Honda Chaly CF70
binge
Emo Kiddy
PostPosted: 21:17 - 08 Jan 2012    Post subject: Honda Chaly CF70 Reply with quote
Alright guys,
I bought this about a month ago now, for £80. I had to drive to Plymoiuth to get it though! Nearly a 600 mile round trip.
It came with wheels too, they're up in the shed.
It was literally a pile of parts when I bought it, and tonight is the first time I've decided to piece it together to see what I have got to work with.
https://a2.sphotos.ak.fbcdn.net/hphotos-ak-ash4/s720x720/386098_10150513613050606_506045605_8748333_1965503706_n.jpg
The forks and yokes are pit bike ones. CRF50 fitment.
I will probably need to shorten the stanchions to get the ride height right, as when it's on its wheels, the swinger will be sitting level, making the front too high.
I will be running a swinger from a Honda C90, as they are about 4" longer, and have footpegs on them still. Laughing
I've just placed an order for a replacement seat, it's black with Honda printed into the back of it, in white.
Got front and rear mudgaurds, in white. Along with a leg sheld.
Will be running the really tall Chaly/Monkey handle bars too.
Engine wise, to everyones dissapointment, I am going to be running a fully automatic 50cc pit bike engine.
But will be fitting a 110 top end and head on it, to give it a little more go.
It'll still be faster than your average 50cc moped, but it's only a cruiser.
Plus, the petrol tank is dinky, so a fully loaded 160 pit engine wont get me very far due to the fuel consumption. Laughing
Ben
PostPosted: 21:23 - 08 Jan 2012    Post subject: Reply with quote
Very disappointed with the engine choice Laughing Was expecting a 140/160 and seeing you track it Mr. Green
Subscribed Thumbs Up
binge
Emo Kiddy
PostPosted: 22:00 - 08 Jan 2012    Post subject: Reply with quote
The problem is, if you want to run an engine with a secondary clutch, such as the 140/150/160 range, you need to hack the frame up to get the clutch actuator arm to clear.
Not something I really fancy doing.
Not only that, Fully auto is the way to go.
It means I can cop my feet up on the frame, and cruise about like they do in Cyprus. Laughing
extermin8tor
PostPosted: 12:30 - 10 Jan 2012    Post subject: Reply with quote
Long time lurker of 4 years, first post Smile
I restored one of these almost completely down here in Australia
Feel free to look at my thread for pictures and ideas, etc Smile
https://www.aussiestreetbikes.com/forum/showthread.php?t=12843
https://i.imgur.com/e4mGH.jpg
https://i.imgur.com/03qXo.jpg
https://i.imgur.com/lEXsC.jpg
https://i.imgur.com/IGOh4.jpg
bryvw1973
PostPosted: 18:27 - 10 Jan 2012    Post subject: Reply with quote
ill be following this as ive just bought a chaly project im yet to start.
do the 110 top ends fit straight on the little auto engines?as i dont want to alter my frame either
also how straight forward was the fork swap? im loving the look of usd forks
cheers
bry
binge
Emo Kiddy
PostPosted: 18:57 - 10 Jan 2012    Post subject: Reply with quote
cheers
bry
I'm not too clued up on the smaller CC engines, but I'm sure it wont take me long to find my way around them.
There are 4 types of pit bike / honda style engines.
You've got the original honda style, which are non start in gear.
The manual ones have a primary clutch, and require you to be in neutral to kick start it. If you pull the clutch in, it completely imobilizes the kick starter from the crank.
Then you have the secondary clutch style, which run a proper clutch on the gearbox.
This style runs a slightly different stud patter on the barel/head bolts, and they are also M7, as apposed to M6.
Then you've got the big 150s and 160s, which are KLX110 style (Kawasaki) top ends, mated to CRF style bottom ends.
They run M8 head bolts, and are completely different in fitment to the other 2 styles.
Now I am lead to beleive that the 50cc / 70cc / 90cc engines, all run the standard M6 honda stud pattern.
Meaning as long as the cylinder skirt can be made to fit into the crank cases, and the stroke is the same length, then you can go right up to a 110, or even a 125 barrel, piston and head on the smaller bottom ends.
I'm taking delivery of a fully auto, and a semi auto 50cc bottom end next week, so I'll find out.
The USDs are from 2 different types of pit bike.
The fork legs and yokes are from a CRF50 sized pit bike, as they are shorter.
Then the stem bolt is from a CRF70 style pit bike, SDG, as it's longer.
