What did I just break? Rieju RS2 not starting - My fault >
Nai
PostPosted: 14:34 - 07 Jan 2012    Post subject: What did I just break? Rieju RS2 not starting - My fault > Reply with quote
Roit, after the last theft 2 things were broken on my bike. The choke cable and the clutch cable. I have gotten around to giving my bike a good clean today and changed the clutch cable. My bike however doesn't start. Rough order of events :
Gave bike a clean and let the engine run for a bit (Hadn't been started in 3-4 weeks). Started first time and ran happy.
Lifted fuel tank, unhooked fuel pipe, electric cable, and air pipe(?) from the bottom of the tank. Had some fuel leak out of the bottom of the tank as it stood the tank up leaning it back.
Changed clutch cable, took me 20 ish minutes. Yar, I know, slow, it was my first time. Clutch now appears to work. Great.
Put the tank back down and noticed petrol had come out of the cap.
Reconnected all the pipes (deffo all gone on the right places).
Tried to start the bike, and got greeted with 2-3 secounds tops of a running engine then it stopped.
All i get now is the bike trying to start but not actually firing up.
It got left to sit for an hour while I had a cuppa and ordered shopping, came back, had a look, couldn't see anything in the wrong place, but the bike still doesn't want to start.
What have I broken?
UrbanRacer
PostPosted: 14:43 - 07 Jan 2012    Post subject: Reply with quote
fuel and air pipe are connected incorrectly or you have air in the fuel line.
Nai
PostPosted: 14:46 - 07 Jan 2012    Post subject: Reply with quote
Guessing air in the fuel line is most likely. How does one fix that? Embarassed
Drake
PostPosted: 15:03 - 07 Jan 2012    Post subject: Reply with quote
if its a vacuum tap just keep cranking and it will suck it through
Nai
PostPosted: 15:27 - 07 Jan 2012    Post subject: Reply with quote
I read that and the first thought was 'But I have been trying for 5-10 minutes! I even had to get jumps starter on there cause the battery was dead!'
Went outside, back on with the jump starter, and vroom, 2nd time.
Thankyou sirs!
The bikes now cutting off at low revs, but I am figuring thats a battery problem as it was pretty dead today. Stuck in charge indoors, and crossing my paws thats all it is.
Chris 85
PostPosted: 00:56 - 10 Jan 2012    Post subject: Reply with quote
I had a similar problem which turned out to be the vacum pump on the tank it wouldnt keep a continuous flow of petrol, I found it by sucking on the air pipe to see if petrol comes out just make sure u suck on the right one or you get a mouth full of petrol which isnt good
The last post was made 14 years, 174 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.42 - MySQL Queries: 13 - Page Size: 47.15 Kb
