| P.addy |
 P.addy Red Rocket
 Posted: 13:20 - 10 Jan 2012 Post subject: Steering lock and ignition |
Hi, I haz stol a moped coz it duz 60mph blud, but its got a MASSIVE problm.
Anyway, some nugget screwdrivered my ignition and didn't bother snapping the steering.
Helpful knob is helpful!
I'm good with the ignition, can replace that today (I hope)
The steering lock on the other hand... will this be unlocked when I install a new ignition? Reason being... I have been loaned the bike while I fix and repair the GSXR and just by chance I leave the bike outside and it gets touched, cant lock in safe area as the steering lock is on and I cant walk it the 500metres  |
| Vincent |
 Vincent Banned
| P.addy |
 P.addy Red Rocket
 Posted: 13:36 - 10 Jan 2012 Post subject: |
Sounds like its going to be a PITA.
I have to replace it, its not mine and I'm not returning it sub standard!
Fuck sake... was under CCTV but the people at the bingo who own it are as useful as a cheese crowbar.
Could I just remove the ignition and put new one in set as "lock"
Unsure how the steering lock works on these  |
| Vincent |
 Vincent Banned
| P.addy |
 P.addy Red Rocket
 Posted: 13:59 - 10 Jan 2012 Post subject: |
XJ600 Divvy 1993  |
| Vincent |
 Vincent Banned
| P.addy |
 P.addy Red Rocket
| Vincent |
 Vincent Banned
| P.addy |
 P.addy Red Rocket
 Posted: 15:18 - 10 Jan 2012 Post subject: |
Have a vice. Dad is going to attempt when I'm at work so will give him the details you posted
How strong are the tamper bolts
Thanks for all the advice  |
 Posted: 15:38 - 10 Jan 2012 Post subject: |
Tamper proof bolts are not normally in that tightly, but are still gits to get out when the yoke is in place. Cut a slot in them and then use an impact driver, or if you can get at them use some mole grips. However they are designed to be difficult to get at.
On most bikes the ignition switch is also the steering lock. When you lock it a peg comes out from the lock and into a hole in the headstock (probably a small bracket welded to the headstock).
Trouble is that with the steering lock enabled you probably can't remove the top yoke (as the yoke needs to go up over the forks, but the peg in the hole stops it moving that way). What you probably need to do is support the front of the bike, slacken off the clamp bolts on the top yoke for the forks and undo the nut on the top yoke and drop the forks and bottom yoke down a couple of inches. The top yoke should then come off easily (but if it is the original style steering head bearings, these will now be rolling round the surrounding area).
You could drill the lock out, but that might take a while. You could try and smash the lock off, but then you stand a chance of breaking off the mounts on the top yoke for the lock.
| P.addy |
 P.addy Red Rocket
| Vincent |
 Vincent Banned
| Vincent |
 Vincent Banned
| P.addy |
 P.addy Red Rocket
| P.addy |
 P.addy Red Rocket
 Posted: 16:33 - 10 Jan 2012 Post subject: |
They won't be tight but there will likely be 2 of them. One to set the tension, the other to lock the first in place.
Just though, there might also be a bit of tin with prongs to try and keep them together. You might have to wreck that by bending the prongs out of the way to undo them. In which case screw drivering the lock might be easier!
| P.addy |
 P.addy Red Rocket
| P.addy |
 P.addy Red Rocket
 Posted: 16:56 - 10 Jan 2012 Post subject: |
Ignition is dead, can't do more damage
I might give it the screwdriver treatment tonight and try to remove the lock, does it really mean the whole top yoke needs removing or loosening, I can get to the underside of the ignition as it stands. |
| Vincent |
 Vincent Banned
| P.addy |
 P.addy Red Rocket
 Posted: 17:12 - 10 Jan 2012 Post subject: |
Fetch me a grinder.
Thing is I really CBA with doing the head bearings... I know it should be done, but the bike was religiously maintained by previous owner, so hope he has changed them to decent ones.
I need the bike for work, currently driving my mums pimp wagon and its terrible  |
The last post was made 14 years, 137 days ago. Instead of replying here, would creating a new thread be more useful? |
