| binge |
 binge Emo Kiddy
 Posted: 21:17 - 08 Jan 2012 Post subject: Honda Chaly CF70 |
Alright guys,
I bought this about a month ago now, for £80. I had to drive to Plymoiuth to get it though! Nearly a 600 mile round trip.
It came with wheels too, they're up in the shed.
It was literally a pile of parts when I bought it, and tonight is the first time I've decided to piece it together to see what I have got to work with.
https://a2.sphotos.ak.fbcdn.net/hphotos-ak-ash4/s720x720/386098_10150513613050606_506045605_8748333_1965503706_n.jpg
The forks and yokes are pit bike ones. CRF50 fitment.
I will probably need to shorten the stanchions to get the ride height right, as when it's on its wheels, the swinger will be sitting level, making the front too high.
I will be running a swinger from a Honda C90, as they are about 4" longer, and have footpegs on them still.
I've just placed an order for a replacement seat, it's black with Honda printed into the back of it, in white.
Got front and rear mudgaurds, in white. Along with a leg sheld.
Will be running the really tall Chaly/Monkey handle bars too.
Engine wise, to everyones dissapointment, I am going to be running a fully automatic 50cc pit bike engine.
But will be fitting a 110 top end and head on it, to give it a little more go.
It'll still be faster than your average 50cc moped, but it's only a cruiser.
Plus, the petrol tank is dinky, so a fully loaded 160 pit engine wont get me very far due to the fuel consumption.
Ben |
| P.addy |
 P.addy Red Rocket
 Posted: 21:23 - 08 Jan 2012 Post subject: |
Very disappointed with the engine choice Was expecting a 140/160 and seeing you track it
Subscribed  |
| binge |
 binge Emo Kiddy
 Posted: 22:00 - 08 Jan 2012 Post subject: |
The problem is, if you want to run an engine with a secondary clutch, such as the 140/150/160 range, you need to hack the frame up to get the clutch actuator arm to clear.
Not something I really fancy doing.
Not only that, Fully auto is the way to go.
It means I can cop my feet up on the frame, and cruise about like they do in Cyprus.  |
| extermin8tor |
 extermin8tor L Plate Warrior
 Posted: 12:30 - 10 Jan 2012 Post subject: |
| bryvw1973 |
 bryvw1973 Two Stroke Sniffer
| binge |
 binge Emo Kiddy
 Posted: 18:57 - 10 Jan 2012 Post subject: |
| bryvw1973 wrote: | ill be following this as ive just bought a chaly project im yet to start.
do the 110 top ends fit straight on the little auto engines?as i dont want to alter my frame either
also how straight forward was the fork swap? im loving the look of usd forks
cheers
bry |
I'm not too clued up on the smaller CC engines, but I'm sure it wont take me long to find my way around them.
There are 4 types of pit bike / honda style engines.
You've got the original honda style, which are non start in gear.
The manual ones have a primary clutch, and require you to be in neutral to kick start it. If you pull the clutch in, it completely imobilizes the kick starter from the crank.
Then you have the secondary clutch style, which run a proper clutch on the gearbox.
This style runs a slightly different stud patter on the barel/head bolts, and they are also M7, as apposed to M6.
Then you've got the big 150s and 160s, which are KLX110 style (Kawasaki) top ends, mated to CRF style bottom ends.
They run M8 head bolts, and are completely different in fitment to the other 2 styles.
Now I am lead to beleive that the 50cc / 70cc / 90cc engines, all run the standard M6 honda stud pattern.
Meaning as long as the cylinder skirt can be made to fit into the crank cases, and the stroke is the same length, then you can go right up to a 110, or even a 125 barrel, piston and head on the smaller bottom ends.
I'm taking delivery of a fully auto, and a semi auto 50cc bottom end next week, so I'll find out.
The USDs are from 2 different types of pit bike.
The fork legs and yokes are from a CRF50 sized pit bike, as they are shorter.
Then the stem bolt is from a CRF70 style pit bike, SDG, as it's longer.
