Battery charging - to disconnect or not to disconnect?
Adam_P
PostPosted: 07:26 - 10 Jan 2012    Post subject: Battery charging - to disconnect or not to disconnect? Reply with quote
Hi folks.
Very quick question. I've got to put the charger on the Fazer and I'm just wondering, is it better to disconnect it from the bike or can I just connect the optimate leads straight onto the terminals while it's still wired up to the bike?
It's been fine all winter until I moved it the other day and it's got a sluggish turnover, bugger.
Colin McRae MBE 1968 - 2007 RIP Sad
Orwell Rolls in his Grave
God is imaginary
multijoy
PostPosted: 10:14 - 10 Jan 2012    Post subject: Reply with quote
Stick it straight on. I've got an optimate tail wired straight in, which is even more handy.
PostPosted: 10:18 - 10 Jan 2012    Post subject: Reply with quote
With an Optimate I would also just connect it up. Be a touch more careful with a normal fast battery charger.
Also, while I remember the Optimate leads use the same connector as some Tamiya radio control model batteries (polarity is reversed though I think), which might be convenient it you want to wire up an extra lead for the Optimate.
weasley
PostPosted: 13:06 - 10 Jan 2012    Post subject: Reply with quote
Another Thumbs Up for the Optimate fly lead. I have one permanently attached to my battery and hidden behind a fairing panel. When I get home I just plug in, switch on and walk away - it can sometimes stay like this for several weeks.
This fly lead can also be used to attach a cigarette lighter accessory which is useful for charging phones and sat navs etc on the move.
goto10
PostPosted: 13:11 - 10 Jan 2012    Post subject: Reply with quote
With an Optimate you'll be fine connecting it straight up, anything charging at more than 2 amps then you should disconnect it.
Marmalade
PostPosted: 13:15 - 10 Jan 2012    Post subject: Reply with quote
You can buy the optimate plugs on ebay. I've got the tails on my 3 bikes and put one on charge each night
Tenko
PostPosted: 14:42 - 10 Jan 2012    Post subject: Reply with quote
Always used a charger with the battery on the bike and never had a problem so far. You must remember to stand the bike upright however, as if it is on the sidestand and cells spill over you may end up with a mess...
Adam_P
PostPosted: 16:51 - 10 Jan 2012    Post subject: Reply with quote
Thanks everyone. It may be gone by the end of this evening. Sad Got a guy coming to view it later.
God is imaginary
The last post was made 14 years, 50 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.31 - MySQL Queries: 13 - Page Size: 56.66 Kb