You could possibly use the stem bolt from the Chaly if it comes out of the bottom yoke.
I've yet to find some bearings that fit.
The Chaly runs smaller bearings, Outer races are smaller than the bearings which go with the SDG stem bolt.
So I'm going to have to mix and match bearings I think.
Thinking
Just having a look through that thread on the aussie forum.
Superb input, thanks! Very Happy
Ben
grahamd1
PostPosted: 19:38 - 10 Jan 2012    Post subject: Reply with quote
This is my Chaly (also rebuilding, as and when I find the parts)
https://www.bikechatforums.com/viewtopic.php?t=226879&highlight=chaly
XV1100, XV750
CD175 (Rebuild)
CF70 (Chaly - Rebuild),
Charlie
PostPosted: 22:01 - 10 Jan 2012    Post subject: Reply with quote
Chives also made an attempt at restoring one:
https://www.bikechatforums.com/viewtopic.php?t=184370&postdays=0&postorder=asc&start=0
PostPosted: 22:35 - 10 Jan 2012    Post subject: Reply with quote
Charlie wrote:
Can't remember the last time I did anything with it.
binge
Emo Kiddy
PostPosted: 21:44 - 14 Jan 2012    Post subject: Reply with quote
Loving the input here, didnt realise there were so many Chalys hiding out there.
Not really got anything to update.
My pal Gaz has just taken a few of the bits to his workshop to sandblast for me.
He'll be doing the frame next week.
I've just bought a few engines, and hopefully I can graft them together to make the high output semi-auto hybrid I want. Very Happy
I also managed to pick up a set of original handlebars and risers for £12 delivered. Cool
I've noticed from the pictures that they have the lever perches built into the bars... Strange.
Will have to take a look at them when they arrive. I may well grind the perches off, and fit regular levers and perches, providing they are standard 7/8 bars.
Ben
PostPosted: 12:06 - 15 Jan 2012    Post subject: Reply with quote
Just out of interest, Binge, what forks are fitted to yours and would they take the standard wheel? I imagine not but it's worth asking.
binge
Emo Kiddy
PostPosted: 13:12 - 15 Jan 2012    Post subject: Reply with quote
They are a set of SDG mini-pit forks from a Demon X pit bike. With yokes from something else, cant remember what it was.
I've had to mess around with the stem bolt, as the Chaly has like a 7" long headstock, and any pit bike has a 5.5" headstock (Sometimes 6.25").
Will be shortening the stanchions in the forks to lower the front.
The front wheel should go straight on, but you'd need to make a little bracket from the caliper mount to the drum brake, to act as a torque arm.
Or, OORacing sell a front disc conversion for the Chaly. It's just the hub, and has a 3 bolt face on the hub to run a disc.
It's what I will be doing.
They also sell a rear disc hub, with a solid mount sprocket conversion, to get rid of the horrible cush drive. Laughing
colin1
Captain Safety
PostPosted: 23:43 - 15 Jan 2012    Post subject: Reply with quote
i'm liking the aussies emoticon Smile
https://www.aussiestreetbikes.com/forum/images/smilies/ride.gif
binge
Emo Kiddy
PostPosted: 22:45 - 19 Jan 2012    Post subject: Reply with quote
Managed to get a Honda VIN plate for the Chaly, as it doesnt have one, nor does it have any substantial frame numbers as the frame's been painted so many times.
Need to find somewhere who can engrave / stamp it professionally, so it doesnt look like a ringer! Laughing
Nice tin pressed plate for the old girl too.
https://a4.sphotos.ak.fbcdn.net/hphotos-ak-ash4/403625_10150538574505606_506045605_8826241_1669935890_n.jpg
binge
Emo Kiddy
PostPosted: 18:39 - 21 Jan 2012    Post subject: Reply with quote
Okay, decided to bin the semi auto / fully auto idea, and just go balls out with a massive motor.
Here it is:
https://a2.sphotos.ak.fbcdn.net/hphotos-ak-snc7/s720x720/396083_10150541000550606_506045605_8831870_1460627732_n.jpg
Re-shimmed the gearbox to get a tighter gear engagement in second as the bigger engines are prone for jumping in 2nd and 3rd.
https://a6.sphotos.ak.fbcdn.net/hphotos-ak-ash4/s720x720/407197_10150540999440606_506045605_8831866_129052037_n.jpg
Here it is:
https://a8.sphotos.ak.fbcdn.net/hphotos-ak-ash4/s720x720/408191_10150540938285606_506045605_8831768_107752680_n.jpg
It's a Zongshen 155 engine. Latest and best one on the market for pit bikes.
