bikes?
D O G
PostPosted: 10:08 - 07 Jan 2012    Post subject: Re: MOT changes 2012 Reply with quote
Read what I wrote again.
I have 15 year old Renault, it's fine. Old french cars are good - it means they were built properly if they are still working. Young French cars have a huge risk of going wrong. Hence avoid all young French cars, unless they are in warranty.
PostPosted: 11:44 - 07 Jan 2012    Post subject: Reply with quote
If you can find out where it is, you should take an oath to use your X-Ray vision only for good.
To be fair, the wife's Xsara Picasso has been excellent, even with the abuse she gives it. But the more cut price electronics that get crammed into (any) car, the bigger the risk of the magic smoke escaping and turning it into scrap. I'd have thought that the ecomentals would be all over this, since it's far better for the dolphins and such to keep existing cars in service than to build new ones.
keggyhander
PostPosted: 15:13 - 07 Jan 2012    Post subject: Reply with quote
I love dodgy MOT places.
ME: I've got illegal HID's but I've made em quick-swappable with the standard H4's. I can change it if you want?
TESTER: Fuck that. Use my beam tester to set your HID's where you want them. I've got 'em myself.
WIN!!
Walloper
PostPosted: 20:44 - 07 Jan 2012    Post subject: Reply with quote
WIN!!
Tut Tut..
Rated as: This Post is Too Dodgy. Tut Tut
Smile
jimbothe
PostPosted: 23:54 - 07 Jan 2012    Post subject: Reply with quote
Because I put a de-cat on it when the original finally gave up the ghost. I also took off the egr system. It's a 1996 diesel. I was under the impression that as long as it was diesel and was pre - 2000 then it wasn't a requirement for mot?
Until now Rolling Eyes
st3v3
PostPosted: 00:59 - 08 Jan 2012    Post subject: Re: MOT changes 2012 Reply with quote
I was scooting off and glanced, not read the text.. Embarassed
PostPosted: 12:45 - 08 Jan 2012    Post subject: Reply with quote
MOT just checks a a subset of the things that are required for a vehicle to be road legal and which can easily be checked.
They have just decided that the presence of the cat is an easily checked thing (the actual emissions test only being vaguely related to real tested emissions for homologation).
st3v3
PostPosted: 12:49 - 08 Jan 2012    Post subject: Reply with quote
It's still a semi-pointless exercise. MOT, that is...
Nb
PostPosted: 13:25 - 08 Jan 2012    Post subject: Reply with quote
And how do you come to that Conclusion? I carry out mots every day on class iv vehicles and the downright dangerous state of vehicles on the road today worries me! With the recession and things the way they are, people are avoiding servicing just to save money. The mot is the only way to Atleast improve road safety when it comes to vehicles.
I appreciate that a vehicle can be unfit for the road even after an mot with other regulations and that the next day the tyres might be illegal etc
I really don't think it's pointless but then it's what I do lol
What gets my goat is all the eastern Europeans coming over here and driving around in shit heaps not needing an mot or insurance in most cases I expect.
st3v3
PostPosted: 17:29 - 08 Jan 2012    Post subject: Reply with quote
I think there should be some dept that does mobile spot checks on shit heaps.
If it looks iffy, pull it and test it on the spot. Any MOT failure points discovered the driver pays for an MOT (at the most local centre at that point) and get's rectification notice.
The last post was made 14 years, 57 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 148.55 Kb
