Hornet hell
stebmx
PostPosted: 19:45 - 08 Jan 2012    Post subject: Hornet hell Reply with quote
Hi new to the forum and after some advice fixing my 99 hornet 600cc
The hornet has developed a cut out fault that has steddley got worse.
The symptoms are: power loss through out rev rang, starting difficultly but this could be due to lack of use. Fault occurs within 1/2 miles of riding.
Parts changed and checks done to date are as follows:
- Sparkplugs and HT leads replaced
- coil packs replaced
- crabs and jets checked and cleaned
- Fuel tap and diaphragm checked and cleaned
- visual check of fuel and air box pipes
- ignition pick up/pulse coil replaced
Hope someone can shed light on the problem... manythanks Ste.
funmonkee
PostPosted: 01:25 - 09 Jan 2012    Post subject: Reply with quote
Might be a good idea to join https://www.hondahornet.co.uk/
**** Don't ride faster than your angel can fly Get this Free Space
The democratically elected Mod of the Scottish Section - The Peoples Choice[b]
Beelzebob
PostPosted: 01:28 - 09 Jan 2012    Post subject: Reply with quote
+1
'09 YBR 125 -> '92 XJ600 S Diversion -> '99 Hornet 600
"Stronger than your average female lifeguard"
funmonkee
PostPosted: 01:30 - 09 Jan 2012    Post subject: Reply with quote
^ ah, so you got that lovely blue Hornet Question
andys675
PostPosted: 23:29 - 09 Jan 2012    Post subject: Reply with quote
sounds like a fuel pump relay, bypass it temporarily and see if it cures it
PostPosted: 23:39 - 09 Jan 2012    Post subject: Reply with quote
Maybe a blocked fuel breather, try running the bike with the fuel cap open.
Beelzebob
PostPosted: 01:16 - 10 Jan 2012    Post subject: Reply with quote
UnknownStuntm...
PostPosted: 10:36 - 10 Jan 2012    Post subject: Reply with quote
Yep this one. I've had the exact same symptoms, turned out the breather pipe was being squashed by the tank where some monkey had put it back on in a hurry.
Yes, I am that monkey.
And yes join the website, they appear a friendly enough bunch!
The last post was made 14 years, 166 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.30 Sec - Server Load: 3.14 - MySQL Queries: 13 - Page Size: 59.99 Kb
