Carbs fixed well not yet it seems
TheSmiler
PostPosted: 17:07 - 07 Jan 2012    Post subject: Carbs fixed well not yet it seems Reply with quote
As you know I have been working on the carbs the last few days, managed clean them put them back together turn her on and ...
It starts chucking fuel from the carbs and rubbers that go into the engine.
Read online that this is to do with either the floats set at the wrong height or the needle (pin thingamajig) being pushed up too high causing too much gas and making them overflow.
Is there a way of sorting this without taking the carbs off, wanted get her on the road for this Tuesday/Monday 16th last last resort.
m3-paul
PostPosted: 19:56 - 07 Jan 2012    Post subject: Reply with quote
If you have a workshop manual then look at what the float height should be set to, also, i would look at replacing the needle valve and seat. Seems like fuel is passing the valve and no matter if the float height is set correctly or not, if this needle valve seats O ring is not sealing well then it will piss fuel out via the overflow.
Yamaha TZR250 - love the smell of TTS!!!!
CBR900RR Fireblade - so much fun
Teflon-Mike
tl;dr
PostPosted: 20:28 - 07 Jan 2012    Post subject: Reply with quote
The floats on your bike are 'fixed height'; there is no adjustment on them; so if the float bowls are flooding;
a) you have put the float needles in 'wrong'
b) you haven't got the float bowls sealed.
Most likely a) if petrol is pissing straight out the main jets or mixture gallery.
TheSmiler
PostPosted: 23:05 - 07 Jan 2012    Post subject: Reply with quote
Ah thank you for the reply mike, I have had a closer look at the carbs and you can see the black inner line around the carb (where they join), hardly any gap but wonder if this is what's causing it.
TheSmiler
PostPosted: 18:02 - 08 Jan 2012    Post subject: Reply with quote
Sorry for double post, saves creating a new thread.
Managed to take the carbs apart and now they are fully sealed so the leak has slowed down. However still leaking from extended pipe on the side. Believe its the overflow tube (not sure if its got one) it is on the side of the carb.
Any idea how to sort this issue out Question Found out one method on this website below:
https://www.dansmc.com/carbs.htm
If you turn on the fuel petcock and gas pours out the overflow tube, tap lightly on the carb body with a plastic hammer(or something like it). That will jiggle the fuel inlet needle loose. Same thing if there is dirt holding the needle open.
Haven't got a plastic hammer but have got a rubber mallet (if that is the issue) would a light tap sort it out, if so where do I tap it Question
Teflon-Mike
tl;dr
PostPosted: 19:30 - 08 Jan 2012    Post subject: Reply with quote
No, its not the over-flow. Over flow is the nipple on the bottom of the float-bowl, that DID have over flow pipes attached to direct any weepage to under the engine.
If its a pipe on the side, of the left hand carb, behind the choke cable plate; it doesn't have a name; I think its an auxilliary breather vent to let air into the float bowl.
After rebuild these often weep for a while, before they stop leaking.
Your bike has no centre stand so is leaning to that side, which doesn't help.
Ought NOT weep; and means that your float needles aren't seating properly.
BUT; leave it for now; run the bike up, and see if it stops of it's own accord.
Letting the bike run will drain the fuel from the float bowls and get the float going up and down bedding the needles back in to find a nice 'seat', and THAT may be all it takes.
Just turn the fuel tap 'off' so it doesn't drain the tank when not running; and see whether it persists after maybe an hours running.
If so, then you have some crap still under the float needles, and will have to pull the float bowls and clean AGAIN!
TheSmiler
PostPosted: 13:53 - 09 Jan 2012    Post subject: Reply with quote
Ah thanks mike, why did I have a hinklin that it just wouldn't be that easy to fix them (slight tap). Decided try this method today managed to get the bike start, if only for a second with no flooding from below. However then conked out again.
Rang a local workshop to me asked for a quote told them what went wrong and the back story, the guy owning it is willing look over it for £50 not bad really that is with free pick up. Considering the wagely hour against the time it can take to get the carbs off.
Also the free lift will be getting me to university as well as he has to go that way anyway, saves the £30 pick up from the other location plus the fix on top.
Ichy
PostPosted: 14:14 - 09 Jan 2012    Post subject: Reply with quote
My offer to help still stands. I should have some time free this weekend if it's not already sorted.
TheSmiler
PostPosted: 14:22 - 09 Jan 2012    Post subject: Reply with quote
Dam completely forgot mark about your offer Crying or Very sad got her in jackhammer tomorrow now in morning https://www.jackhammermotorcyclesst4.co.uk/ hopefully no one rates them as badly as DK really friendly guy.
Didn't think it was a bad offer £50 free pickup and fix +sync if no parts need replacing. (none do). Kind of jumped at it straight away, need the bike for monday next week as well so hopefully fixed and sorted trouble free in no time.
Ichy
PostPosted: 14:33 - 09 Jan 2012    Post subject: Reply with quote
No problem, the offer aways stands although I don't always have a lot of free time. I'll add you as a friend so you can see my mobile number. Your welcome to text me if you ever get stuck.
PostPosted: 17:27 - 09 Jan 2012    Post subject: Reply with quote
If fuel is pourng out of the float bowl breather and carb rubbers, mind that it hasn't filled any of the cylinders with petrol, or even done that and then leaked past the rings into the sump.
If you crank your bike with a cylinder even part-filled with fuel it can hydraulic and do some pretty hefty damage. I suggest pulling the plugs and giving it a good whizz over to clear the cylinders as a precaution.
The last post was made 14 years, 181 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.96 - MySQL Queries: 13 - Page Size: 78.38 Kb