You could possibly use the stem bolt from the Chaly if it comes out of the bottom yoke.
I've yet to find some bearings that fit.
The Chaly runs smaller bearings, Outer races are smaller than the bearings which go with the SDG stem bolt.
So I'm going to have to mix and match bearings I think.
Just having a look through that thread on the aussie forum.
Superb input, thanks!
Ben |
| grahamd1 |
 grahamd1 Trackday Trickster
| Charlie |
 Charlie World Chat Champion
| ms51ves3 |
 ms51ves3 Super Spammer
 Posted: 22:35 - 10 Jan 2012 Post subject: |
Can't remember the last time I did anything with it. |
| binge |
 binge Emo Kiddy
 Posted: 21:44 - 14 Jan 2012 Post subject: |
Loving the input here, didnt realise there were so many Chalys hiding out there.
Not really got anything to update.
My pal Gaz has just taken a few of the bits to his workshop to sandblast for me.
He'll be doing the frame next week.
I've just bought a few engines, and hopefully I can graft them together to make the high output semi-auto hybrid I want.
I also managed to pick up a set of original handlebars and risers for £12 delivered.
I've noticed from the pictures that they have the lever perches built into the bars... Strange.
Will have to take a look at them when they arrive. I may well grind the perches off, and fit regular levers and perches, providing they are standard 7/8 bars.
Ben |
| ms51ves3 |
| binge |
 binge Emo Kiddy
 Posted: 13:12 - 15 Jan 2012 Post subject: |
They are a set of SDG mini-pit forks from a Demon X pit bike. With yokes from something else, cant remember what it was.
I've had to mess around with the stem bolt, as the Chaly has like a 7" long headstock, and any pit bike has a 5.5" headstock (Sometimes 6.25").
Will be shortening the stanchions in the forks to lower the front.
The front wheel should go straight on, but you'd need to make a little bracket from the caliper mount to the drum brake, to act as a torque arm.
Or, OORacing sell a front disc conversion for the Chaly. It's just the hub, and has a 3 bolt face on the hub to run a disc.
It's what I will be doing.
They also sell a rear disc hub, with a solid mount sprocket conversion, to get rid of the horrible cush drive.  |
| colin1 |
 colin1 Captain Safety
| binge |
 binge Emo Kiddy
| binge |
 binge Emo Kiddy
| P.addy |
 P.addy Red Rocket
 Posted: 19:56 - 21 Jan 2012 Post subject: |
Man points have been restored  |
| binge |
 binge Emo Kiddy
 Posted: 19:35 - 23 Jan 2012 Post subject: |
Right, having a look at the engine tonight, and mocked it up in the frame.
Looks like I need to do a few things:
Remove some of the cooling fins from the cylinder head and barrel of the engine. As they dont fit up inside the frame.
It's only on the right hand side though, above the spark plug.
I'm running a extra large oil cooler though, so removing the fins shouldnt be a problem.
I need to mount the clutch cable perch on the frame somehow, for the cable to clamp into. As it doesnt fit under the frame.
I will also need to either modify the actuator arm for the clutch, or cut the frame. Not sure how I'll cut the frame though as it's right beside where the engine mount is.
Time to experiment and research.
Ben |
| garth |
 garth World Chat Champion
| binge |
 binge Emo Kiddy
| garth |
| UnspeedySam |
 UnspeedySam World Chat Champion
| binge |
 binge Emo Kiddy
| AL- |
 AL- World Chat Champion
 Posted: 12:18 - 25 Jan 2012 Post subject: |
looking forward to seeing this progress  |
| garth |
 Posted: 12:48 - 25 Jan 2012 Post subject: |
Gotta get a pimp exhaust and shocks like my cub.  ____________________ You ain't a has been if you never was |
| P.addy |
 P.addy Red Rocket
 Posted: 13:07 - 25 Jan 2012 Post subject: |
Gotta have a go on that  |
The last post was made 14 years, 299 days ago. Instead of replying here, would creating a new thread be more useful? |
