Why did I get a two stroke...
Milo
PostPosted: 18:06 - 17 Sep 2004    Post subject: Why did I get a two stroke... Reply with quote
Well I'm in work and my lil 100cc 2-stroke won't start.
It started initially but then navigating a security barrier i let the revs drop and it cut out and hasn't started since.
I've tried the kick start many times and also bump starting it but it doesn't sppear to be firing.
I've tried swapping the spart plug (which was quite oily) but still nothing. It's sparking so I'm really not sure what the problem is.
Any suggestions?
And no - it's not out of fuel Laughing
Ads
Shaft drives rule. Razz
Hex
Party Boy
PostPosted: 18:39 - 17 Sep 2004    Post subject: Re: [HELP!]Why did I get a two stroke... Reply with quote
But is it turned on? Laughing
Is the spark plug shot?
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
Stu_666
PostPosted: 18:46 - 17 Sep 2004    Post subject: Reply with quote
Not that I pretend to be shit hot with bike mechanics Rolling Eyes Razz , but with the RS125 I'm thinking of getting you have to let them warm up a wee bit before going off. I'm guessing you probably already know that though. Have you checked obvious stuff like the battery etc. That's what I normally do with me car when there's a problem and its normally something really simple and obvious...maybe Laughing
Milo
PostPosted: 18:49 - 17 Sep 2004    Post subject: Reply with quote
The battery's fine as the neutral light is fine and it's sparking.
The fuel is on and it was running fine when it was parked - and when it started initially.
When I got it there were a couple of spare plugs. I've tried these and it's the same with each. Confused
Jammy-G This post is not being displayed because the poster is banned. Unhide this post / all posts.
Mr Pants!
I Karma
Two things required, a spark, which you have proven is present and fuel getting through. Have you checked that?
Mr Pants! (Alex or Al)
Its better to burn out, than to fade away....
Smoto Bob
PostPosted: 19:00 - 17 Sep 2004    Post subject: bike Reply with quote
choke?? kill switch spring to mind lol
then spark/fuel
its a 2 stroke thats a good thing cant be many thigns Thumbs Up
F'it DO WHAT EVER MAKES YOU HAPPY!!!!! Even if it screws over everyone else :p
Titz wrote: "..and my 3rd accident was when this police car....."
mrchips
PostPosted: 19:12 - 17 Sep 2004    Post subject: Reply with quote
Take the plug out and give it a few kicks to get all the petrol out of the head.
Azmodeus
PostPosted: 19:49 - 17 Sep 2004    Post subject: Reply with quote
It cut out when you let go of the throttle?
and now it wont start?
Hmmm... sounds a lot like what is wrong with my bike. May be that the float in the carb has gone.
Robby
Dirty Old Man
PostPosted: 20:52 - 17 Sep 2004    Post subject: Reply with quote
Does it run a fuel filter?
Its an old bike, it'll have shit in the tank that could block the jets if its not got a filter.
Wave2k
G's Stalker
PostPosted: 21:01 - 17 Sep 2004    Post subject: Reply with quote
ahhh the joys of the 2-stroke Embarassed
Ducati 1299 Panigale
2009 Corvette C6 z51
Claud 14.7 to 1
PostPosted: 21:09 - 17 Sep 2004    Post subject: Reply with quote
Yeah i'd aggee with Robby, and check lines, clean out the tank. Basically check there are not blockages/problems though the whole fuel delivery system, including the carbs. But do the carbs last.
Clean out the tank, check hoses, filters, fuel tap etc. Mine cut out just like that, when the fuel pump finally packed up. You probably won't have a fuel pump, but you may do.
Doing all of the above certainly wont hurt it, may even fix the problem.
PostPosted: 22:47 - 17 Sep 2004    Post subject: Reply with quote
This'll be way too late, but you probably flooded it. Fuel off, choke off, ignition on, throttle wide open. Now kick over until it fires, quickly switch fuel on.
JonB
Afraid of Mileage
PostPosted: 23:01 - 17 Sep 2004    Post subject: Reply with quote
Sounds like a classic flooding to me, Leave it for 5 minutes and what works for me is to pull the throttle back ever so slighty just to let a trickle of fuel into the ignition area and just push in the ignition and hold for a little while, should fire up shortly after. Smile
Milo
PostPosted: 10:06 - 18 Sep 2004    Post subject: Reply with quote
Thanks for the replies everyone. Finally managed to get it started by pushing it around the small car park outside my work many many times with a mate to help.
Still unsure what caused the problem, though I assume it was flooded. Each time I changed the plugs they seemed very oily.
Very annoying bike to bump start - you can't push it along and then release clutch because it's light and will just skid.
I'll give it a thorough take apart and put back together soon.
cheers
Ads
PostPosted: 10:09 - 18 Sep 2004    Post subject: Reply with quote
You should try bumpstarting a dr600 or a high compression zx9... it skids, but not because it's light. Put it into second and it should be fine.
If you're actually bump starting it to start it rather than clear it out, then I'd just run along and jump on it.
Milo
PostPosted: 10:22 - 18 Sep 2004    Post subject: Reply with quote
Yeah, that did the job in the end. Very odd, and rather embarassing running around with this bike outside work.
On another note - my XJ900 had been sat outside, open to the elements, for 3 weeks and started perfectly first time. Damn I love that bike - and I'd forgotten about the power she can give!
PostPosted: 10:31 - 18 Sep 2004    Post subject: Reply with quote
If it is something like an H100 or an RXS or that kind of thing, you should bump start it in second. That way you can just sit on the saddle with the clutch out and paddle it about with the engine turning over.
You can start my H100 by sticking it in second on the stand and pulling the back wheel round by hand (NB fingers, spokes etc!).
The last post was made 21 years, 151 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 98.37 Kb