Will have to modify / cut the frame to get it in, but who cares! The Chaly isnt a restoration project anyway.
Will still look fairly stock as far as the bike goes. Cant wait to start dicking on Ped boys with it! Laughing
Them 155 engines produce about 15hp.
With a few mods and some head work, can get them up to 20hp~.
Ben
PostPosted: 19:56 - 21 Jan 2012    Post subject: Reply with quote
Cool Man points have been restored Thumbs Up
binge
Emo Kiddy
PostPosted: 19:35 - 23 Jan 2012    Post subject: Reply with quote
Right, having a look at the engine tonight, and mocked it up in the frame.
Looks like I need to do a few things:
Remove some of the cooling fins from the cylinder head and barrel of the engine. As they dont fit up inside the frame.
It's only on the right hand side though, above the spark plug.
I'm running a extra large oil cooler though, so removing the fins shouldnt be a problem.
I need to mount the clutch cable perch on the frame somehow, for the cable to clamp into. As it doesnt fit under the frame.
I will also need to either modify the actuator arm for the clutch, or cut the frame. Not sure how I'll cut the frame though as it's right beside where the engine mount is. Confused
Time to experiment and research.
Ben
garth
PostPosted: 20:36 - 23 Jan 2012    Post subject: Reply with quote
If you decide you want to mod an auto, I might have one.
binge
Emo Kiddy
PostPosted: 22:21 - 24 Jan 2012    Post subject: Reply with quote
Well the Zonga 155 is in! Cool
No cutting engine fins at all.
Just a small cut had to be made to the inside of the frame on the secondary skin steel. Had to take out a 1" square section to clear the Cam Chain tensioner.
And I've had to bend the clutch actuator arm up a tad higher, along with space the bracket out for the clutch cable using longer bolts.
Had to make a few cuts to the leg sheld too. Needs to be neatend up still.
Handlebars have been heavily modified. I've cut all the built in throttle away. Removed the built in levers, and pulled all the wiring out of them as it had all broken up.
I've fitted regular pit bike levers and throttle to the bars too.
I wont be running any switch gear as such. Just a simple 2 button unit, for horn, and high beam on/off.
Lights will be on all the time. I will probably pass them through a switch under the seat or something incase I ever want them off.
And an ignition will be fitted somewhere at the bottom of the bars. Maybe in the side of the frame near the seat like on the road legal pit bikes.
Seat, mudgards etc all arrived. Very happy with them. Cool
https://a1.sphotos.ak.fbcdn.net/hphotos-ak-snc7/408063_10150550524105606_506045605_8862080_1979595264_n.jpg
https://a3.sphotos.ak.fbcdn.net/hphotos-ak-ash4/397056_10150550525315606_506045605_8862088_162190887_n.jpg
https://a1.sphotos.ak.fbcdn.net/hphotos-ak-ash4/403028_10150550492905606_506045605_8861984_623306475_n.jpg
garth
PostPosted: 08:47 - 25 Jan 2012    Post subject: Reply with quote
Sweet.
Chinese / American seat?
PS What's the orange stuff in the coke bottle? Swarfega?
UnspeedySam
PostPosted: 09:03 - 25 Jan 2012    Post subject: Reply with quote
garth wrote:
Sweet.
My guess is coolant.
binge
Emo Kiddy
PostPosted: 12:03 - 25 Jan 2012    Post subject: Reply with quote
garth wrote:
Sweet.
Its from Thailand. Would of loved to get my original Honda one re covered but the base was crumbling away.
That is indeed swarfega in the coke bottle. Just fill it up every few weeks at work. Handy to have up at my garage as Ive got an out side tap there too. Hence the kettle. Smile
AL-
PostPosted: 12:18 - 25 Jan 2012    Post subject: Reply with quote
looking forward to seeing this progress Cool
garth
PostPosted: 12:48 - 25 Jan 2012    Post subject: Reply with quote
Gotta get a pimp exhaust and shocks like my cub. Cool
PostPosted: 13:07 - 25 Jan 2012    Post subject: Reply with quote
Gotta have a go on that Laughing
The last post was made 14 years, 299 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.13 Sec - Server Load: 0.57 - MySQL Queries: 13 - Page Size: 132.83 Kb
